***NEW*** Fox 2.0 Performance Series ATS Stabilizer - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > Approved Vendor's Showcase > Poly Performance
Old 04-18-2013, 09:03 PM   #1
PIG
PIG's Avatar
Member # 119
Fox 2.0 Performance Series ATS Stabilizer for Jeep Wrangler JK
Description:
The FOX Performance Series Adjustable Through Shaft (ATS) steering stabilizer offers unrivaled steering control and a striking high tech appearance. The technologically advanced design cancels unwanted steering forces in both directions, taking the place of two conventional opposing stabilizers. It will also respond to your input with 24 clicks of external adjustment to fine tune the feel. The integrated reservoir allows for additional fluid capacity and improves cooling during extreme use. Also included is FOX's relocating hardware that moves the steering stabilizer up and out of the way. The ATS represents a revolutionary breakthrough in stabilizer design.
Specifications:
Body - Aluminum shock body dissipates heat three times faster than steel
Components - Black anodized 6061-T6 billet aluminum
Shaft - 5/8" hard chrome plated heat treated alloy steel
Piston - Race-developed high-flow piston design
Valving - Proprietary deburred valve shims
Seals - Redundant sealing pack system main seal, wiper seal, scraper seal
Oil - Specially formulated for ultimate performance at variable temperatures
Reservoir - External reservoir design separates shock oil from the high-pressure nitrogen
Mounting - Applications available for stock and aftermarket lifts kits
Adjustments:
-Nitrogen Pressure Adjuster
-24 Clicks of Adjustability
CLICK HERE FOR PURCHASING INFO.
__________________
USE CODE: JKOWNERS FOR 10% SAVINGS ON YOUR NEXT ORDER!!!
PIG is offline   Reply With Quote Quick reply to this message
Old 04-19-2013, 08:28 AM   #2
Busa Dave
Busa Dave's Avatar
Member # 28031
I had one put on my 13 last month when the AEV lift was installed---Very nice esp to be able to do the fine tune!!
__________________
2013 Rubicon
2014 Denali 6.2L
NRA Life Member
Busa Dave is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
