Prorock 44 vs Tera 44 - Page 2 - JKowners.com : Jeep Wrangler JK Forum
Old 09-21-2012, 12:29 PM   #26
AllJeep.com
Member # 21572
Originally Posted by Alaska-HWY JK View Post
Thats an expensive looking rock magnet (FOX) hanging there. The Tera wasn't an option when I got my PR44, I'd run either though. Definitely want the corrected caster with a lift. Mine has great road manners and has never had a steering stabilizer on it. Needs hydro assist though.
Yeah the Reid knuckles raised the tie rod so the normal steering stabilizer flip kits dont work. We have since fabricated a new bracket and moved the stabilizer up out of harms way
AllJeep.com is offline   Reply With Quote Quick reply to this message
Old 09-21-2012, 12:33 PM   #27
PhrogMech46
PhrogMech46's Avatar
Member # 10501
Originally Posted by AllJeep.com View Post
Here is a Teraflex one we just did with Reid knuckles and the factory locker and shafts.
The quality is second to none and there are plenty of great Teraflex vendors on here to get sweet deals from
EDIT: CANT FIGURE OUT HOW TO MAKE THIS PICTURE SMALLER... SORRY
Will aftermarket trackbar brackets like the poly bracket work with the Tera axle? I ask because the drag link is flipped in that picture but the trackbar appears to be in the factory location resulting in them not being in the same plane.
__________________
The duty of a patriot is to protect his country from its government.-Thomas Paine
See Garage for Mods
PhrogMech46 is offline   Reply With Quote Quick reply to this message
Old 09-21-2012, 12:41 PM   #28
TeraFlex
TeraFlex's Avatar
Member # 1767
TeraFlex has a Tera44 that comes with a raised trackbar mount now. (Running down to take pic now).
__________________
1-888-837-2359
TeraFlex never left the market or the trail.
TeraFlex is offline   Reply With Quote Quick reply to this message
Old 09-21-2012, 12:51 PM   #29
AllJeep.com
Member # 21572
This build has a drop bracket on the frame side so they ride in the same plane the bracket also has 2 different holes to fine tune the plane the track bar rides in.
Old 09-21-2012, 01:00 PM   #30
TeraFlex
TeraFlex's Avatar
Member # 1767
Sorry, all the axles that have these are crated up and ready to go.
__________________
1-888-837-2359
Old 09-21-2012, 01:11 PM   #31
Dynatrac
Dynatrac's Avatar
Member # 7964
The brackets we use on our PR44 are the same as our PR60 brackets and thickness has never been an issue. We don't use cheap stamped brackets like you'll see on some housings. If it had proven to be a failure point it would have been remedied years ago.
One of the reasons we went with 1/2" tubes on our ProRock44 Unlimited housing was to retain use of axle tube seals. For some users, this is an important option. We've also found our customers appreciate the thicker tubing when they are welding on additional brackets (for custom suspensions).
Dynatrac is offline   Reply With Quote Quick reply to this message
Old 09-21-2012, 02:40 PM   #32
TeraFlex
TeraFlex's Avatar
Member # 1767
TeraFlex uses the same 1/4" thick CNC laser cut brackets on both the Tera 44's and CRD60 Axles. The Tera44's allow customers to use stock inner axle seals and a outer shield is in the works.
__________________
1-888-837-2359
Old 09-23-2012, 07:28 AM   #33
FireTrail741
FireTrail741's Avatar
Member # 17647
Originally Posted by TeraFlex View Post
I'm running a Tera44 with RCV's and the stock e-locker in my 2012. I also added our big brake kit with the HD cylinder. Works great! The 0-3" is perfect for your application.
So your axles are not air locker/e-locker specific?
FireTrail741 is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 09:26 AM   #34
TeraFlex
TeraFlex's Avatar
Member # 1767
TeraFlex offers a Rubicon OEM replacement housings to re-use all the stock Rubicon parts. The non Rubi housings is for ARB's etc to be installed in.
__________________
1-888-837-2359
Old 09-24-2012, 10:45 AM   #35
REBEL OFFROAD
REBEL OFFROAD's Avatar
Member # 8448
We can help with this question.
When ordering the Tera44 front housing for Jason's JK - we ordered the JK Rubi version so he could run JK specific gears and an ARB 157. The Tera44 came ready for the E-Locker. Because we put the ARB in Jason's housing - we had to drill a hole for the ARB fitting.
An ARB 147 and non JK specific ring and pinion gears are correct for that application.
Cheers,
Bond
__________________
Rebel Off Road // Bond Gilmer, President
Toll Free: 866-900-8841
Email:
HQ:
CONSULT. BUILD. DELIVER.
REBEL OFFROAD is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 10:51 AM   #36
Ghetto Fab.
Member # 23354
You guys with drainplugs ever rip one out while crawling over rocks?
