Out of alignment. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 01-31-2011, 02:09 PM Thread Starter
FosDad's Avatar
Out of alignment.
I have less than 3k miles and no serious off-road yet and my front end is already out of alignment.
FosDad is offline
post #2 of 10 Old 01-31-2011, 02:10 PM
MoridinTX's Avatar
What exactly is out of alignment?
09 BLACK Sahara 4 Door - Auto, G2 4.88s
TF 2.5" Coil Lift w/shocks, TF Frnt Adj Trac, TF FLCA, JKS Discos, JKS Rear Adj Trac, LOD Full Rear GEN2,
A.C.E. Rock Rails, Viper TB: Check the Garage for more.
MoridinTX is offline
post #3 of 10 Old 01-31-2011, 02:36 PM Thread Starter
FosDad's Avatar
I haven't had time to investigate yet as I just noticed this morning on the way into work, but it pulls hard to the right and would go right off the side of the road in a matter of seconds if I were to let go of the wheel.
FosDad is offline
post #4 of 10 Old 01-31-2011, 02:54 PM
gdub's Avatar
That could be a lot of things - maybe not the alignment - tire pressure, ball joint going bad, crown in road, severe semi-driven groove, bolts wallowed out, etc.
Is your steering wheel still centered? There's really only 2 adjustments (well, other than castor - but that requires more lift to come into play usually).
Would be curious what your findings locate...
2.5" Rock Krawler Stock Mod Lift : Bilstein 5100's Front & Back : Rock Krawler Discos : 35X12.5X17 Goodyear MTR/K's : 2" Rock Krawler Stackable Bumpstops F/R : ProComp 7089's 17x9 4.75BS : Poison Spyder Evap Skid : Poison Spyder Brawler Lite : Spiderwebshade - Trailmesh : Recon 10,500lb Winch : Olympic Rock Sliders : Hella Black Magic Lights
gdub is offline
post #5 of 10 Old 01-31-2011, 04:02 PM
levellinebrad's Avatar
toe and sterring wheel center are the only things adjustable. I would check your air pressure.
levellinebrad is offline
post #6 of 10 Old 01-31-2011, 04:35 PM
Should've put a Rubicon sticker on it. Then, it'll always be aligned.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #7 of 10 Old 01-31-2011, 04:43 PM
BeerMonkeY's Avatar
thats what i did, plus i get laid more cause of it
'92 YJ
'13 WK2
BeerMonkeY is offline
post #8 of 10 Old 01-31-2011, 04:47 PM Thread Starter
FosDad's Avatar
The Rubicon sticker didn't help.
FosDad is offline
post #9 of 10 Old 02-01-2011, 05:58 AM
bubba2u's Avatar
getting laid always helps for me.
bubba2u is offline
post #10 of 10 Old 02-06-2011, 11:51 PM
The factory alignemt isn't very good. Some brand new ones need to be adjusted. Once you have it dialed it should be solid till you hit rocks with your tierod.
