Rock Lights... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 28 Old 07-02-2009, 03:41 PM Thread Starter
Tank29's Avatar
Rock Lights...
Where are you guys mounting your rock lights at on the 4dr's?...What for lights are you using too?...Thanks and many 's to all!!!
Have a safe and happy 4th!!!!!
2007 JK Unlimited "X"
TF 3" Kit w/4 Arm Flex Kit, TF HD F & R Adj. Track Bars, TF HD Steering Stabilizer, Yukon 5.13 gears, CenterForce II Clutch, Black Rock Soft 8's 16x8, Cooper Discoverer STT 315/75/16, RR XHD Front w/Stinger, SB XRC Rear w/Carrier, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fenders, SB XRC8 Winch
Tank29 is offline
post #2 of 28 Old 08-07-2009, 07:15 PM
jkpirate's Avatar
Everyone uses Night Vision Goggles now.
Ronjk-forum, jk forum,jeep wrangler jk.
jkpirate is offline
post #3 of 28 Old 08-07-2009, 07:24 PM
Jscwerve is offline
post #4 of 28 Old 08-07-2009, 07:31 PM
Dr.Dirty's Avatar
Feedback: 21 reviews
here is where i mounted mine and they work great i have mover the 2 in the rear because the RE kit mounted where i had them
www.jeepasylum.com
Dr.Dirty is offline
post #5 of 28 Old 08-07-2009, 07:45 PM
jkpirate's Avatar
Thanks, I just picked up some small lights at Walmart and wanted to get a few ideas where people were mounting them on JK's
jkpirate is offline
post #6 of 28 Old 08-07-2009, 10:46 PM
I'm installing 10 LEDs tomorrow probably as rock lights. Well 10 pods of 9 LEDs. These are pretty serious lights, I plan to have no shadows under my Jeep...
post #7 of 28 Old 08-07-2009, 11:01 PM
StubEXrube's Avatar
Optronics at Walmart- cheap, and they do the trick.
StubEXrube is offline
post #8 of 28 Old 08-08-2009, 09:08 AM
jkpirate's Avatar
Those are the same Walmart lights I picked up. I didn't think they would put out that much light. I need to get busy and get them mounted then figure out how many relays I need for 6 lights. Thanks for the Pics.
jkpirate is offline
post #9 of 28 Old 08-08-2009, 09:15 AM
Dr.Dirty's Avatar
just steer clear of water with them on lol (dont ask me how i know i have two sets broken )
and those particular luight put out alot of heat so make sure you fuse and realy them hell better yet John at sPOD has the soulution for rocklights makes install very easy
www.jeepasylum.com
Dr.Dirty is offline
post #10 of 28 Old 08-08-2009, 09:49 AM
jkpirate's Avatar
That's good to know, I'll make sure I wire them so they can be unplugged and replaced quick. I also need to check the amp draw and determine if one relay can handle 6 lights.
jkpirate is offline
post #11 of 28 Old 08-08-2009, 07:41 PM
StubEXrube's Avatar
I pulled the rubber caps off of them, soldered the (screw-type) connections, and sealed them with high-temp rtv sealant, so they are completely waterproof now. Yes they get a little warm. I also wired in one 25 amp relay for two lights. Below is a schematic I made prior to installation.
post #12 of 28 Old 08-08-2009, 08:34 PM
jkpirate's Avatar
jkpirate is offline
post #13 of 28 Old 08-08-2009, 08:40 PM
usmcdoc14's Avatar
you laugh, have you read the RROR skid review? https://www.jkowners.com/productreviews/rror/index.php Thats how I was driving while testing them
NVG's, towel over the dash lights, chasing guys in the woods.
Rock lights work better
I am looking for LED's but have not found anything cheap/work well. Sorry but I am not dropping $100 on rock lights
usmcdoc14 is offline
post #14 of 28 Old 08-08-2009, 09:33 PM
post #15 of 28 Old 08-09-2009, 09:46 AM
RODICON's Avatar
Nice.
RODICON is offline
post #16 of 28 Old 08-17-2009, 04:59 AM Thread Starter
Tank29's Avatar
I agree...I am somewhat CHEAP!!!...
Cool...I was thinking of doing the same with a set of lights I had given to me but I have seen a couple sets at Walmart that are smaller...I may just buy two sets for now and try it...Thanks for posting the wiring diagram too...
Very nice!!!!...If could find some LED lights cheap then I would probably go that route...I (mainly the WIFE) just can't justify dropping $100 for lights...I will keep searching for a cheap set of LED's and in the meantime I will use a cheap set from Walmart I guess...
Tank29 is offline
post #17 of 28 Old 08-17-2009, 06:55 AM
My LEDs were $35, shipped for ten. So you could have 20 of my LEDs plus some change for you're $100 issue lol
post #18 of 28 Old 08-17-2009, 07:12 AM Thread Starter
Tank29's Avatar
COOL!!!
Where did you get them?...
Tank29 is offline
post #19 of 28 Old 08-17-2009, 10:12 AM
email seller hyperledsinc and tell him you want the rock lights that goodysgotacuda put on his Jeep. he should know what you're talking about
post #20 of 28 Old 08-17-2009, 10:39 AM Thread Starter
Tank29's Avatar
Sweet...Thanks!!!
Tank29 is offline
post #21 of 28 Old 08-19-2009, 10:31 PM
Swinge86's Avatar
Boy am I glad I found this post, because I've been looking into doing this... and have been dreaming about how! Goodysgotacuda, how many lights do you have under there? I'm wondering if those would light up the underside of an unlimited....
'08 Silver JKU - Grace
“We often miss opportunity because it's dressed in overalls and looks like work”
― Thomas A. Edison
Swinge86 is offline
post #22 of 28 Old 08-19-2009, 10:34 PM
10 lights, 9leds per light, $35. You could do 15 or so and have some spares for interior lights or something for an unlimited
post #23 of 28 Old 08-19-2009, 10:36 PM
Swinge86's Avatar
Very nice, thanks for the info.... you put all 10 up under yours?
― Thomas A. Edison
Swinge86 is offline
post #24 of 28 Old 08-19-2009, 10:42 PM
yep
post #25 of 28 Old 08-20-2009, 12:52 AM
NYJKGUY's Avatar
Send a message via AIM to NYJKGUY
I like the way it looks i just might have to do this one day
i dont really want to look at filthy girls anyway
NYJKGUY is offline
