Rear Window Gap - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 02-21-2010, 07:50 AM Thread Starter
Heckdaddy's Avatar
Rear Window Gap
I have a 07 JK unlimited and for some reason there is about a 1.5 -2 " gap between the bottom of the zip up rear window and the tailgate. Any Ideas?
Heckdaddy is offline
post #2 of 6 Old 02-21-2010, 05:00 PM
TORN's Avatar
I would check that your clips on each end have not popped up and your bar is correctly inserted into them. I believe they came out with new clips in late '07. You can zip-tie them on to keep them from popping up. Hope that helps.
Who's pickin the banjo here?
TORN is offline
post #3 of 6 Old 02-21-2010, 06:17 PM
tkob1060's Avatar
I would say you are missing your tailgate bar that slides onto the bottom of the rear window and the clips that snap onto the bed rail that holds the bar. Did you buy the jeep used?
here is link to pic of one http://www.quadratec.com/products/11033_400.htm
here it is cheaper http://www.moparonlineparts.com/part...&siteid=214954
you also need the clips that hold it http://www.moparonlineparts.com/part...layCatalogid=0
tkob1060 is offline
post #4 of 6 Old 02-23-2010, 10:28 AM Thread Starter
Heckdaddy's Avatar
tkob, thank you so much this is it. I really appreciate the help on this one. Thanks again.
post #5 of 6 Old 02-23-2010, 03:19 PM
tkob1060's Avatar
you're welcome, that bar will slide onto the bottom of the rear window and clip into those clips to seal the back.
here is a video on how it works http://www.jeep.com/en/owners/soft_t...oft_top_guide/
tkob1060 is offline
post #6 of 6 Old 02-25-2010, 01:31 PM
My clips were crap. They would not stay connected to the tub if the soft top was on. The dealer replaced them with a newer model. I think there was a TSB on this.
quote by my lovely wife....
She'd be a lot cuter if you duct-taped her mouth shut.
dizug is offline
