6 speed drain plug - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 05-25-2009, 05:01 PM Thread Starter
6 speed drain plug
I went to change the tranny oil in my 09 rubicon over to synthetic the other day and realized the exaust runs right under the plug ! WTF !! Thus leaving me with 2 options; 1. Remove transmission just to change the oil (get right on that) 2. Remove exaust, just to change oil. You have to love american engineering. I have never been a Jeep guy. Infact, this is the 1st one I have ever owned. Loving it so far ! lol. CHRYSLER W T F !!!!!!!!
tophvytoy is offline
post #2 of 13 Old 05-25-2009, 05:29 PM
H8T2W8T's Avatar
I've been putting off on doing mine for this reason. Where did you get the oil? I've looked everywhere locally (except the dealer) for oil that meets the specs, but no dice.
BIG RED JEEP
H8T2W8T is offline
post #3 of 13 Old 05-25-2009, 06:19 PM
mcnaught6's Avatar
go get a set of drain plug sockets (they are pretty cheap) then take the one that fits, and cut the end of it off (the part that goes into the drain plug - basically removing the part that attaches to the socket wrench). then stick the part that you cut off into the drain plug and use a wrench to turn it.
did that make any sense?
this doesn't keep you from making a mess, but it isn't too bad, and it works.
mcnaught6 is offline
post #4 of 13 Old 05-25-2009, 06:21 PM
rockrash's Avatar
all you need is a small 1/2 bolt with 2 nuts on the end. just grind the bolt head down a bit so it fits. If you have a good hardware store you might be able to a metric size to fit with out grinding.
.[___]
(OllllllO)
{}--o{}
rockrash is offline
post #5 of 13 Old 05-26-2009, 05:21 PM
Mule'Con's Avatar
Use a piece of heavy plastic wrap & make a bib, that way it spills over the top, and into a drain pan. Who makes the 6spd tranny for us?
2008 Red Rock Rubicon Unltd 6spd dual top
Mule'Con is offline
post #6 of 13 Old 05-26-2009, 05:47 PM
rockrash's Avatar
I think I rember hearing germany could be wrong
.[___]
(OllllllO)
{}--o{}
rockrash is offline
post #7 of 13 Old 05-26-2009, 08:11 PM
Mule'Con's Avatar
Hows about the clear non hypoid fluid? Like surgical syrup! My fluid is clear as mineral oil.
Mule'Con is offline
post #8 of 13 Old 08-08-2009, 07:51 AM
bubba2u's Avatar
you can use Syncromesh. you can get it at any auto parts store. i bought a tool on ebay to get at the drain plug. use a garbage can lid (upside down) over your used oil pan to catch the fluid.
bubba2u is offline
post #9 of 13 Old 08-10-2009, 08:24 AM
I've got to check and possibly change my fluid and I have been dreading it. Who honestly puts an exhaust pipe underneath a drain plug. Idiots.
Oh well I still love my JK. Horrible drain plug position, leaks, and all.
JaysJK is offline
post #10 of 13 Old 08-10-2009, 05:54 PM
took the two nuts off the rear trans mounts and jacked the trans up some to clear a real short socket.
post #11 of 13 Old 08-10-2009, 09:31 PM
X2!! Total B.S.
Prolly a metric bolt that takes a 12mm wrench. Just guessing it might be an M8. Take your 12mm wrench into the parts store and get a bolt that fits it.
JonB KE6GFB
Lake Tahoe Hi-Lo's
S. Lake Tahoe, CA
08 Wrangler X 4dr. 6sp: Winched, bumpered, Atlased, 5:13 Rubi axles, 37" Kevlar MTRs, Treks skids.
87 Toy BJ70 LandCruiser. Winched, bumpered, 35ed, locked, slidered, dieseled.
87 Toy 4r. Winched, bumpered, dual cased, 35ed, locked, slidered. -Sold, to pay for Jeep parts!
jonb96150 is offline
post #12 of 13 Old 08-10-2009, 09:38 PM
OlegRock's Avatar
vice grips ... just on the lower portion so as to not ruin the thread...
... on and royal purple
OlegRock is offline
post #13 of 13 Old 08-11-2009, 08:41 AM
07unlimitedx's Avatar
Here's what I did...
https://www.jkowners.com/forum/showthread.php?t=11755
07unlimitedx is offline
