Ox Locker installed - JKowners.com : Jeep Wrangler JK Forum
Old 05-03-2009, 05:16 PM   #1
N2rock
N2rock's Avatar
Member # 1458
Ox Locker installed
Easily the most expensive mod I've done to date:
Ox locker- $900
Locker cable (125")- $140
diff overhaul kit (bearings/races/bolts)- $200
River Raider shifter mounting bracket- $50
Labor- $200 + 6 Red Bull energy drinks
Machine shop (details below)- two cases of Bud Light
According to Ox, the only other JK version out there is on River Raider's 2dr. So I guess that makes me the guinea pig for the 4dr's
No need to go into details on the assembly and install of the Ox as the Ox instructions are pretty straight forward click here for Ox Instructions- warning, large pdf file!
there is only one problem with the Ox instructions: on page #3, step #6- It appears that you simply screw the cable end into the cover. However you can only screw the cable so far before it disappears into the shift fork. Once the cable is in there, you have no way to hold on to it in order to screw it in further. And at that point, it is only about 1/2 way from where it needs to be. Took quite some time to figure out that you have to remove 2 c-clips that are holding the fork, then unscrew the fork assembly from the diff cover. Once all of that is removed, you can then screw the cable the remainder of the way that is necessary.
Rear opened up and getting ready to start working
Introducing the Ox to my ring gear
Then the BIG problem hit. Some '07 models D44's have 1/2" ring gear bolts. instead of 7/16" ring gear bolts. Well of course Murphy's Law- mine has the 1/2" bolts, and the Ox holes were made for 7/16" bolts. I thought my day was shot right there. There is no way possible a drill press is going to drill larger holes in that Ox- that steel is seriously hardened. Lucky for me, there is a machine shop right behind RockRash4x4's shop, and a couple guys were there working on stuff. George talked to them and they helped us out. Did I mention that the steel is hardened? It took them 3 HOURS and they destroyed 2 endmill bits (I think that's what those bits are called??) drilling out the holes for me. Payment was 2 cases of beer- can't beat that!
I won't bore you with the details of routing the cable. Anyone that is interested in seeing the cable run, I will post a reply with clickable thumbnails:
Cable routed, and shifter mounted- notice the RockRash4x4 custom touch- he powder coated the shifter nob black, but left the knurled portion of the nob un-coated (I love the look). He also powder coated the shifter plate (where the X and O are), then grinded off the powder coating leaving just the X and O in black- a really nice touch IMHO.
Finished - I can't wait to try it out!
And while RockRash was busy with the technical stuff, I was busy with the non-technical: I painted my jerry can holders black, painted the jerry cans olive drab, and painted my muffler high-temp black
__________________
check out: http://n2rock.com
jk-forum, jk forum, jkforum, jeep jk wrangler, Jeep Wrangler Unlimited JK, Rubicon, Sahara, X, Sport
N2rock is offline   Reply With Quote
Old 05-03-2009, 05:17 PM   #2
N2rock
N2rock's Avatar
Member # 1458
thumbnails for cable routing pictures
__________________
Old 05-03-2009, 05:57 PM   #3
Mr.RonGilbert
Mr.RonGilbert's Avatar
Member # 3399
It's official.... you suck!
My OX is going to have to stay out in the pasture for a little while longer, I have to put a new set of rubber on the freakin camper and buy a $700 set of ramps... soon though...soon.
Nice job on the install Geo.
Mr.RonGilbert is offline   Reply With Quote
Old 05-03-2009, 06:08 PM   #4
Riverkid
Suuuure you can...
Riverkid's Avatar
Member # 1955
Badass install thread. How does it work?
Riverkid is offline   Reply With Quote
Old 05-04-2009, 04:44 AM   #5
Mudinyeri
Mudinyeri's Avatar
Member # 2831
Nice writeup. I'm considering OX lockers. How smoothly does the cable shifter operate?
Mudinyeri is offline   Reply With Quote
Old 05-04-2009, 06:16 AM   #6
Paul08Wrangler
Paul08Wrangler's Avatar
Member # 1390
WOW, for that kind of money, you could have bought a WHOLE New Rubi Diff from cali, with electric lockers tooooo....
Paul08Wrangler is offline   Reply With Quote
Old 05-04-2009, 08:05 AM   #7
N2rock
N2rock's Avatar
Member # 1458
Yeah- Except YOU never told me about that deal! I found out from George about it after it was already too late!!!
__________________
Old 05-04-2009, 08:08 AM   #8
N2rock
N2rock's Avatar
Member # 1458
Very smooth.
__________________
Old 05-04-2009, 08:18 AM   #9
Paul08Wrangler
Member # 1390
Didn't know that the Ox was that much either. Besides you didn't ask
Old 05-04-2009, 08:21 AM   #10
SDMF
Openly Hostile
Member # 1231
I'd only be worried about knocking the cable off. But I have a habit of backing up into boulders and smashing my shocks.
