Zipper sucks - JKowners.com : Jeep Wrangler JK Forum
post #1 of 30 Old 06-26-2009, 06:35 AM Thread Starter
Born2run's Avatar
Zipper sucks
Major problem with my back window zipper. Never wants to install correctly, it seems to be misaligned at the left side where the window starts. Thus it zips up but is a pain to remove. Sometimes it won't remove. With all the rain we have been getting I have been taking down the top when the sun finally comes out. Do I take it into the dealership and have them replace the top (still have the warranty) or try something else. Any suggestions. Just wanted to know if anyone else has this problem?
Born2run is offline
post #2 of 30 Old 06-26-2009, 06:48 AM
owtdorz's Avatar
Make sure it is clean and no vivible damage.
If it still does not work properly take it to your dealer.
We would replace it if it came to our dealer in AZ.
owtdorz is offline
post #3 of 30 Old 06-26-2009, 06:54 AM
dyolfknip's Avatar
Mine started doing the same thing....but it was the rear window teeth...they had started to push out of the stiching. Brought it into the deal and they got me a new rear window.
I had a friend who had the top sie of the teeth go and they put in a new zipper onto his top.
"And did you exchange a walk on part in the war for a lead role in a cage?"
dyolfknip is offline
post #4 of 30 Old 06-26-2009, 06:56 AM Thread Starter
Born2run's Avatar
Thanks. I will go back to the dealer.
Born2run is offline
post #5 of 30 Old 06-26-2009, 11:18 AM
If you lube the at least zippers once a month it'll help. After several FUBAR'd zippers on my CJ's figured it was better to keep em lubed. The jk rear is a PIA. I just roll mine up when the top is on.
mkjeep is offline
post #6 of 30 Old 06-26-2009, 03:33 PM
When I install the rear window, I do it with the top loose( not pull down tight). I always install the rear window before the side windows. With a little slack in the top, you're not trying to stretch the rear window and zipper to fit the opening. I tore up the zipper in my TJ and had to replace the top. I tried this method and the window zips in easy. After it's installed, I pull the latches down tight, then install the side windows.
2007 Rescue Green Rubicon Unlimited
4" Superlift with Bilsteins
37" Mickey Thompson Baja Radials with PSC Spyderlocks
5.13 Yukon Gears and Custom Driveshafts
Mopar Offroad Rear Bumper
Smittybilt Front Stubby with Warn 8000
PSC Rocker Nockers with PSC Body Armor
PSC Front Tube Fenders
KC Lights
AEV Procal Programmer
Powertank
Rockcrusher Diff Covers
1" PA Bodylift
Rockhard Evap Skid
Corbeau CR-1 seats
roketman is offline
post #7 of 30 Old 07-03-2009, 08:10 PM
thebigtman's Avatar
I sprayed WD40 on the teeth before I unzip them. After the second application, it really loosened things up and now it's working like it should.
The zipper/teeth were misaligned when I first unzipped it, which made for a helluva first time getting the rear window off.
thebigtman is offline
post #8 of 30 Old 08-11-2009, 09:43 PM
BadAzGirlsDriveBadAzToyz's Avatar
I totally have the same problem. That and my lack of patience with everything has ensured my rear window still has not been put back in place for a week now, rain and shine. I've got some zipper lube I'm going to try when I decided to tackle it again.
hehehe. lube
BadAzGirlsDriveBadAzToyz is offline
post #9 of 30 Old 08-11-2009, 09:55 PM
Speaking of the stuff I gotta lube mine up pretty soon. It's been a while and they aren't sliding around like they used to.
JaysJK is offline
post #10 of 30 Old 08-12-2009, 12:51 AM
paramaniac's Avatar
i have had problems since day one with mine... finally a few months ago, the zipper just plain fell apart. i have to get it to an auto upholsterer to have new zippers sewn on the top and the window!
paramaniac is offline
post #11 of 30 Old 08-12-2009, 08:28 AM
GPV
If you know of a local dive shop (or archery shop) they have a wax for lubing zippers on dry suits and such.
