Stock rear control arm "orientation"? - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Stock JK Tech Dept.
Old 08-25-2012, 09:03 PM   #1
aristobrat
Member # 6619
I'm replacing a stock bent rear LCA with a stock rear LCA from a 2012, and the bushings have different stampings than the one being replaced.
One end has a 45, the other end has a 43.
Anyone know which end mounts to the axle, and which mounts to the frame, or if that's even relevant?
Thanks!
aristobrat is offline   Reply With Quote Quick reply to this message
Old 08-29-2012, 08:22 PM   #2
jkrubitm
Member # 15184
I pulled out my spare arms to look at the bushings. Mine don't have those numbers. But The rear LCA are not bent like the upper ones so I'm sure it does not matter. I also measured both ends and they are the same, 2-1/2''.
jkrubitm is offline   Reply With Quote Quick reply to this message
Old 08-29-2012, 09:53 PM   #3
Goodysgotacuda
Goodysgotacuda's Avatar
Member # 4538
This is something I've never paid any attention to when it comes to rear lowers, either way shouldn't make much of any difference. If any at all...
__________________
Goodysgotacuda is offline   Reply With Quote Quick reply to this message
Old 08-30-2012, 08:43 AM   #4
aristobrat
Member # 6619
Thanks guys, especially jkrubitm for pulling your arms to look!
Old 08-31-2012, 08:01 PM   #5
jkrubitm
Member # 15184
I did not take my arms off, I looked at my spare set, but your welcome anyway.
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
