BB vs. Spring Lift vs. Shock Lift - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 01-16-2009, 12:19 PM Thread Starter
Gordon2's Avatar
I have an '08 JK Unlimited X with 3.73 gears. I know I want to put 35's on eventually, but will be running stock tires/wheels for a while. I mainly use on highway and around town, about 15-20K per year. I normally do about 40K per year on my other truck(daily driver).
I dont know what to do and am seriously confused by all the options.
I narrowed down a little, but all help would be appreciated.
TF: 2.5" BB with shocks $409.99
2.5" BB with shock adapters & springs $436.99
Skyjacker: 2.5" with Shocks & Springs $451.99
2.5" Spacers, stops, Shocks $259.99
Help!
"Hope for the best, but expect the worst. You will never be disappointed." ME
'08 Unlimited X - Stone White - Hardtop - Auto - 3.73 Gears - 17's - 3" Fabtech
Gordon2 is offline
post #2 of 3 Old 01-16-2009, 02:24 PM
TEEJ's Avatar
Talking
Well, if you don't go off road...and its just to fit 35', do a 2" BL and you will have no worries.
A BL is to fit larger tires.
A suspension lift is to raise the frame.
The suspension lifts can be confusing, but, just try to remember that they all do the same thing...they make the distance between the drivetrain and frame longer.
It doesn't matter what brand, style, etc...that's what they do.
If one includes a part the others don't, like a longer or adjustable track bar...it doesn't mean only that kit NEEDS one, it means that that kit COMPENSATES for the axle shift that ALL lifts MUST produce....and the other's do not.
If its an OPINION by one maker that you need that compensation, vs not needing it...that doesn't change the physics.
(Needing can be subjective...axle shift is not subjective, how far is TOO far IS subjective)
So - ALL lifts that lift you 2.5" will shift the axle by the EXACT SAME AMOUNT, etc.
If one kit compensates by using a new bracket, or a new bar, etc...then you can compare which solution might be better/the best value, or whatever your priorities are.
If you want more wheel travel, and better handling, to compensate for the taller center of gravity you get with a lift, then, new, longer and properly valved shocks will be better than a shock extension....and a shock extension will be better than leaving the stock shocks as is, etc.
A coil spacer gives the same lift as a longer coil...but might not compress as short, and might not have the best spring rate considering the potentially new shocks and their valving, the new, heavier tires and their weight, and the higher center of gravity, etc.
And so forth.
The suspension lift only increases the ride height...so, on road, and under most conditions, the tires clear....but under compression, they can hit what ever they would have w/o a lift.
The Body Lift just raises the body, so the COG stays about stock, and the tires have the same clearance as with an equivalent SL, except that that clearance doesn't dissapear when you go over a bump.
Its also cheaper.
If off roading enough to matter...the SL gives room for a more flexible suspension and other advantages, like ground clearance.
Larger tires give ground clearance too though, and ONLY larger tires will pick up the ENTIRE truck, axles and all.
Food for thought.
- TEEJ
2008 JK 4 Dr X. 5 Speed, LSD, JKS QD, 3.73 Diffs. Husky Liners and Daystar Hood Wranglers. Pine Stripes.
TEEJ is offline
post #3 of 3 Old 01-16-2009, 03:16 PM
TeraFlex's Avatar
Yes, with the one notation--not all kits named "2.5" lift" will lift exactly 2.5". (at least spring lifts vary, spacers should be the same...)
Which is why more complete lift kits will include bumpstop spacers or equivalent, so the amount of uptravel remains generally the same as stock, so the axle won't be able to compress as far, keeping those bigger tires out of the body/fenders.
Nice informative answer post there, TEEJ.
1-888-837-2359
TeraFlex never left the market or the trail.
TeraFlex is offline
