Rattling noise when i start my jeep - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Electrical & Lighting Tech Dept.
Old 10-04-2012, 08:23 PM   #1
jknewgirl
jknewgirl's Avatar
Member # 23830
Hey guys so every time I start my jeep i hear this rattling noise. It only does it for a few seconds and then it goes away but I was wondering if this is normal or not? If not what could it be?
jknewgirl is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 08:25 PM   #2
Goodysgotacuda
Goodysgotacuda's Avatar
Member # 4538
Does it tick for a couple of seconds? Like the engine valve lifters are dry and pumping up?
__________________
Goodysgotacuda is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 08:35 PM   #3
Illtrythat
Illtrythat's Avatar
Member # 18067
I Have a 07 rubicon in my garage right now that had this problem. We are correcting it by installing a LS3 motor. I'll keep ya posted if it works.
Illtrythat is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 08:43 PM   #4
JKCTAZ
Certified Bullshit Spotter
JKCTAZ's Avatar
Member # 15063
Not to be gender biased, or ageist, but I would surprised if that wasn't Greek to her.
__________________
JKCTAZ is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 08:50 PM   #5
jknewgirl
jknewgirl's Avatar
Member # 23830
sadly your right lol. but i'm trying to learn as much as i can ever since i got my jeep. So I would love an explanation
Old 10-04-2012, 09:19 PM   #6
JKCTAZ
JKCTAZ's Avatar
Member # 15063
When you stop your Jeep, all of the oil in the motor collects in a pan that has a tube and screen near the bottom attached to a pump. When you start your Jeep that pump draws oil from the pan into that screen/tube and sends it to the top of the motor where it lubricates vital engine components, such as lifters and the valve train. If the motor sits for a while, those items go "dry" and make noise when the motor starts to function right before the oil pump primes and lubricates the motor. What exacerbates this issue is cheapo oil filters with no drain back check valve which keeps the oil from completely draining back to the oil pan.
Hope this helps. Usually the noise sounds like ticking or a coffee can with plastic marbles in it at times...
Make sure you check your oil level.
__________________
Old 10-04-2012, 10:09 PM   #7
snksknr94
snksknr94's Avatar
Member # 14982
Could also be a cracked exhaust manifold.
__________________
Aaron
2008 JK Unlimited Rubicon
snksknr94 is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 10:14 PM   #8
jknewgirl
jknewgirl's Avatar
Member # 23830
Thanks how do i know if this is the problem?
Old 10-04-2012, 10:14 PM   #9
jknewgirl
jknewgirl's Avatar
Member # 23830
is there a way to know if this is my issue?
Old 10-04-2012, 10:18 PM   #10
snksknr94
snksknr94's Avatar
Member # 14982
Your best bet would be to try and record the noise and post up the clip.
__________________
Aaron
Old 10-04-2012, 10:23 PM   #11
bthomas
bthomas's Avatar
Member # 13705
not really a "problem" per say, its just an explanation on the source of what i would call the sound of tapping a quarter on a wood table. different oil filters can help somewhat, but ime never completely cure it.
a cracked manifold would most likely do it constantly and get louder as the engine rpms go higher.
__________________
08 2dr steel blue, toyo 37's, method beadlocks, rock krawler 2.5" max travel, extended wheelbase, poly cage, 5.13's, arb's, diy hydro assist, prorock44, reid's, rcv's
bthomas is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 11:04 PM   #12
BenFoo
BenFoo's Avatar
Member # 8805
Is your AC on when you start up?
BenFoo is offline   Reply With Quote Quick reply to this message
Old 10-05-2012, 04:26 AM   #13
mschaffer66
mschaffer66's Avatar
Member # 11961
That was my issue.
Pull off the heat shield and inspect the manifolds or run some seafoam through it and look for where the smoke comes from.
__________________
2007 Sahara Unlimited - Dana 60/14 Bolt - 5.38's with ARBs - 40x13.50x17 Goodyear MTRs - 3.5" Rock Krawler X Factor Plus - Rubi Rock Rails - XRC 10,000lb Winch
mschaffer66 is offline   Reply With Quote Quick reply to this message
Old 10-06-2012, 09:02 PM   #14
jknewgirl
jknewgirl's Avatar
Member # 23830
nope lol AC is never on
Thanks everyone i'm determined to figure it out tomorrow
Old 10-06-2012, 09:12 PM   #15
Alpinehyperlite
Member # 22998
I have a work vehicle, so sometimes the jeep goes 3-4 days without being driven. It does the same thing. Ive always wondered what it was, but since it went away after a second or two i never really worried much about it.
