Short KM2's - JKowners.com : Jeep Wrangler JK Forum
post #1 of 24 Old 02-24-2010, 02:12 PM Thread Starter
Short KM2's
My new 315/75 R16's (35's) KM2's arrived on the doorstep today. Took a measuring stick to them and they barely measure 34 inches tall unmounted. I knew BFG's run small but only 34inches ??? Perhaps they'll grow up when mounted and full of air.
seiken01 is offline
post #2 of 24 Old 02-24-2010, 02:16 PM
Heat'n and a beat'n...
STUPIDFACE's Avatar
Dont count on it.
corey d
corey d
2008 JEEP...
STUPIDFACE is offline
post #3 of 24 Old 02-24-2010, 02:20 PM
terrahawk's Avatar
BFG's always run smaller than advertised.
terrahawk is offline
post #4 of 24 Old 02-24-2010, 02:28 PM Thread Starter
Originally Posted by STUPIDFACE View Post
Dont count on it.
corey d
More of a false hope I have, either way it will still be better than the 33's on now that are measuring 31.5.
seiken01 is offline
post #5 of 24 Old 02-24-2010, 10:46 PM
Dang, I hope that the KM2 37"s that I'm ordering on Friday are a bit smaller. I have this 5.5 RK lift and if they are a full 37 then it may not fit in the garage anymore! But I'm going KM2 because I've seen them in action on the trail and they outperform my Mick Thompson MTZ's as far as traction goes.
post #6 of 24 Old 02-25-2010, 06:13 AM
km2jk's Avatar
They are tiny. Im considering going to 40's just to get close to a true 37". I love the grip, but they are borderline false advertisement when it comes to size.
TNT Customs
Genright
Poison Spyder
Or-Fab
River Raider
Mastercraft
Spod
M.O.R.E.
Goodyear
Diablosport
km2jk is offline
post #7 of 24 Old 02-25-2010, 12:43 PM
spillidge's Avatar
The only tires I have seen come close to the advertised size are Swampers.
You really need to check the specs closely to see the actaul "mounted" height.
spillidge is offline
post #8 of 24 Old 02-25-2010, 12:58 PM
terrahawk's Avatar
km2 37' are just a tad over 35"
post #9 of 24 Old 02-25-2010, 02:19 PM
N2rock's Avatar
315/75/16 calculates out to 34.6", so they are not very short actually. I bet if you do a dead accurate measurement, you'll find that they are within .5" of being accurate
N2rock is offline
post #10 of 24 Old 02-25-2010, 02:38 PM
desert dog's Avatar
My 35" KM2s are 34.25". My 33" Mickey Thompsons were 32".
Yep, swamper and Toyo seem to be the only ones that go true to advertised size (that I have seen).
desert dog is offline
post #11 of 24 Old 02-25-2010, 05:42 PM Thread Starter
Measured them from a level on top to the floor. Right at 34 inches. So fairly close to a half inch off.
Not that a 1/2" or so really matters one way or the other, just feels like we get shortchanged a bit.
seiken01 is offline
post #12 of 24 Old 02-25-2010, 06:04 PM
my 37 KM2's are almost 36"... site says 36.8
40s are 39.8
http://www.bfgoodrichtires.com/specs...-km2/3930.html
edit: if u look.. the bigger size rim.. the smaller the tire is gonna be..
07 2dr Rubicon - Teraflex 6" LA - 37 KM2's - LoD rear bumper - Rockhard front stubby - Poison Spyder Flares - etc.
upcoming: Front D60, 40's, beadlocks.
BiGEN is offline
post #13 of 24 Old 02-25-2010, 07:23 PM
spillidge's Avatar
The mounted size will also depend on the width of the rim you are using, a skinner wheel should produce a slightly taller tire.
post #14 of 24 Old 02-26-2010, 12:35 AM
JKDoc's Avatar
If you measure the circumference of your KM2 after it is mounted and on your Jeep and compute the diameter (a more accurate way to measure than trying to find the diameter), it gets worse. My "35s" measure 33.3 inch diameter mounted on an 8.5 inch wide rim. When programmed in with the AEV programmer, this size (actually 33.25 programmed as I remember) nails the speedometer with my GPS and speed calculation based on RPM. They work great. If taller, I could not get in my garage. So it all worked out for the best.
