ruff stuff one ton tie rod - JKowners.com : Jeep Wrangler JK Forum
Old 06-10-2012, 10:08 PM   #1
jk_zero
Member # 20071
i am looking for opinions on this product. pros, cons ect... it seems stout but if anyone has used/seen it first had their impression would be helpful. thanks
http://www.ruffstuffspecialties.com/...g/TREOFFK.html
__________________
So-Cal
Krew O.G.
RKDONKY (work in progress)
'11 JKU Rubicon, bright silver
jk_zero is offline   Reply With Quote Quick reply to this message
Old 06-10-2012, 10:11 PM   #2
JKCTAZ
Certified Bullshit Spotter
JKCTAZ's Avatar
Member # 15063
I have been contemplating this mod for a while, it's a solid option for 150 bucks.
__________________
JKCTAZ is offline   Reply With Quote Quick reply to this message
Old 06-10-2012, 10:13 PM   #3
PhrogMech46
PhrogMech46's Avatar
Member # 10501
Awesome set up for a great price. I have been running it for along time with no issues. Just make sure you are running at least a 16.5 inch wheel and your good to go. Tightened up my front end tremendously. There are a couple of threads on this topic.
__________________
The duty of a patriot is to protect his country from its government.-Thomas Paine
See Garage for Mods
PhrogMech46 is offline   Reply With Quote Quick reply to this message
Old 06-10-2012, 11:20 PM   #4
Robbs2008JK
Robbs2008JK's Avatar
Member # 21970
Did the same thing on my TJ. Will be doing the same in my JK. Super strong and had close to 40k on them with zero wear.
Robbs2008JK is offline   Reply With Quote Quick reply to this message
Old 06-11-2012, 04:55 AM   #5
Goodysgotacuda
Goodysgotacuda's Avatar
Member # 4538
Welded one up for someone on Saturday. Nice little kit for the $$.
__________________
Goodysgotacuda is offline   Reply With Quote Quick reply to this message
Old 06-11-2012, 07:44 AM   #6
Abadjeeper
Abadjeeper's Avatar
Member # 4396
Like other have said it is hard to beat for the money and is super beefy. I have built 5 so far and they work great.
__________________
09 Rubicon Unlimited on 42's with some stuff
Abadjeeper is offline   Reply With Quote Quick reply to this message
Old 06-11-2012, 07:50 AM   #7
zjr
zjr's Avatar
Member # 5296
I'm running it too. Love it. 17" factories and needed spacers.
__________________
zjr is offline   Reply With Quote Quick reply to this message
Old 06-11-2012, 01:00 PM   #8
nocoastfocus
nocoastfocus's Avatar
Member # 7404
Dr. Dirty did a write up on this recently. I loved Ruff Stuff when I was building my XJ and its great to see these parts on the JKs.
http://www.jkowners.com/forum/showthread.php?t=56217
nocoastfocus is offline   Reply With Quote Quick reply to this message
Old 06-14-2012, 12:05 AM   #9
jk_zero
Member # 20071
so what are you guys doing about a steering stabilizer? i looked into the poly tube clamp but it only fits 1.3 od tube. i guess some u-bolts and a plate would work. any suggestions would help.
__________________
So-Cal
Krew O.G.
Old 06-14-2012, 04:12 AM   #10
zjr
zjr's Avatar
Member # 5296
I got the Poly PPM-3112-06 with mounting tabs, but still haven't installed it. Running no stabilizer for the last year probably.
__________________
Old 06-14-2012, 05:39 AM   #11
Goodysgotacuda
Member # 4538
We weren't quite ready for that change on the one I did, we welded a tab to it for the time being. That kinda defeated the adjustment on it, but he didn't want to run w/o a SS.
__________________
Old 06-14-2012, 08:21 AM   #12
Abadjeeper
Abadjeeper's Avatar
Member # 4396
My RC stabilizer brackets fit fine. On my buddies 11 we just modified the factory mount with my die grinder to fit. For the others I have built a clamp using some spare tube I had around the shop.
The backup for all of these was u-bolts and 3/16" plate.
__________________
Old 06-14-2012, 04:56 PM   #13
PhrogMech46
Member # 10501
The factory one will work with a little persuasion, I just bent the u-bolts a little and it will bolt up. I actually just installed a 1.5 poly clamp that I welded a threaded bung to and it works perfect.
__________________
See Garage for Mods
Old 01-11-2013, 09:56 PM   #14
macknjack
Member # 25067
someone stated you have to run a minimum of a 16.5" wheel? is this correct? i am running 16's. no idea of backspacing on them but not oem
__________________
Daily driven and self sponsored
07 X RK X factor 5.5 long arm w/coilovers, Coast front ds, adams rear shaft, 5.13's, Detroit rear/ e-locker front, Ten factory front & rear shafts, artec c gussets, synergy ball joints, rockhard offroad cage, ipcw tails, aev corners, warn xd9000i, bestop element doors, 37" bfg km2's, 17" TR beadlocks
macknjack is offline   Reply With Quote Quick reply to this message
Old 01-11-2013, 10:17 PM   #15
PhrogMech46
Member # 10501
I believe it is hit or miss with 16's. I think I have an old ruff stuff tre laying around I could send you so that you could test fit. I'll send it on my dime if you pay it forward for someone else that needs it for a test fit
__________________
See Garage for Mods
Old 01-12-2013, 03:41 AM   #16
Rottenbelly
Rottenbelly's Avatar
Member # 13438
The Gm 1 ton offset tie rod ends are very close on a 17 inch wheel with 3.5 backspace.
I have heard they will clear the 16.5 with 3.5 backspace TWF recentered wheels.
__________________
You smell that?
Rottenbelly is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 12:33 PM   #17
BeerMonkeY
BeerMonkeY's Avatar
Member # 148
i run one, i just moved my ss to the drag link fo rthe time being, it looks like a bracket from a f250 will fit and i have one laying around i plan to try one my jeep is put back together.
__________________
'91 YJ-woods beater-lift and stuff
'98 ZJ-5.9 lowered street jeep
'13 WK2-5.7 daily tow pig
BeerMonkeY is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 05:45 PM   #18
Abadjeeper
Abadjeeper's Avatar
Member # 4396
We use these ends in our Aluminum Steering and I can say with about 95% certainty they will not fit with a 16" wheel. It would have to be a steel wheel with a pretty good radius or little to no backspacing to have any chance.
__________________
Old 01-27-2013, 09:23 PM   #19
macknjack
Member # 25067
that would be awesome, i actually just pm'd gravel maker on pirate. i really need to get this tie rod done.
is it offset or normal style? i have a guy local that can bend my tube if i can't run an offset tre so i really just need to know now if i can clear the standard style ruff stuff tre.
__________________
Old 07-09-2014, 09:22 AM   #20
Crossman100
Member # 58937
Double thumbs up for RuffStuff Tie Rods! I've got on on my JK and its very beefy! Both Poly and JKS make a tie rod clamp to fit the tube from what I've found. (I've got the JKS bracket on mine)
Crossman100 is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
