Horn & Cruise control do not work - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Stock JK Tech Dept.
Old 01-09-2012, 10:48 PM   #1
captjay
Member # 15045
I press the horn on the steering wheel and sometimes it might work once with hard press and cruise control is in and out. The horn works just fine with the key fob. Cruise does not work most of the time and when it does engage, it drops out on it's own
Does this sound like clockspring?? Only codes I'm getting are for wheel speed sensor (C100A), traction control (U0184), and some loss communication with radio or antenna (U1158) not sure on that last one though.
And have I read correctly that clockspring may be covered in warranty now??
edit: also the passenger air bag light has flashed on in the past maybe 4 or 5 separate occasions
__________________
I finally ditched that "other" forum
and coming to wheel on the dark side
captjay is offline   Reply With Quote Quick reply to this message
Old 01-09-2012, 11:52 PM   #2
Trdr712
Member # 16586
My horn also doesn't work when it is pressed, but will sound when I press the key fob. My cruise works fine. I have seen a few posts about checking the fuses as the most common reason for the horn to malfunction. I need to get around to checking mine some day, but with the doors and top off of the Jeep, I tend to point and yell instead of use the horn.
Trdr712 is offline   Reply With Quote Quick reply to this message
Old 01-10-2012, 02:56 AM   #3
-T-
-T-'s Avatar
Member # 1449
Most likely clock spring.
__________________
I laugh, I smile, I bounce..............JEEP
-T- is offline   Reply With Quote Quick reply to this message
Old 01-11-2012, 08:05 AM   #4
BeerMonkeY
BeerMonkeY's Avatar
Member # 148
the clock spring will affect anything on the steering wheel if it goes bad. thehorn still works with the key fob becasue your not physically pressing the horn button with the key fob
__________________
'91 YJ-woods beater-lift and stuff
'98 ZJ-5.9 lowered street jeep
'13 WK2-5.7 daily tow pig
BeerMonkeY is offline   Reply With Quote Quick reply to this message
Old 01-12-2012, 04:16 AM   #5
captjay
Member # 15045
Thanks man. looks like a dealer visit soon
__________________
Old 01-12-2012, 10:19 PM   #6
j5
Member # 15473
There was a cabin flash software update on my JK. Might check that out while you're there.
j5 is offline   Reply With Quote Quick reply to this message
Old 01-15-2012, 09:46 PM   #7
captjay
Member # 15045
thanks for the heads up
__________________
Old 01-18-2012, 01:10 PM   #8
captjay
Member # 15045
woohoo go my letter today for clockspring! I can''t believe that Chrysler customer service is saying there is no such thing out there for a recall or extended warranty. At least it will get fixed now hopefully
__________________
Old 01-18-2012, 01:17 PM   #9
jkruss
jkruss's Avatar
Member # 3071
Lucky bastard I just shelled out $536 to replacemy clock spring yesterday
__________________
Black Jeep
jkruss is offline   Reply With Quote Quick reply to this message
Old 01-18-2012, 01:57 PM   #10
HOOLIGAN
HOOLIGAN's Avatar
Member # 7236
Check on it. The warranty reimburses you if you previously paid out of pocket to fix it.
__________________
☠ ☠ Don't let fear and common sense stop ya. ☣ ☣
HOOLIGAN is offline   Reply With Quote Quick reply to this message
Old 01-19-2012, 12:18 AM   #11
captjay
Member # 15045
yea man, my letter provides a reimbursement form so hopefully u will get one
__________________
Old 01-19-2012, 10:20 PM   #12
b1pig
b1pig's Avatar
Member # 748
I got my letter two weeks ago... it definitely mentions possible reimbursement.
good luck!
__________________
'15 Ram 1500
2008 Kawasaki KLR650
needed: boat and plane
b1pig is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
