20 Ton Press Brake DIY Builder Kit @ Swag Off Road - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 03-14-2013, 03:20 PM Thread Starter
Swag Off Road's Avatar
20 Ton Press Brake DIY Builder Kit, Bend Steel With Your Hydraulic Press
Press Brake kit comes unassembled, you do the final assembly and welding.
Designed to fit the Harbor Freight 20 ton hydraulic press Item # 32879. or the Harbor Freight 12 ton hydraulic press Item # 33497.
Press Brake includes adjustable back stop and side top for accurate repeatable bends.
Max Bending Radius (deg.) 110
Max. Bending Capacity 5/8" plate
Max Bending Width 19.25"
Tools required for assembly, welder, grinder, level, small square.
Our HEAVY DUTY kit Is capable of bending mild steel in the following length and thickness.
19" = Full bending width of the bottom die on anything 3/16" or thinner.
15" in 1/4"
13" in 5/16"
11" in 3/8"
6" in 1/2"
3" in 5/8"
Our STANDARD DUTY kit Is capable of bending mild steel in the following length and thickness.
19" = Full bending width of the bottom die on anything 1/8" or thinner.
15" in 3/16"
12" in 1/4"
5" in 3/8
The DIY builder kit includes the following parts:
Press brake base plate
Side stop
Back stop
Top machined die
Bottom die
Back stop guide rails
Top die guide rail rod
Top die guide rail DOM tubing
Top die ram center 1.75" dia tubing
(2) 3" threaded rods
(2) Shaft collar locks
(2) Springs
Misc fasteners
Detailed Instructions
The DIY 20 ton press makes a great addition to the arbor press plates we sell HERE
Click here to view Youtube demo video.
SWAG Off Road 20 TON Press Brake DIY Builder Kit - YouTube
The kit can be purchased HERE
Free shipping, how it this possible? We recently produced a new box that allows us to fit the 12 and 20 ton press brake kits into a large flat rate USPS shipping box.
We wrapped up the cost of shipping in the purchase price of the kit as our website shipping calculator has no idea how we can transport up to 56 lbs from Oregon to New York for $20.00. Upon check out please provide an address that USPS delivers too.
Thanks Troy
Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's.
Visit us on
Swag Off Road is offline
post #2 of 16 Old 03-14-2013, 03:28 PM Thread Starter
If you are on the fence because you don't have a Harbor Freight 20 Ton Press. We just received a coupon in the mail today good until the end of the month.
Troy
Visit us on
post #3 of 16 Old 03-20-2013, 01:09 PM Thread Starter
Take a look at the latest edition that will soon be an option up on our website very soon.
The top half is backwards compatible for all of you that have either the standard or HD press brake kits currently on the website.
Details will be posted soon.
SWAG
Visit us on
post #4 of 16 Old 04-10-2013, 10:48 AM Thread Starter
We often get asked what is the difference between out standard press brake kit and the HD press brake kit.
The main difference on the standard and HD press kits are the thickness of the bottom steel frame and the width of the bottom die .
The standard press brake kit is made up of 1/4" steel with a bottom die width of 2.0" the HD press brake kit is made up of 3/8" steel with a bottom die width of 4.0".
The HD kit can effectively bend twice as thick of material in the same width as the standard press brake kit, or another way of looking at it is the same thickness of material just twice as long as the standard kit. Keep in mind that the bend radius of the standard kit is 3/8" as opposed to 5/8" of the HD kit.
The neat feature about the HD press brake kit is you can always stack smaller pieces of angle iron in the bottom die to make it "adjustable" to allow for different bend radius's.
We have these in stock ready to ship out in the mail today.
Thanks for the orders.
Troy
Visit us on
post #5 of 16 Old 05-07-2013, 04:17 PM Thread Starter
If your into metal fabrication they you know the value of good tooling. Next time you stick a piece of metal in a bench vice and beat on it with a hammer to make your next bracket or tab think of us.
Thanks SWAG
Visit us on
post #6 of 16 Old 06-04-2013, 08:30 AM Thread Starter
We just launched our latest Youtube demo video of the SWAG Finger Press Brake Kit, check it out.
SWAG Off Road Press Brake Finger Brake Kit Demo Video - YouTube
Visit us on
post #7 of 16 Old 06-18-2013, 02:40 PM Thread Starter
*New Product*
20 TON Finger Brake Gooseneck Dies
Are you looking to increase the bending capabilities of your SWAG finger press brake kit?
The SWAG gooseneck dies are laser cut at 85 to allow for air bending. These punches are used for forming right angle bends, channels, or other special bends where our straight 90 punch would cause interference and limit your bending options.
If you have used your press brake for any "special" projects you have ran into the limitations of the straight segmented fingers. These limitations become apparent when bending shallow pans or forming complex "U" bends. For this reason, we have laser cut 24 individual pieces of 1/2" plate that can be stacked in line or welded together to suite your particular needs. When fully assembled and stacked in line you will have a 12" long goose neck bending top die.
The SWAG finger brake gooseneck dies are able to bend up to 1/4" thick material.
http://www.swagoffroad.com/Finger-Br...ies_p_120.html
post #8 of 16 Old 07-23-2013, 11:54 AM Thread Starter
Your fabrication skills are only as good as the tools you own.
Let us know if you have any questions.
Troy
Visit us on
post #9 of 16 Old 08-26-2013, 09:45 PM Thread Starter
If it looks like you bend metal with a big hammer and a bench vise then take a look at our DIY press brake kits.
In stock ready to ship out in the mail today.
Troy
Visit us on
post #10 of 16 Old 10-02-2013, 09:57 AM Thread Starter
Put down the big hammer and give us a call, it's about time you upgrade the quality of your fabrication tools?
In stock ready to rock.
Swag
Visit us on
post #11 of 16 Old 12-10-2013, 09:57 AM Thread Starter
If your looking for a great gift for the tool lover in your family, we can still get these out in the mail and delivered to your door step before Christmas.
We have every Portaband table in stock ready to ship out in the mail today.
SWAG
http://www.swagoffroad.com/SWAG-Port...les-_c_35.html
Visit us on
post #12 of 16 Old 02-13-2014, 01:14 PM Thread Starter
In the latest add out by Harbor Freight they have the 20 ton hydraulic press for $150.00, stack the 25% off coupon on top of that and you have a good press for $112.50. That is a great price for a good tool to add to your collection.
Thanks for the orders on our DIY press brake kits.
Troy
Visit us on
post #13 of 16 Old 02-13-2014, 08:57 PM
Troy
Did that in december and purchased your kit. You really cant beat it!!!
PartySnake is offline
post #14 of 16 Old 02-26-2014, 07:22 AM Thread Starter
Originally Posted by PartySnake View Post
Did that in December and purchased your kit. You really cant beat it!!!
Thanks again for the orders and I hope the kit is allowing you to create the one off fabricated parts you need in your garage.
Troy
Visit us on
post #15 of 16 Old 03-02-2015, 07:29 AM Thread Starter
If you looking for a great addition to your shop be sure to check out our 20 ton press brake kit that is designed to fit inside the Harbor Freight 20 ton press.
We have everything on our website in stock. Let us know if you have any questions about the products we sell.
Thanks again for the orders.
Troy
http://www.swagoffroad.com/SWAG-Pres...Kits_c_53.html
Visit us on
post #16 of 16 Old 09-03-2015, 09:41 AM Thread Starter
Visit us on
You may not post new threads