__________________
Jason
SDMF is offline   Reply With Quote
Old 05-04-2009, 11:19 AM   #11
RDM Offroad
RDM Offroad's Avatar
Member # 3340
Looks pretty good! What length cable did you end up using?
***Edit***
Read the OP again, I see it now.
$900 for the locker and $140 for the cable seems pretty steep.
__________________
JKOWNERS Member Discount Available at:
RDM Offroad - Let Nothing Stop You!
Click the link to automatically apply the current offer!
(909) 599-8706
Follow us on: Facebook Twitter
RDM Offroad is offline   Reply With Quote
Old 05-04-2009, 11:19 AM   #12
N2rock
N2rock's Avatar
Member # 1458
I hear ya.
I asked Ox about breaking the cable. Was told that the locker by default goes open. So if the cable happened to get pinched while locked, simply cutting the cable will unlock. Was also told there is a way to lock it with a busted cable. I'm not sure how, and have asked them for details.
__________________
Old 05-04-2009, 11:29 AM   #13
terrahawk
terrahawk's Avatar
Member # 938
Just strap Hunter under there and make him hold the cable!
__________________
terrahawk is offline   Reply With Quote
Old 05-04-2009, 12:04 PM   #14
SDMF
Openly Hostile
Member # 1231
I hear ya.
That's good to know. Hopefully you don't have to find out, that cable will get expensive really quick it you have to keep replacing it.
__________________
Jason
Old 05-04-2009, 12:06 PM   #15
N2rock
N2rock's Avatar
Member # 1458
no doubt
I figure the odds would be about the same as breaking an air line with an ARB. Though the air line would be less expensive to replace. But the flip-side is that the OX could still be locked/unlocked even with a broken cable.
__________________
Old 05-04-2009, 12:14 PM   #16
SDMF
Openly Hostile
Member # 1231
no doubt
Very true, broken air line, leaky air lines...nothing is ever trouble free.
__________________
Jason
Old 05-04-2009, 12:35 PM   #17
redneckhouston
Member # 1467
I hear ya.
a 1/4-28 bolt about 4inches long with a stack of washers could be threaded in from the outside of the cover to engage the shift fork and lock it up
redneckhouston is offline   Reply With Quote
Old 05-04-2009, 03:42 PM   #18
Mudinyeri
Mudinyeri's Avatar
Member # 2831
The OX really isn't that expensive when you compare it to an ARB and consider that you need an air source of some type for the ARB. Two OX cables roughly equal the cost of the Power Tank Jet Pack.
Old 05-04-2009, 04:05 PM   #19
N2rock
N2rock's Avatar
Member # 1458
Yeah I considered the two system just about even in price. Until I found out that the OX does not include new bearings, races and bolts. And the ARB does. The Superior Gears overhaul kit cost me $200. So you need to add that into the equation.
Now if I had had to pay for the machine shop time to drill out the holes, that would've easily been another $100 or more.
__________________
Old 05-04-2009, 04:40 PM   #20
RDM Offroad
Member # 3340
The cool thing with the OX is that you can now choose the actuating method. Manual with the cable, air solenoid, or an electric actuator.
__________________
(909) 599-8706
Old 05-06-2009, 02:32 PM   #21
N2rock
N2rock's Avatar
Member # 1458
OK- here's what Ox told me about it- it is one run-on sentence so I'm having trouble deciphering what he says. See if you can make sense of this:
Purchase a 5/8-18 set screw drill and tap a 1/4-28 for a long bolt when you thread in the 1/4-28 it will push in the fork use a 1/4-28 jam nut to keep it locked in
Sounds like he's saying the same as you, but I'm not following the "Purchase a 5/8-18 set screw drill and tap..." part of it.
__________________
Old 05-06-2009, 02:41 PM   #22
Matt
Matt's Avatar
Member # 1507
the "5/8 set screw" is kind of like a diff cover fill plug.
That threads into the OX cover, drill and tap a hole in it for the 1/4" bolt to thread into. Use the 1/4" nut as a jamb nut to keep the 1/4" bolt from backing out of the 5/8" plug.
Do You know if they changed the cable type at all over the years?
A friend of Mine installed OX's in His TJ when they first came out. He had a lot of problems with the cables stretching and not engauging the locker. He adjusted them over and over and they never stayed adjusted. Eventually He switched to ARB's.
I hope they changed some stuff and You dont have any problems!!
Matt is offline   Reply With Quote
Old 05-06-2009, 02:55 PM   #23
N2rock
N2rock's Avatar
Member # 1458
Ah! Now it makes sense! Thanks. Now I just need to get Redneckhouston to build me the "emergency locker"
They changed the shifter- this website discusses the new shifter and how it cures the old adjustment issue: http://demon4x4.com/Tech/oxs.htm
__________________
Old 05-06-2009, 03:03 PM   #24
Matt
Matt's Avatar
Member # 1507
Good to hear!!
I figured they would have changed something by now.
Old 03-20-2010, 07:31 AM   #25
Big Chris
Big Chris's Avatar
Member # 399
Any updates on how the Locker is holding up? I am getting ready to install mine.
__________________
Big Chris is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
