My hidden winch in stock bumper - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Write Up Dept. (The Library)
Old 01-07-2013, 02:04 PM   #1
troyboy
troyboy's Avatar
Member # 8830
I won't take credit for the idea and you have probably seen it from others already but I couldn't find the thread. Here is my take on it:
This is the pre-fit before I weld the fairlead spacer onto the winch plate. I think the winch plate is just a flat TJ winch plate that I cut down a bit.
Here is the winch plate with the fairlead spacer welded on. I think it was 3" wide as I recall.
Another pre-fit. Notice the v-slots I had to cut in the bumper mount. This is so I could slip a wrench in.
Primer:
Finally bolted on and painted. I used just flat paint for the bumper mount and painted the winch plate with bedliner.
Cut the bumper metal and plastic:
Here it is with the bumper back on:
This shows the winch below. Notice the two cuts:
And the finished product:
troyboy is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 02:26 PM   #2
Asmmns
Asmmns's Avatar
Member # 12483
Nice !
__________________
__________________
CURE SMA !
Asmmns is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 03:23 PM   #3
SIKJEEP
SIKJEEP's Avatar
Member # 3005
Awesome
__________________
2015 JK Unlimited Anvil
SOLD -2009 JK Unlimited Rubicon Deep Water Blue
1987 YJ Stretched 60/14 40" LTB's
SIKJEEP is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 03:25 PM   #4
Apt
I Put the FU in FUN
Apt's Avatar
Member # 15684
Nice work!
Apt is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 03:30 PM   #5
TJDukit
TJDukit's Avatar
Member # 18730
Very clean.
__________________
'09 JKUR. Metal Cloak overlines, TF 3" LA, 35" Nitto Trail Grapplers, Home built winch bumper, custom built sliders, RK Drag Link and HD Pro Tie rod, Adams front shaft, TF Big Brakes, Speed Bumps, Warn M8000
I.Y.A.A.Y.A.S.
TJDukit is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 03:43 PM   #6
troyboy
troyboy's Avatar
Member # 8830
Oh I forgot to add a couple of pics:
I added a 500 amp in-line fuse, a 500amp relay to allow me to switch off the power from the cab and I moved the main winch relay into the engine compartment:
Old 01-07-2013, 03:52 PM   #7
4x4x4
4x4x4's Avatar
Member # 6912
Like
__________________
Army 13B enlisted & 15B officer MΟΛΩΝ ΛΑΒΕ NRA Life Member /
Detroit/Aussie,Sport Cage,4.5 lift, some welds...
4x4x4 is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 04:01 PM   #8
J1000
J1000's Avatar
Member # 24056
Awesome! Nice work.
J1000 is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 05:47 PM   #9
DisaMent
DisaMent's Avatar
Member # 20992
Very nice work.
__________________
Disabled & Mental
U.S. Army Veteran
DisaMent is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 05:51 PM   #10
dmhines
dmhines's Avatar
Member # 4079
Nice ... I like stealth accessories. Hiding winches like that makes it tough to get a neat wind. I guess with the synthetic line a neat wind isn't as important as it is with steel cable.
__________________
2009 JK - 2DR - 6SPD - 1/2 Doors
4.88 G2 Gears / Warn XD9000i / Custom bumpers & Swing Gate
XRC Rock Rails / 35" Kumho's on Black Rock Vipers
2.5" Mutt Lift / Rubicon T-Case / E-DISCO / VIAIR OBA
Rear CV Driveshaft / Rear Detroit Locker / Front Aussie
Teraflex Sleeves / Gussets / Nitro Chromoly Axles
dmhines is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 06:32 PM   #11
Thisguyhasadd42
Thisguyhasadd42's Avatar
Member # 16578
looks good, now make it a stubby
__________________
2010 Mango 2dr 6spd Rubicon
Thisguyhasadd42 is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 06:50 PM   #12
Goodysgotacuda
Goodysgotacuda's Avatar
Member # 4538
Nice work, I hate to ask what that 500a relay and fuse cost.[ I assume you have a spare fuse or two?
