Question about installing an amp in a 2013 door jk with stock head unit and no - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 10-28-2013, 06:03 PM Thread Starter
JG1981's Avatar
Just ordered an amp, sub and wiring along with a PAC 2 channel line out converter to run from the head unit. Should I tap into the two front speakers with the LOC? Any advice would be appreciated!!
JG1981 is offline
post #2 of 19 Old 10-28-2013, 06:05 PM
bluewave's Avatar
id grab it off your factory sub if you have it, or just grab it off one of the speakers.
Texas Complete Truck Center
5670 S Interstate 35
New Braunfels, Texas
(210) 412-6379
bluewave is offline
post #3 of 19 Old 10-28-2013, 06:09 PM Thread Starter
JG1981's Avatar
I read somewhere that the factory speakers signals are cut off at certain frequencies and it varies from front to rear speakers. This is done because of the shitty factory speakers and underpowered head unit??
JG1981 is offline
post #4 of 19 Old 10-28-2013, 06:10 PM Thread Starter
JG1981's Avatar
Also, I don't have a sub from the factory.
JG1981 is offline
post #5 of 19 Old 10-28-2013, 06:22 PM
bluewave's Avatar
check out my attachment
(210) 412-6379
bluewave is offline
post #6 of 19 Old 10-28-2013, 06:37 PM Thread Starter
JG1981's Avatar
JG1981 is offline
post #7 of 19 Old 10-28-2013, 08:04 PM Thread Starter
JG1981's Avatar
OK. Opened in Safari. Was using app. Got it. Thanks.
JG1981 is offline
post #8 of 19 Old 11-04-2013, 01:49 PM Thread Starter
JG1981's Avatar
So, I just had a local audio shop install new Fusion brand 6 1/2'' components in the front. Tweeters fit perfect and look great. The soundbar speakers have been replaced with the kicker replacements from quadratec. I had the shop install the cheap pac line out converter and install the jl audio xd300/1 amp in the rear cubby compartment and placed the pioneer shallow sub and enclosure in the rear. Everything sounds good (sub still needs broken in). The shop that installed the system hooked up the line out converter to the rear right speaker. I asked them before the install to use the front speakers to send the signal from the loc to the sub amp but they must not have understood me. Is my amp not getting the full signal because they are using the rear speaker and it's only connected to the right rear???
The sound quality from the new components is way better than stock but they could sound much better with an amp. I am writing this post because I am at a crossroad and need some advice on where to go next...
I like the idea of keeping the factory head unit because of theft. Adding a four channel amp (the jl audio xd400/4) is what I would like to do next. I have read several post concerning this topic but I am still left wondering what products I need that would not break the bank??
JG1981 is offline
post #9 of 19 Old 11-04-2013, 01:54 PM Thread Starter
JG1981's Avatar
The Pac C2A-CHY23 will allow me to connect rca's, but that doesn't let me adjust treble, bass, etc....
JG1981 is offline
post #10 of 19 Old 11-05-2013, 06:41 AM
I ditched the factory head unit.
Originally I had just the replacement kicker 6 1/2" speakers up front and in the sound bar. I added some of that pillow packing stuff to the sound bar and that helped out the sound too.
Then I ditched the factory head unit and it completely changed the sound of those speakers. After that, I got tired of not having any good thumping bass, so I added a single 10" MTX sub and a MTX 250D amp. It thumps plenty hard and sounds really good now.
To get quality sound out of it, you're going to have to ditch the factory head unit.
2008 Patriot Limited 4x4
2010 Jeep JK Sport 2dr/6spd/3.73's
Go visit
...and tell your friends!
SmurfJK is offline
post #11 of 19 Old 11-05-2013, 09:36 AM Thread Starter
JG1981's Avatar
Thanks for the reply. It looks like I'm going to take a chance and put either a single din or double din in to replace oem unit. I would only do the single din because they have detachable faces and most of the doubles do not. Does anyone know of a good double din unit that has a detachable face? Also, other than losing my ability to fade from front to rear, is there anything else the canbus system will not allow the new aftermarket radio to do? I want to regain a full use of the soundbar and send the entire frequency signal to all four speakers. Will the aftermarket allow me to do this? Any help would be appreciated!!
JG1981 is offline
post #12 of 19 Old 11-05-2013, 01:19 PM
Davesrb's Avatar
Once you get into replacing the head unit and add the second amp you regain control of everything. You will bypass the factory amp and just RCA out to the new aftermarket amps. Canbus will not matter at all at that point. If you need to save some cash at first, just get a decent high power head unit and power the fronts and soundbar speakers with it, RCA out to your sub amp. Pioneer makes a model, something like AVH8500?? That has a detachable face, high power, plenty of eq and crossover controls that would do well for your needs.
Davesrb is offline
post #13 of 19 Old 11-05-2013, 03:33 PM Thread Starter
JG1981's Avatar
Thanks for the reply. That head unit looks awesome. If I don't add the amp at first and just do the new head unit, will that resolve the soundbar speaker limitations?
JG1981 is offline
post #14 of 19 Old 11-05-2013, 03:42 PM Thread Starter
JG1981's Avatar
Also, I mentioned above that I do not have the premium system with the amp. My wrangler is bone stock with the cheapest factory system available.
JG1981 is offline
post #15 of 19 Old 11-05-2013, 04:13 PM Thread Starter
JG1981's Avatar
OK so just found out from crutchfield that all 2013's have some sort of amp regardless if you have the alpine system or not. He said to just bypass the amp using the new head unit and tap into the output of the factory amp to avoid running all new wire to the four speakers. The harness they suggested is Pac C2R-CHY4. The install kit is free from crutchfield.
JG1981 is offline
post #16 of 19 Old 11-08-2013, 06:36 AM
JKY
My 2013 JK does not have the Alpine system and does Not have an external amp.
JKY is offline
post #17 of 19 Old 11-08-2013, 07:09 AM Thread Starter
JG1981's Avatar
Ok. I don't think i have the amp either but the guy at crutchfield said his computer system was telling him all new jeeps have an amp regardless of system. ??
JG1981 is offline
post #18 of 19 Old 11-08-2013, 08:09 AM
JKY
Crutchfield is not correct. I installed the Alpine KTP-445U amp on mine and I am sure there was not another amp.
JKY is offline
post #19 of 19 Old 11-11-2013, 07:12 PM Thread Starter
JG1981's Avatar
"Edit"
JG1981 is offline
