JkOwners.com - The Community for Jeep JK 4x4 Owners
Go Back   JkOwners.com - The Community for Jeep JK 4x4 Owners > JK Tech > Electrical Tech Dept.
Old 02-23-2009, 11:32 AM   #1
MOTO X JK
MOTO X JK's Avatar
Member # 3457
FACTORY STEREO WIRING
Does anyone know what wires behind the radio I can hook too for sound? I am trying to put an amp and sub into my JK keeping the factory single disc radio and can not figure out what wires to hook the inline converter too. I did this in my 2008 ram 2500 and the wires on the back of the jk radio are similar, but not exactly the same.
__________________
2009 SUNBURST ORANGE JK 4 DOOR SOFT TOP. 4" PRO COMP LIFT W/ 35" X 12.50" PROCOMP X TERRAINS ON 18" PROCOMP WHEELS. FABTECH PRE-RUNNER FRONT BUMPER AND STILL BUILDING...........
RED DRAGGONS!!!
shout out to Ellis Mate
MOTO X JK is offline   Reply With Quote
Old 02-24-2009, 01:35 PM   #2
MOTO X JK
MOTO X JK's Avatar
Member # 3457
ANYONE?? HELLO?...............
__________________
RED DRAGGONS!!!
Old 02-24-2009, 01:43 PM   #3
finishlinewestfabricator
finishlinewestfabricator's Avatar
Member # 3163
are you just trying to install a high low converter?
finishlinewestfabricator is offline   Reply With Quote
Old 02-24-2009, 02:21 PM   #4
BigO
BigO's Avatar
Member # 87
Here's the wiring diagram. Maybe this will get you going...
__________________
2007 Jeep JK Wrangler Rubicon Unlimited
B&M transmission cooler|Magnaflow muffler|Cobra 75WXST CB & Wilson antenna|3" hybrid lift|Rugged Ridge XHD front & rear bumper w/ carrier|Raingler nets|16x10 Pro Comp series 8179 wheels|315/75R16 BFG Mud Terrains|Glock 30 security system
BigO is offline   Reply With Quote
Old 02-24-2009, 02:25 PM   #5
Member # 3163
if you have a factory amplified system you will just toast the high low converter if you get the wires after the amp
Old 02-24-2009, 08:35 PM   #6
MOTO X JK
MOTO X JK's Avatar
Member # 3457
Thanks BigO...I think that is exactly what I need. I saved the pic and will try it in the next week or two. Thanks for the help!
__________________
RED DRAGGONS!!!
Old 02-24-2009, 08:36 PM   #7
MOTO X JK
MOTO X JK's Avatar
Member # 3457
I will make sure to pick up the signal BEFORE the amp. Thanks for the tip
__________________
RED DRAGGONS!!!
Old 02-27-2009, 07:43 AM   #8
hscrugby
Member # 1023
Umm.
if you go BEFORE the amp, you won't get any volume changes, eq changes, etc etc.
you will have to either take the stock amp completely out, and use the four channel from the radio, (still a "high power" output) or make sure to get a high/low converter that can handle the wattage from the amp. (Not hard to find)
the radio just tells the amp what to do via the canbus for volume and eq settings.
hscrugby is offline   Reply With Quote
Old 03-01-2009, 11:39 AM   #9
MOTO X JK
MOTO X JK's Avatar
Member # 3457
I found a transarent blue one w, gain control. That should do it I would think, right?
__________________
RED DRAGGONS!!!
Old 03-10-2009, 08:19 PM   #10
hscrugby
Member # 1023
Sorry I'm slow to reply, but no.
I don't know what that wire is, but it's not what you think it is.
If you want volume control, you need to go after the stock amp, or pull it out completely.
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©1996 - 2009 Pirate Media Group
