Hard shifting from 1st to 2nd - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 01-16-2009, 08:12 PM Thread Starter
So my 07 X, New to me, but has 15000 miles on it. Ive had it just about a week now. And when i shift from first into second gear its like the shifter hits something and clicks in to gear. Doesnt grind, but feels like it is trying to get by some obstruction. Doesnt happen with any of the other gears. Still under warranty, but i need to know if this is just a normal little thing or what?
Any help is greatly appreciated
bunkrdfool is offline
post #2 of 7 Old 01-16-2009, 08:40 PM
gt3073b's Avatar
Does it go away once it warms up? It seems that most or all of the 6-speeds are a little rough going into second until it warms up. The synchronizers don't work as well when the tranny fluid is cold and thick. Just go easy on the shifting and don't crank on the stick until it warms up.
Bryan.
2007 JK Rubicon Unlimited Rescue Green 6 Speed
Mods Shrockworks Rails & Bumpers, Currie Lift, Tom Woods 1310/1350, 36-13.50 Bias Iroks on HMMWV 12 Bolts (play tires), 35" Toyo M/Ts on ProComp 7028s
In Progress
To Do Co4Lo suggested Grade Eleventy bolts for my new bumper flag mounting bracket
gt3073b is offline
post #3 of 7 Old 01-16-2009, 08:49 PM Thread Starter
It doesnt get THAT much better when its warmed up.... but i dont really drive it for like 30 mins either ... and its been like 10 degrees out for a high here the past week, so the tranny getting warm is almost out of the question. I dont beat on it either. If it becomes a big problem i might just take it to the dealer and see whats up
post #4 of 7 Old 01-16-2009, 08:49 PM
StubEXrube's Avatar
never had this problem with my manual, even when cold. have heard of similar situations though. I might check into the tsb bin on this one, to see if there is one relating to it. jmo
like stated...may be related to the synchro.
StubEXrube is offline
post #5 of 7 Old 01-16-2009, 09:15 PM Thread Starter
No tsb's already looked. Might just have the dealer take a peek
post #6 of 7 Old 01-17-2009, 07:46 AM
USAntigoon's Avatar
First and second are triple cone synchronizers and will drag somewhat with a colder oil environment.. Also keep in mind that the detent spring load might be higher in the 1-2 rail, combined with more coupler teeth backtaper because of higher torque transfers hence avoiding gear jump out..
A lot of technical crap to say that this hard 1-2 shift is somewhat inherent for manual transmissions...
USAntigoon
USAntigoon is offline
post #7 of 7 Old 01-20-2009, 08:45 PM
I have a 2007 Unlimited JK it does the same thing so if you take it to the dealership let us know what they say. Cause I'm thinking about doing the same thing.
timbo is offline
