Will the 2013 softtop fit <2012 JK?? - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK General Discussion
Old 12-04-2012, 01:25 AM   #1
FireTruck
Member # 20042
Got a dual top option on my JKU rubi, and don't want/need the softop... even though it has the fancy spring assist and improved material etc. Looking to sell it on (and pay for other fun mods)...
Will it fit a 2012, 2011, etc??
S.
__________________
From the land downunder...
MY'13 Cherry Red JKU Rubi.
FireTruck is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 02:46 AM   #2
mrsig
mrsig's Avatar
Member # 547
With all the parts it will fit 07 and up. With just the soft top it will fit 11 and up.
__________________
07 JKU, To see my mods & Jeep in Action @
CEO of Black Sheep 4x4s
Member of CCJ, White Jeep Club Member #137.
mrsig is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 07:23 AM   #3
FireTruck
Member # 20042
Thanks - I assume that by 'all the parts' you mean brackets, door surrounds, windows etc. If so, all sweet - they are all brand spankin new in the box.
Cheers,
S.
__________________
Old 09-26-2013, 09:06 AM   #4
Gotlime?
Gotlime?'s Avatar
Member # 16884
So a friend has a 2012 JKU that only came with the hard top. Will a 2013 soft top work on a 2012 if she gets the hardware, door surrounds, etc with the 2013 top?
__________________
08 Jeep Wrangler Unlimited Rubicon: lift, wheels/tires, bumpers, skids, sliders, winch, lights, cb. All the normal stuff, plus some.......
Build thread:
Gotlime? is offline   Reply With Quote Quick reply to this message
Old 09-26-2013, 10:15 AM   #5
kkuntz01
kkuntz01's Avatar
Member # 8097
The tops are interchangeable on any of the model years so long as they are getting it complete meaning every last little piece and part.
__________________
kkuntz01 is offline   Reply With Quote Quick reply to this message
Old 09-26-2013, 10:30 AM   #6
dwtgolden
dwtgolden's Avatar
Member # 12973
This doesn't work going the other way though. A new top will fit on all JK's with all the pieces, but a top from an older JK will not work on a '12 or '13. They made a change to the location of the center bracket on the windshield for the freedom top and it interferes with the older style soft top header.
dwtgolden is offline   Reply With Quote Quick reply to this message
Old 09-26-2013, 10:55 AM   #7
tiltz
tiltz's Avatar
Member # 16840
That is 100% BS. Is this just hearsay or is this your actual experience?
I initially installed an older 2009 soft top on my 2012 Jeep and then later upgraded to a new one. The new soft tops and old soft tops don't make use of the center footman's loop and there is no interference.
I also sold my 2012 hard top to somebody with an 2007 JK. Their Jeep didn't have the center loop in the same place, but the top still installed just fine.
__________________
tiltz is offline   Reply With Quote Quick reply to this message
Old 09-28-2013, 08:30 AM   #8
dwtgolden
dwtgolden's Avatar
Member # 12973
Actual experience. You're right, they don't use the center loop, but the cutout in the header that is supposed to clear the center loop doesn't line up. You can still close the top, but the center footman's loop actually holds the center of the top up slightly at the windshield. Not enough to make it leak, but enough to get extra wind noise.
Old 09-28-2013, 08:46 AM   #9
10Seconds
Member # 30293
I am running a 2013 top on my 2007. Not a single issue - actual experience.
No leaks, no noise - exactly like the top that came with it, except I now have the sunrider option.
10Seconds is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
