Knock Sensor - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Stock JK Tech Dept.
Old 01-07-2013, 05:00 AM   #1
hellionss
hellionss's Avatar
Member # 6992
Knock Sensor
I just replaced my clutch (with stock replacement) and now I get a MIL light. When I do the key trick I get no code, but if I pull the code with my flashpaq I get 0325 Knock Sensor curcuit one. This is on an 07 Rubi. Any guidance would be appreciated.
hellionss is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 09:20 AM   #2
ronjenx
ronjenx's Avatar
Member # 10975
The knock sensor is located on the right side of engine block, to the rear of right engine mount.
P0325-KNOCK SENSOR 1 CIRCUIT
When Monitored:
This monitor runs above 2000 rpm, under open throttle conditions. The Knock diagnostic does not run at idle or during decelerations. The high voltage test runs all the times the engine is running.
Set Condition:
The PCM detects the Knock Sensor voltage out of limits. Two Trip Fault. Three good trips to turn off the MIL.
Possible Causes
KS SIGNAL CIRCUIT SHORTED TO VOLTAGE
KS SIGNAL CIRCUIT OPEN
KS RETURN CIRCUIT OPEN
KS SIGNAL CIRCUIT SHORTED TO THE (K942) KS RETURN CIRCUIT
KS SIGNAL CIRCUIT SHORTED TO GROUND
KNOCK SENSOR
POWERTRAIN CONTROL MODULE (PCM)
__________________
2008 Unlimited Rubicon Automatic
ronjenx is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 09:27 AM   #3
hellionss
hellionss's Avatar
Member # 6992
Excellent information. Thank you. I will test and report back. Wish me luck.
Old 01-07-2013, 12:00 PM   #4
hellionss
hellionss's Avatar
Member # 6992
Does anyone know what kind of voltage readings I should be getting from my knock sensor?
Old 01-08-2013, 09:36 AM   #5
hellionss
hellionss's Avatar
Member # 6992
I am able to read voltage and ignition retard on the superchips. Foes anyone know what kind of numbers I should be seeing?
Old 01-10-2013, 04:15 AM   #6
hellionss
hellionss's Avatar
Member # 6992
I checked the voltage at the knock sensor above 2000 RPMS and it seems to decrease drastically. Is this normal? What range should I be looking for? Is this decrease of voltage a sign of a bad knock sensor or something else? I looked the wiring over and can not find any sort of shorts or anything.
Old 01-10-2013, 10:04 AM   #7
ronjenx
ronjenx's Avatar
Member # 10975
I couldn't find any data for the knock sensor output.
I do know it will have a constant output of sorts due to engine background noise. A knock will make it spike. The spike's duration may be too brief to show on a meter. A scope would be needed to display it.
Have you checked the wire harness for continuity? I think that's about all you can do.
__________________
Old 01-25-2013, 06:31 AM   #8
hellionss
hellionss's Avatar
Member # 6992
Ok. I have not checked the harness for continuity but what I have discovered is the light will only trip after two running cycles during which rpms exceed 2k. If I keep the rpms under 2k for three cycles the light will clear itself. I do get a fluctuating voltage reading from the obd port that drops drastically above 2000 rpms. Also, above 2k rpms the jeep falls on it's face momentarily which I assume is the knock sensor retarding the spark but after a couple seconds it resumes normally until it drops below 2k rpms at which point it acts fine until the rpms reach 2k again. Should I put a new sensor in it and go from there or are these symptoms pointing elsewhere?
Old 01-29-2013, 05:47 AM   #9
hellionss
hellionss's Avatar
Member # 6992
I may have found a problem. One of my ignition wires (spark plug wires) is damaged. What I don't kbow or understand is would this trip the knock sensor code and nothing else? I would ha e thought I would get a misfire code or something. Still not sure this is the solutuon to the knock sensor code but wires are on order and I will report back once they are installed.
Old 01-30-2013, 06:15 AM   #10
hellionss
hellionss's Avatar
Member # 6992
Well. New plug wires, no change. I'm thinking I either pinched a wire putting the transmission back in or the mnock sensor itself went bad. Not sure which. Plan to drop the transmission again when I get the chance and check the wiring. What I don't understand is I do get voltage thru to the pcm from the sensor so if I did pinch a wire it must be damaged but not completely severed right? Or am I just over thinking it?
Old 01-04-2015, 11:22 PM   #11
Giest
Member # 97921
I know digging up skeletons. But did you ever fix this. I have the exact same problem.
Giest is offline   Reply With Quote Quick reply to this message
Old 02-17-2015, 03:15 PM   #12
hellionss
hellionss's Avatar
Member # 6992
Yep.
I had actually broken the wire to the knock sensor.
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
