Interior "Squeaking" - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Stock JK Tech Dept.
Old 08-13-2012, 03:27 PM   #1
Blackr6
Blackr6's Avatar
Member # 8378
As of lately the interior has been "squeaking" ridiculously. I have never taken any of the panels on the b pillar off but they are becoming extremely annoying!!! My JkU is a 2010. Anyone else experiencing this?
Sent from my iBrick
Blackr6 is offline   Reply With Quote Quick reply to this message
Old 08-13-2012, 03:36 PM   #2
ChrisR
ChrisR's Avatar
Member # 12728
I've experienced lots of squeaks. My 2011 has styrofoam in the roll bar covers that squeaks against the metal. It's coming from the B pillar?
ChrisR is offline   Reply With Quote Quick reply to this message
Old 08-13-2012, 04:00 PM   #3
snowbilt
snowbilt's Avatar
Member # 11501
Try this checklist
The top bolts on each side of the windshield pillar
Remove freedom panels and make sure the front bolts are tight for the rear piece of the hardtop.(I had a horrible squeak that started two weeks ago and couldn't figure it out. When I started to remove the top this weekend I noticed the passenger side bolt was completely loose. I probably forgot to tighten it the last time I put the top on.
Buy some white lithium grease and apply a light coating to all door latches and strikers.
Let me know how it comes out.
Sent from my iPad on the toilet
snowbilt is offline   Reply With Quote Quick reply to this message
Old 08-13-2012, 05:29 PM   #4
FireTrail741
FireTrail741's Avatar
Member # 17647
Mine was the cigarette lighter. Threw it out!
FireTrail741 is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 05:17 AM   #5
snowbilt
snowbilt's Avatar
Member # 11501
Interesting will keep that in mind
Old 08-14-2012, 11:28 AM   #6
Gotlime?
Gotlime?'s Avatar
Member # 16884
I had a B pillar squeak. It was the door striker. I put some elctrical tape on it and it's been quiet ever since.
__________________
08 Jeep Wrangler Unlimited Rubicon: lift, wheels/tires, bumpers, skids, sliders, winch, lights, cb. All the normal stuff, plus some.......
Build thread:
Gotlime? is offline   Reply With Quote Quick reply to this message
Old 08-17-2012, 02:12 PM   #7
Espo78
Member # 17843
Good call! I just put some tape on the passenger side striker and no more squeak! Thanks for the tip!
__________________
Mike
'07 2 door soft top
Espo78 is offline   Reply With Quote Quick reply to this message
Old 08-17-2012, 02:25 PM   #8
Blackr6
Blackr6's Avatar
Member # 8378
Striker?
Is this the rubber trim?
Sent from my iBrick
Old 08-17-2012, 02:29 PM   #9
Espo78
Member # 17843
The metal latch on the body...AKA the Bottle Opener.
__________________
Mike
'07 2 door soft top
Old 08-17-2012, 06:04 PM   #10
Blackr6
Blackr6's Avatar
Member # 8378
K. New it as a bottle opener. haha
Sent from my iBrick
Old 08-28-2012, 10:42 PM   #11
Matti
CUNT
Matti's Avatar
Member # 17942
Location: The Land of the Polite, Where shits covered in Ice.
squeak from behind dash will be the AC lines coming through the firewall use some zipties to hold it in place to something else under the hood
__________________
As previously mentioned, the key step in this process is saturating those whores in piss.
I just gotta say.. When you're being butt hurt by your fudge packer minions.. how do you decide which one gets to pull the pony tail n who's left to cup the balls.. If there is any..
Matti is offline   Reply With Quote Quick reply to this message
Old 08-28-2012, 10:45 PM   #12
dmhines
dmhines's Avatar
Member # 4079
My annoying squeak which sounded like it was coming from behind glovebox was actually dented skid plate pushing plastic gas tank into the floor of the jeep.
__________________
2009 JK - 2DR - 6SPD - 1/2 Doors
4.88 G2 Gears / Warn XD9000i / Custom bumpers & Swing Gate
XRC Rock Rails / 35" Kumho's on Black Rock Vipers
2.5" Mutt Lift / Rubicon T-Case / E-DISCO / VIAIR OBA
Rear CV Driveshaft / Rear Detroit Locker / Front Aussie
Teraflex Sleeves / Gussets / Nitro Chromoly Axles
dmhines is offline   Reply With Quote Quick reply to this message
Old 08-29-2012, 07:39 PM   #13
Lagfest
Lagfest's Avatar
Member # 15810
I had one too,.
The tailgate has a ruber grommet on the drivers side body that fits inside a metal U shape on the tailgate itself. If the u shaped metal piece comes loose, or is misaligned at all, any vibration will cause the rubber grommet to squeak against its metal holder. its reaaaaly anoying but easy to fix.
I gotta fix mine tonight.
__________________
2012 JK Rubi
See ya when I see ya
"The Stupid is spreading!
Lagfest is offline   Reply With Quote Quick reply to this message
Old 06-11-2015, 09:33 AM   #14
Stangbuster
Member # 16414
The AC lines were my issue. I zip tied them to my Arrington oil catch-can off the ignition block.
Stangbuster is offline   Reply With Quote Quick reply to this message
Old 06-11-2015, 02:21 PM   #15
funfred
funfred's Avatar
Member # 50657
Buy a Corvette. The Jeep squeak wil be music to your ears.
funfred is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
