| Register | Active Topics | Garage | iTrader | Calendar | Mark Forums Read | Premium Memberships | Auto Escrow | Auto Loans | Insurance | Advertise |
Share | Thread Tools | Display Modes |
#1 |
Member # 19806
adjustable control arms
I am looking to get some adjustable control arms. Which would you suggest? Right now I am leaning toward the Metal Cloak control arms.
| Sponsored Links | |||
Advertisement | |||
#2 |
Member # 16199
Rock Krawler all the way. You will get the most flex out of their arms due to the 20-30 degrees of misalignment. Also, their lower arms are slanted upwards for ground clearance. Their new joints are basically service free (the Generation 3), all you have to do is spray em down with some WD every so often and your good to go. Plus, you have a full lifetime warranty on them. Not that you will ever break one, you can certainly try tho
__________________
2008 Black 2Dr 6spd D30/44
RK 2.5 | Bilstein 5100's | RK draglink | Synergy tie rod | 35x12.5 MTRK's | BFH front | Yukon 5.13's | ARB front locker & diff cover | Warn M8000 |
#3 |
Member # 14310
+2^
__________________
2012 Flame Red JKUR- Manual w/ 4.10s & Nav JCR Front Pre-runner & Rear Dagger, RK 2.5" Flex System, Bilstein 5100s, Teraflex Exhaust Spacers, Nitto Trail Grappler 35x12.5x17 Tires, Black ATX Slot 17x9 Wheels |
#4 |
Member # 14682
RK x3
#5 |
Jersey Crew "OG"
Member # 15065
Polly you can adjust them on the ground, don't have to drop the arm and your not limited to a half turn.
__________________
http://www.JustJeepGear.com/ Official sponsor of the Jersey Crewhttp://www.carolinametalmasters.com/ "Wasn't Me I was in Sweetwater" |
#6 |
Member # 16788
You could always build your own, if you can't, find a local fabricator... it should be A LOT cheaper. I built both of my Front Lowers out of 2" x 1/4" wall x 36" with SS high misalignment ends for about $211 and that's including shipping ($47).
#7 |
doesn't drink koolaid
Member # 14440
X4 on RK.
Poly is great too. Bullet proof and a reasonable price. Sent from my DROID X2 using Tapatalk 2
__________________
Jersey ![]() Crew POISON SPYDER • ROCK KRAWLER • POLY • RCV • YUKON • AEV • TATTON • MBRP • TERAFLEX • BILSTEIN • JKS • RAMSEY • ROCK HARD • WURX • NEMESIS • SPOD • RIGID
#8 |
Member # 16199
Yeah the poly arms and there on vehicle adjustability is nice for sure. Esp if you have aftermarket shafts to dial in your pinion angle. But even still, adjusting the RK arms is pretty easy with a jack on the pinion to increase the pinion and line up the bolt holes, or on one of the TREs to increase caster.
__________________
#9 |
Member # 15179
Those Metal Cloak arms are bad ass!
__________________
2.5" Rock Krawler Springs-Teraflex Control Arms-35" Toyo- AEV Pintlers-Fab Fours Bumpers- Ace Engineering Sliders and Fenders-Spiderwebshade......... |
#10 |
Member # 14440
What makes them more badass than any other arm?
__________________
#11 | |
JC Militia
Member # 5317
![]() Is this thing on?
__________________
www.4x4s-pod.com |
#12 |
"Ainokea I do what I like"
Member # 9703
My vote is for Currie. Johnny joints on both ends their beefy nuff said IMO.
__________________
USARMY
#13 |
Member # 4538
$1215 for 8 Poly or $1100 for 8 RK. With the installed adjusting on the rig, I'd have to bite the bullet and go for Poly. As long as Poly didn't want eleventy dollars to ship the arms.
__________________
'09 2dr Rubicon - 6spd | 37s | 4.88s | DIY PSC Ram | OR-Fab cage | Poly Cage | BFH Front | XRC Rear | XRC12 Winch | Walker Evans Beadlocks | WannaBe Off Road Shop |
#14 |
I Stink
Member # 13438
I have the Metalcloaks. They are awesome, ride has improved. Flex is improved.
Even at full flex they still have room for more flex. Have about 3k miles and a few offroad trips on the so far and the difference is noticeable. I can't see payIng 300+ for a control arm that still as a stock bushing on one end. The joints on each end of he Metalcloaks give them a lot of flex.
__________________
You smell that?
#15 | |
Member # 11961
Don't buy Poly/Synergy stuff from Poly. ![]() Even with their 10% off sales its usually the same, if not cheaper to order their stuff from a place like Northridge that has free shipping.
__________________
2007 Sahara Unlimited - Dana 60/14 Bolt - 5.38's with ARBs - 40x13.50x17 Goodyear MTRs - 3.5" Rock Krawler X Factor Plus - Rubi Rock Rails - XRC 10,000lb Winch |
#16 |
Member # 14682
If you drive the Jeep regularly I'd keep the stock bushing on one end for the smoother ride. As far as adjusting on the rig, I'd be terrified a lock nut would loosen up and give me problems.
#17 | |
Member # 11961
I said in another forum I assumed my RK tie rod lock nuts were tightened and it ruined the rod. No more assuming.
__________________
#18 |
Member # 14682
I do understand that. My statement is purely theoretical. I never had a problem with lock nuts backing out.
#19 |
Member # 4318
Let us know if you have any questions on our products! Were here to to talk jeep, good luck on your build.
RK
__________________
Better Products Through Innovation, Not Duplication!
The Originator of the Independent 3 Link System! |
#20 |
Member # 19484
This. Rokmen is another solid choice. Can't beat the Currie JJ.
#21 |
Member # 10501
My vote is MetalCloak, their Duroflex joints soak up vibes, give tons of flex, and are bent for tire clearance versus ground clearance which I prefer any day running my 13.5" wide Toyos with 4.5" backspace wheels. They are $1,200 for a set so price wise they are comparable to others. I have about 10k miles on mine with zero complaints.
__________________
The duty of a patriot is to protect his country from its government.-Thomas Paine See Garage for Mods http://www.jkowners.com/forum/dto_garage.php |
#22 |
Member # 9703
This I learned from you & a few others. Couldn't be happier.
__________________
USARMY
#23 |
IDWE
Member # 15593
Currently running all eight RK arms. They've been great so far. With that being said I'll be putting on the metal cloak game changer system within a few weeks. I'll be sure to give my impressions.
__________________
Greg Jersey Crew 2011 White 2dr. Rubicon on 37's. - SOLD 2012 Silver JKU Sport - PR44 and a bunch of other stuff |
#24 | |
Member # 8265
__________________
AnimasOutdoor.com Quality Hunting, Fishing, Camping and Outdoor Gear 2007 Wrangler X - Jeep Green, 4" lift, 4.88s, locked rear, custom bumper/fender/cage, rolling on 35s w/ 15s |
#25 |
JC Militia
Member # 5317
I believe he already did....
__________________
www.4x4s-pod.com |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
