Same sh!t...another 1 ton build.... - Page 9 - JKowners.com : Jeep Wrangler JK Forum
Old 12-07-2012, 05:06 PM   #201
jeepbronco1
jeepbronco1's Avatar
Member # 7956
Originally Posted by Jaybee1669 View Post
I'm out in Baytown currently. Renting a room from a friend while i stash money back for a property purchase in the next 12-18 mos.
I'll PM you some contact info. Give ema heads up when you're gonna be banging on it. If i'm free, i'm more than happy to lend a hand....and pick your brain a little.
Sent ya PM, come on by any time! Kinda slow this month with the holidays, but should make more progress next month. Talk to ya soon!
BP
__________________
My build
jeepbronco1 is offline   Reply With Quote Quick reply to this message
Old 01-12-2013, 07:02 PM   #202
Ludski
Ludski's Avatar
Member # 19625
i seriously need to come spend a weekend with you. lol.
have been really really considering new axles.
and its gonna be weird seeing your jeep with...all the same tires...
__________________
*The More You Play With It, The Bigger It Gets*
Ludski is offline   Reply With Quote Quick reply to this message
Old 01-13-2013, 07:30 AM   #203
jeepbronco1
Member # 7956
hahahah! Bring it on man, and yea its going to feel weird having all 4 match!!
__________________
My build
Old 01-22-2013, 08:54 PM   #204
True Life
True Life's Avatar
Member # 20492
spyderlock 20s will be back in action in may
True Life is offline   Reply With Quote Quick reply to this message
Old 01-22-2013, 10:41 PM   #205
Co4Lo
Slow and Low
Co4Lo's Avatar
Member # 4935
Do tell...
Co4Lo is offline   Reply With Quote Quick reply to this message
Old 01-23-2013, 09:21 AM   #206
jeepbronco1
Member # 7956
Badasss
__________________
My build
Old 01-23-2013, 05:26 PM   #207
HEEPJEEP
Member # 24003
You guys are having to move the LCA mounts out on the front axle housing to clear the diff casting?
HEEPJEEP is offline   Reply With Quote Quick reply to this message
Old 01-23-2013, 05:38 PM   #208
frankie945
frankie945's Avatar
Member # 9831
either cut some of it off or just weld over top of it.
[IMG][/IMG]
frankie945 is offline   Reply With Quote Quick reply to this message
Old 01-23-2013, 07:34 PM   #209
HEEPJEEP
Member # 24003
Yeah I will be welding right directly to the casting. I've bent/broke enough 60 housings to know I am not taking any of the casting away. I do have a 78-79 60 though, so I have more "room". I am having to bring the arms in as far as I can to clear the tires and not lose steering.
Looking good man! Lots of good info in here. Thanks!
Old 01-23-2013, 08:44 PM   #210
jeepbronco1
Member # 7956
[IMG][/IMG]
Most people arent using the 78-79 because of rarity, but i think with that year model you shouldn't have to move the brackets out much... I welded to cast and think it should hold up fine, I've got a great thread saved on pirate about welding cast that should be a great go to....
If ya cut the perch make sure and truss it like Frankie and co4lo did.
As for updates its been a while . But finally got my steering linkage in from ruff stuff , also git me some 35spline 4340's from Yukon, as well as there hardcore lockouts..... The pitman arm is kicking my ass, because I'm a jack ass and should have removed it before drilling... I'm only half way done drilling it out so I may go ahead and remove it.
Also I need some help with track bar and and draglink geometry . I've decided against the high steer ... So question is does your trackbar, use the angle in which its bent or do you go from mount hole to mounting hole?
If it goes from mounting point to mounting I'm good, but if not ill probably be making my own track bar since the RK one is some what limiting .....
Yukon axles , just a tad large... Had to git them with a grinder to get them in.
Also had a fit with alignment bushing but finally went with 0* and got it squared away!!
Adjustable ones suck!!!!! Don't F with em!!!
Should have this piece of shit on its front wheels very soon!!!!!!!!!!!!!!!
Things to wrap it up will be driveshafts, hydro steering , brake kit for rear, and brake lines..... Then fabricating some fenders etc........
By the way huge shout out to Marcus at RCO , I literally ask him for prices twice a week!!! I owe you a beer bud!!! Ill be sporting his swag on this biatch fo sho!!!!!!