"Old age and treachery will overcome youth and skill", Bob Arnett
JKDoc is offline
post #15 of 24 Old 02-26-2010, 06:47 AM
garner's Avatar
Same experience here. My 35 KM2s mounted on stock Moab wheels after mounted and aired up measure 33.75. I think I may try the Goodyear MTRs w/kevlar.
2008 Rubicon Unlimited | Rescue Green | OME Long Travel HD Lift | Raceline Monster Beadlocks | 39.5 Irok Bias Tires| 5.13 Gears | PSC BFH Front Bumper | PSC Flares | PCS Crusher Corners |PSC Rock Brawler Rear w/tire carrier | Warn 9.5ti | ARB High Flow On Board Air | sPOD |Rock Hard Sport Cage | Poly High Steer Kit | Poly Front Track Bar Brace | Alloy Chromoly Rear Axle Shafts
garner is offline
post #16 of 24 Old 02-26-2010, 09:20 AM
N2rock's Avatar
Yup, my 315/75/16 KM2's required 33.25" programming to be accurate.
But of course it gets worse when mounted. You have the wheel pulling in the sidewall (decreasing the actual sidewall height) plus the weight of the vehicle bearing down on it. I suppose one could put max air into the tires to compensate for some of that, but then you would be riding on bricks
N2rock is offline
post #17 of 24 Old 02-26-2010, 09:21 AM
N2rock's Avatar
When you really think about it- 1/2" is actually only 1/4" less sidewall height.
N2rock is offline
post #18 of 24 Old 02-28-2010, 09:17 PM
Chris Hansen's Avatar
yeah....the true height of a tire is always less that it's design height. Your average 315/70r17 is about 34.6 inches.
sadly...as I am a dork...I have a tire size calculator on my palm pre, as is available for a lot of smart phones. You can not only calculate your tire size, but the gap in speedo estmates when upgrading to such tires.
Dirty's Minions don't officially exist. They are a myth, a bedtime story, a whispered rumor. They are ghosts.
Chris Hansen is offline
post #19 of 24 Old 03-01-2010, 07:55 AM
OlegRock's Avatar
Don't think anyone mentioned this but I think tire pressure makes a difference too ... We usually run around 26-30 psi instead of the suggested 50-60 psi
OlegRock is offline
post #20 of 24 Old 03-01-2010, 07:08 PM Thread Starter
Mounted, on the Jeep they are measuring around 33 1/2 to 33 5/8. Completely unscientific method of measuring from the ground to the top of the tire. So these are giving me an additional 1 inch of clearance over my half worn 33's.
However, they still look great. Now I need to get some time to get offroad and test them out
seiken01 is offline
post #21 of 24 Old 03-01-2010, 07:43 PM
johnmcd's Avatar
I just bought a new set of Goodyear MTR kevlars in 35 1250 17 on a 17x9 rim, I'll check them out. I had always heard teh BFG's were short.
Originally Posted by H.I.I.K View Post
Ok We need to organize a "Strippers and Blow Trail Run" It can raise money for college scholarships
Raleigh Meet and Greet,
Check the thread ------------->
johnmcd is offline
post #22 of 24 Old 03-01-2010, 07:47 PM
johnmcd's Avatar
Yup, 34.25" tall at 35psi. Maybe a little compensation for the load it would be better
johnmcd is offline
post #23 of 24 Old 03-05-2010, 02:32 AM
JKDoc's Avatar
The 50 psi rating is only for max load. If you follow a load inflation table we could get by just fine with 25 pounds or less. 30 seems to be a good comprimise between ride quality and fuel mileage. The tires on my motorhome are inflated to 95 psi cold inflation pressure. Just depends on your load.
JKDoc is offline
post #24 of 24 Old 03-05-2010, 02:53 AM
ADDICTION II build begins....
TXROCK's Avatar
with my previous JK 2 Door, ProComp Xtreme MTs 315x70x17s were 33.25 when mounted....anything over 35 pounds made you feel like you were riding on bricks like Terra mentioned!
With the 4 door, Coopers 35x12.5x17s measure a little over 34" and keep it under 35 pounds as well for road comfort as well.
U.S. Army
TXROCK is offline