Is it something that could potentially damage the vehicle in the long run?
Alpinehyperlite is offline   Reply With Quote Quick reply to this message
Old 10-07-2012, 06:46 AM   #16
Chipewa
Chipewa's Avatar
Member # 19680
Without reading the entire thread:
Tin-like rattle: Heat shield.
Clatter-like rattle: Surpentine belt tensioner.
__________________
LS3 2007 JKU X - Red Rock, 2012 JKU Rubicon - Deep Cherry Red, 2001 TJ - Black
Chipewa is offline   Reply With Quote Quick reply to this message
Old 10-08-2012, 04:28 PM   #17
jknewgirl
jknewgirl's Avatar
Member # 23830
this is what I am worried about
Old 10-08-2012, 04:29 PM   #18
jknewgirl
jknewgirl's Avatar
Member # 23830
Its definitely a tin-like rattle
Old 10-08-2012, 04:41 PM   #19
Dancin Dan
Member # 3812
Take a look at the heat shield under the Jeep and see if anything is touching the exhaust pipe. Could be something as simple as this. I had a rattle that drove me nuts for awhile and it turned out to be a piece of the heat shield touching the exhaust pipe.
Dancin Dan is offline   Reply With Quote Quick reply to this message
Old 10-08-2012, 11:51 PM   #20
red_man22
red_man22's Avatar
Member # 17616
I have something very simular on my 2011 with the 3.8L and it is the lifters starving for oil. The 2nd post hit it on the head. There is no fix for this and mopar dose not claim it to be a problem and says it will never hurt the engine. Me being a tech I argued this point for a customer but was at the loosing end of the battle.
Any time there is something that is starved for oil there is excesive clearance that is normally not there when the oil is present. The click you hear is metal on metal. I argued that anything metal on metal rubbing together will cause excessive wear. it may be minimal but it can possibly grow into a larger problem. But as I said I have tryed to argue the point befor and it got nowhere. There are a lot of 3.8L with a lot of miles on them that this has not caused a problem yet but there are a lot of guys that get paid a lot more then I do to figure those things out.
__________________
Build it! Run it! Break it! Repeat!
red_man22 is offline   Reply With Quote Quick reply to this message
Old 10-09-2012, 06:25 AM   #21
Chipewa
Chipewa's Avatar
Member # 19680
Check the heat shield that is attached to the crossover pipe under the front passenger seat for a broken spot weld.
__________________
Old 10-09-2012, 09:34 AM   #22
PhilD
TrailDuty.com
PhilD's Avatar
Member # 143
X2 I found that Mobil 1, Pure One, and several "high end" filters drained back resulting in low oil pressure when you start the vehicle. I used a Fram XG3600 Extended Guard filter and it does drain back at all and is bigger than the factory filter
True, but there is also an issue if the connector from manifold to exhaust pipe that can result in exhaust gas escaping until it warms up and seals.
__________________
PhilD is offline   Reply With Quote Quick reply to this message
Old 10-09-2012, 09:35 AM   #23
PhilD
TrailDuty.com
PhilD's Avatar
Member # 143
Definitely a rattle problem spot. Easily fixed with a cable clamp or two around the heat shield.
__________________
Old 10-09-2012, 10:12 AM   #24
gold knight
gold knight's Avatar
Member # 1460
Where in Ga are you? If you're close by you can come out to the M&G in Jasper on Saturday and somebody can try to diagnose it for you. We have 50 years of combined jk experience lol.
Yeah if it's the filter issie, I use the same one as Phil and it hasn't been a problem since.
Manifold crack was more of a pff pff pff sound.
__________________
gold knight is offline   Reply With Quote Quick reply to this message
Old 04-25-2013, 02:46 PM   #25
Dittman2564
Dittman2564's Avatar
Member # 15844
I am experiencing a similar situation. Only when engine is cold/has been sitting for a while.
My problem is not exhaust,(already replaced drivers side manifold due to extreme crack) and not lifters in my opinion. (37+ years hot rodder,Jeeper,mechanic/ase cerified engine perf./engine elect.&electronics/CARB clean air car course/SMOG certified tech)
My problem appears to be ring gear/starter drive and/or gear related.
It seems like they aren't meshing,weak bendix spring maybe?
It sounds similar to when the ring gear teeth are damaged and starter gear is slipping etc.
Sounds perfect on other occasions.
http://en.wikipedia.org/wiki/Bendix_drive
__________________
Dittman2564 is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