GPV is offline
post #12 of 30 Old 08-12-2009, 08:44 AM
My zipper has been stuck for probably 6 months. I tried it several times, wd40 and muscle and got nothing. So, i zip tied the sh*t out of it. Sucks, and looks like a$$,but functional. Well, by functional i mean, its together. doesnt zip or unzip. i just fold the top down and leave the rear window in place. It's sad. I didnt like the clips that lock it into place either, kept coming off. So i just dont keep anything valuable in the back anymore. because it fills with water. just pulled the drain plugs.
Gibson Headers&Duals,SUPERCHIPS,AFE Stage2Cold Air Intake,Poweraid Thrtl Bdy,4" RghCntry Susp,35" Nitto DUNE Grapplers! 18" ROCKSTAR Rims,"OH-SH*T" Grab Handles,RECON Edit Blk Out Lenses/w/LED's,GTO Smokd hdlight Cover,blk Grill Insrts,Tntd BugShield, Tinted Windw, RghCtry DualSteeringStabilizer,blk stl lckng fuel dr,BLK tail light Covers/guards,Quadratec Mud terrain floor matts,Rhino-line,blk diamond plate rocker guards, mirror relocator/light bracket,Hood Scoop, smittybilt seat covers!
macdougallusaf is offline
post #13 of 30 Old 08-12-2009, 08:49 AM
thebigtman's Avatar
If you're still under warranty, you should get it replaced if it's that bad.
post #14 of 30 Old 08-12-2009, 11:14 AM Thread Starter
Born2run's Avatar
hehehe. lube
Lube is good
Born2run is offline
post #15 of 30 Old 08-18-2009, 09:02 AM
usmcdoc14's Avatar
I placed white paint "dots" next to the ends on each half of the zipper when it was zipped up "correctly".
It is easy to get them misaligned and then zip it up that way. with the white dots you line those up and you know the zipper ends are good to go.
I also extended the zipper pulls by like 5 inches, who the retard was to make them that short needs to be slapped.
usmcdoc14 is offline
post #16 of 30 Old 08-18-2009, 01:36 PM
jkruss's Avatar
I just roll it up and leave it on when I put the top down,no problems
Black Jeep
jkruss is offline
post #17 of 30 Old 08-19-2009, 10:47 AM
X2 on that one
post #18 of 30 Old 09-14-2009, 07:30 AM
CalmerThanYouAre
sin52's Avatar
I use a small block of bee's wax on my zippers. same for my tents and mt harwear jacket.
I support the military, fiscal responsibility, Hemp, legalization of Marijuana over 21, smaller government and the Bill of Rights.
NSA: The only part of the government that actually listens.
sin52 is offline
post #19 of 30 Old 09-15-2009, 05:51 AM
Am I the only one that uses this..
Vote - Bacon for 2012!!!
benmar2000 is offline
post #20 of 30 Old 09-16-2009, 10:54 AM
joeglock's Avatar
Send a message via Yahoo to joeglock
Nope. it is the only thing the dealer ever gave, other than a migrain
joeglock is offline
post #21 of 30 Old 10-12-2009, 05:40 PM
BLACK08X's Avatar
My zipper is the same way. SUCKS! Also, the dealership that I bought the jeep from closed... so who do I go to now to get the top replaced? It's an '08 but it's still under warranty.
BLACK08X is offline
post #22 of 30 Old 11-15-2009, 06:16 AM
thissideup's Avatar
Wax your long board man..... Waxed mine when it started giving me problems and it loosened up and worked great.
07 silver Unlimited
513 gears
4 inch Teraflex lift
1.5 teraflex front spacers
16 inch rims
km2 35"
sadly sold her.
Need more parts
thissideup is offline
post #23 of 30 Old 11-16-2009, 05:18 AM
bubba2u's Avatar
hehehe. lube
i usually just spit on it and it slides easy
bubba2u is offline
post #24 of 30 Old 01-09-2010, 05:17 PM
LSM
LSM's Avatar
X2 I use it. Works OK, I guess. It still sticks on the top right corner.
ME
08 Rubicon Unlimited / জীপ্ Green / 6 Speed..
Mopar offroad bumper
Winch
Raider Evap Skid plate
Some mods to the bumper
It has started....
LSM is offline
post #25 of 30 Old 01-09-2010, 08:02 PM
mikeyfl's Avatar
i had an issue with my zipper once.
dont ask me how the bean got above the frank.
mikeyfl is offline