The toyota drainplugs are pretty notorious for catching a rock, ripping out and dumping gear oil all over the trail. Happened to me once, I've since welded mine up and plated over them.
Kevo
Ghetto Fab. is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 10:38 PM   #37
d'sjk
d'sjk's Avatar
Member # 5640
Thanks to Rebel and TeraFlex I got a Tera 44 front non rubi...but it is going on my TJ build
__________________
d'sjk is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 11:08 PM   #38
REBEL OFFROAD
Member # 8448
You will love it. Jason installed his Tera44 housing Friday and had it ready for wheeling Saturday. Ease of install plus compatibility with other industry leading aftermarket parts gives the Tera44 a 10/10.
__________________
Email:
HQ:
Old 09-25-2012, 05:42 AM   #39
RODICON
30 Years of Rockin!
RODICON's Avatar
Member # 2233
The Tear44 housing drain plug is in the housing were you can't rip it out as is the OEM housing.
__________________
2014 Rubicon on the build!
RODICON is offline   Reply With Quote Quick reply to this message
Old 09-25-2012, 06:26 AM   #40
thedirtman
thedirtman's Avatar
Member # 10948
Where is the teraflex made? Where are the parts sourced from?
__________________
Some build info here:
thedirtman is offline   Reply With Quote Quick reply to this message
Old 10-03-2012, 07:13 AM   #41
RODICON
30 Years of Rockin!
RODICON's Avatar
Member # 2233
Ran the Tera44 across the Dusy trail with no problems. Gears set up by JKVICK.
__________________
Old 10-19-2012, 05:47 AM   #42
RODICON
30 Years of Rockin!
RODICON's Avatar
Member # 2233
Pics of outer tube seals and sleeves posted soon!
__________________
Old 10-19-2012, 12:14 PM   #43
89yjon
Member # 21219
Originally Posted by jeepasoris47 View Post
That is a good question, I have PR 44 Unlimited with RCV's and Reid knuckles and that setup rocks, the only thing that I hate is that no one makes a good gasket for the diff. So i went ahead and e-mailed both LubeLocker and Dynatrac to ask them to hook up and have them make one for the 44 and 60 housing, so lets see were this go's, keep you fingers and toe's crossed.
Any word from either of them yet? I know I would like to have one for my pr44.
89yjon is offline   Reply With Quote Quick reply to this message
Old 10-24-2012, 02:15 PM   #44
TJDukit
TJDukit's Avatar
Member # 18730
Right from the Teraflex website
"- 100% engineered, designed, and built in the USA"
__________________
'09 JKUR. Metal Cloak overlines, TF 3" LA, 35" Nitto Trail Grapplers, Home built winch bumper, custom built sliders, RK Drag Link and HD Pro Tie rod, Adams front shaft, TF Big Brakes, Speed Bumps, Warn M8000
I.Y.A.A.Y.A.S.
TJDukit is offline   Reply With Quote Quick reply to this message
Old 10-24-2012, 02:45 PM   #45
Traviso
Member # 15853
Is the Prorock or the Teraflex also available with a hub kit ? I saw, that it is available for the Dynatrac 60.
Traviso is offline   Reply With Quote Quick reply to this message
Old 10-24-2012, 04:11 PM   #46
GreenJK
Member # 6997
Not sure about the Tera housing, but there is a big FAQ for the PR44.
11. Is the ProRock 44 available with a Dana 60 wheel end?
Yes, the ProRock 44 is available with a Dana 60 wheel end. There are several advantages including larger axle shafts, u-joints, ball joints, and a true locking manual hub. These configurations are made to order and sold as a custom assembly. Please contact a Dynatrac sales representative for
additional information.
17. Can I get a ProRock 44 axle with a half ton truck style wheel end and a locking hub?
Yes, we have built ProRock 44 Axle assemblies with a traditional full size pickup Dana 44 steering knuckle, spindle and hub. These axle assemblies are sold as custom builds on a made to order basis. Please contact a member of the Dynatrac sales staff for additional information if you are interested in one of these assemblies.
GreenJK is offline   Reply With Quote Quick reply to this message
Old 10-24-2012, 04:38 PM   #47
leman
leman's Avatar
Member # 7573
What's the lead time on these axles from order to my door?
__________________
2008 steel blue sahara
with some doo-dads
leman is offline   Reply With Quote Quick reply to this message
Old 10-24-2012, 04:55 PM   #48
Traviso
Member # 15853
Great information. Thanks a lot.
Old 10-25-2012, 12:16 AM   #49
glomb23
glomb23's Avatar
Member # 15593
Depends where you order from.
__________________
Greg
glomb23 is offline   Reply With Quote Quick reply to this message
Old 10-25-2012, 08:41 AM   #50
Dynatrac
Dynatrac's Avatar
Member # 7964
Bare ProRock 44 housings are available from a few of our distributors immediately and some can also do full builds very quickly (as quickly as a week). Our current lead time on a full build is 5-6 weeks.
Scott
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