__________________
Goodysgotacuda is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 07:03 PM   #13
troyboy
troyboy's Avatar
Member # 8830
Oh I've been thinking about it
Old 01-07-2013, 07:05 PM   #14
troyboy
troyboy's Avatar
Member # 8830
Thanks, I can't remember the costs anymore but ya the relay ain't cheap. I do have another fuse too. Fortunately I haven't needed it yet but I haven't really put much use on the winch yet.
Old 01-07-2013, 07:07 PM   #15
troyboy
troyboy's Avatar
Member # 8830
Actually I haven't found it that hard to wind up at all. It's a synthetic line and I just keep a tight pull on it when winding it in.
Old 01-07-2013, 07:14 PM   #16
ratroder
the guy with the hair
ratroder's Avatar
Member # 19972
I like it. Very nice job.
__________________
Jersey
Crew
Have fun but use your head, not a flat bed! - Unsub.
Wise men talk because they have something to say; Fools talk because they have to say something.
ratroder is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 07:15 PM   #17
07unlimitedx
07unlimitedx's Avatar
Member # 2682
Wow nice clean work!
__________________
07unlimitedx is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 09:08 PM   #18
THEBOSSF350
THEBOSSF350's Avatar
Member # 17892
Nice job vary clean
THEBOSSF350 is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 09:12 PM   #19
Nomadr
Nomadr's Avatar
Member # 15547
Well done! Looks great.
__________________
2011 Unlimited Rubicon
Currently: Aurora, Co
Nomadr is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 09:35 PM   #20
Justin67
Member # 17946
Very nice! Now come do mine!
__________________
08' Rubicon unlimited, white
Justin67 is offline   Reply With Quote Quick reply to this message
Old 04-04-2013, 09:38 PM   #21
AWOL
AWOL's Avatar
Member # 27259
Perfect! Nice work on the mount! This is on my short list for the next couple weeks. Exactly the write up I was looking for.
__________________
-Living the dream - Didn't say it was mine-
AWOL is offline   Reply With Quote Quick reply to this message
Old 04-04-2013, 10:05 PM   #22
warcop
warcop's Avatar
Member # 26282
One more reason why I should learn how to weld. Looks great.
__________________
Warcop
2012 JKU Sport, Rock Krawler 2.5 Flex, Smittybilt SRC Side Armor, Mesh Grille MOD, Sony Double DIN AV Receiver, Back up Camera, Kicker Speaker Upgrade, VIAR 300P, Dominion Off Road High Lift Mount, Homemade Paracord Grab Handles, Nitto Trail Grapplers, Paramount Rear Bumper with Tire Carrier, KC Hilites Daylighters, under seat lock box, Metal Cloak Front Bumper, BARTACT Seat Covers, BARTACT Sun Shade, x20 Comp Winch, and sPOD.
warcop is offline   Reply With Quote Quick reply to this message
Old 04-04-2013, 10:24 PM   #23
TYDFAN
TYDFAN's Avatar
Member # 20683
I might have missed it, I HAVE been drinking, but I don't think any welding was involved. hiccup
__________________
2007 Sahara Unlimited - auto - Daystar - RC - Fox - Yukon 4.88 - 315/70/17 WildPeaks - Artec Axle Armor - Synergy - Rock Krawler - PSC
TYDFAN is offline   Reply With Quote Quick reply to this message
Old 04-07-2013, 07:37 PM   #24
crawlin_archer
Member # 27147
Yeah the drinks got to you I think. He welded a spacer for the fairlead on. I like the whole deal being hidden & stock looking. Looks good. Have you used it since install? Just wondering how the fairlead spacer will hold up to a heavy pull at an angle. Hope it's fine cause I like that set-up a lot. Good job.
__________________
Contact me for a true HID retrofit for your JK
crawlin_archer is offline   Reply With Quote Quick reply to this message
Old 07-18-2013, 07:26 AM   #25
KPM171
KPM171's Avatar
Member # 26705
Thumbs up
Very clean. Nice work!
__________________
6-Spd, 4.10's, Arb Bull Bar, XRC X20 Winch, sPOD, IPF Floods, onboard-air, & way more comfortable than a Wrangler has any business being!
Retired but never forgotten
2005 Wrangler TJ
KPM171 is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