Sent from my iPad using Tapatalk
__________________
My build
Old 01-23-2013, 08:49 PM   #211
jeepbronco1
Member # 7956
And the lockouts .....
Not 1ton related but traded for some half doors , one more thing to add to the list if things to do !!
__________________
My build
Old 01-23-2013, 08:51 PM   #212
HEEPJEEP
Member # 24003
It's the angle front mounting point to mounting point... The drag link and track bar "should" be the same lengths.
Old 01-23-2013, 08:53 PM   #213
jeepbronco1
Member # 7956
sweet thats what I figured but with the odd angle im producing it seemed weird! Appreciate it!!
__________________
My build
Old 01-23-2013, 08:59 PM   #214
HEEPJEEP
Member # 24003
FWIW, it's typically easier to grease the u-joints if they are installed with the joint flipped to face the other direction.
Are you doing tone rings on the front end?
Old 01-23-2013, 09:05 PM   #215
jeepbronco1
Member # 7956
Damn!!!!! Good to know! just a tad late on my part...... makes since. Nope on the rings on the front . Gonna run them on the back though.
__________________
My build
Old 01-25-2013, 07:34 PM   #216
Ludski
Ludski's Avatar
Member # 19625
You finally get matching tires. And now you go and throw on different doors. Lol.
Sent from my handy dandy notebook.
__________________
Old 01-25-2013, 09:13 PM   #217
jeepbronco1
Member # 7956
HAHAHA! Hey at least they are all red.....
__________________
My build
Old 01-25-2013, 09:19 PM   #218
jeepbronco1
Member # 7956
pitman arm kicked my ass!!!!!!!!!!!!! Tried drilling it out with out removing it, dumbass move. Gonna take that biatch off tomorrow . Gonna weld up a double shear and washers to fix my drilling out mess Im hoping to have this steering pain done by monday!!!!!!
__________________
My build
Old 01-26-2013, 09:21 AM   #219
Co4Lo
Slow and Low
Co4Lo's Avatar
Member # 4935
You're supposed to cut a slice in it in the same direction as the splines. Then it pops right off.
Old 01-26-2013, 03:58 PM   #220
jeepbronco1
Member # 7956
Well it popped of rather easy with a removal tool. I finshed drilling it out for the rod ends. welded a washer to save my wallowing out and decide to not double shear. Steering links are drying and ill have them installed tomorrow. Ill post up pictures then!!
__________________
My build
Old 01-27-2013, 11:04 AM   #221
jeepbronco1
Member # 7956
Steering is complete for now , need to order some hardware for the passenger side but all in all I think it should work well. Tie rod is straight with no rubbing . I haven't flexed it out yet to see whether or not it should bind but from the looks of it it shouldn't. But I've been fooled a lot.... Gonna pick up some brake pads today's put the wheels and tires on tomorrow. Then a month off from this thing....
Even a lil RCO swag on it
__________________
My build
Old 01-27-2013, 05:53 PM   #222
jeepbronco1
Member # 7956
Also got my exhaust out , what have y'all guys been doing to mod your exhaust? I'm thinking about running true duals and ditching the y-pipe... Is that a good or bad idea?
Need some ideas....
__________________
My build
Old 01-27-2013, 07:23 PM   #223
Norm
Norm's Avatar
Member # 12704
This is the exact point I am at too. What to do with the exhaust...?
I am thinking about re-routing the passenger side behind the crossmember and above the skid.
I too would like to hear other ideas.
__________________
We carry all the following and much much more!!!
ACE - Adams - Lifetime - Metal Cloak - Poison Spyder - PSC - Poly - Rock Krawler - Seward - TeraFlex
Norm is offline   Reply With Quote Quick reply to this message
Old 01-27-2013, 08:50 PM   #224
jeepbronco1
Member # 7956
I actually took the section I cut out and moved it behind the transmission and in front /below the tcase and it looks like a good place. I've got to figure out what to do with the y pipe and run the driver side . Gotta find some exhaust scraps and clamps .
__________________
My build
Old 01-27-2013, 08:54 PM   #225
woody67
Member # 8577
Here's what I had done. Not sure if it will work for you, but might give you some ideas.
This is looking at the crossmember on the passenger side.
This is the back of the crossmember.
This is the driver side, just under front output of t-case
__________________
2009 Rubicon Unlimited: A mix of Teraflex and Currie with a little Poly thrown in, on 36s.
Mo' Doors, Mo' Problems
woody67 is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
