Nemesis Factory 44/30 Front Lower Shock Mount! - Page 3 - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK New Product News
Old 04-10-2012, 06:58 AM   #51
Nemesis Industries
Nemesis Industries's Avatar
Member # 8920
Originally Posted by Thisguyhasadd42 View Post
Great product you guys have here but I have a couple questions for you. I am looking the get the pure jeep backbone/gussets and was wondering if there will be any conflicts between the two parts? Also I am running RKs 2.5" max pro kit and have their recommended RRD shocks on the way, will these work or am I gonna need to get longer ones? I know it was briefly brought up earlier but I just want to make sure. TIA
With the Pure Jeep style of gusset there should be little or no interference with the new shock mounts. If for some reason there is interference it will be minor and can be handled easily with a grinder and then installed. There are some pictures earlier on that show these working installed on the cap style gussets with some minor grinding.
The shocks you have on order will work great. As always we recommend cycling your suspension after you make any changes to it to ensure you will have no issues on the trail.
Thanks for the questions,
Rob
__________________
NEMESIS INDUSTRIES
INDUSTRY'S FIRST ALL ALUMINUM PRODUCT LINE
(303) 974-2440
WWW.NEM-IND.COM
Follow us on Facebook
Nemesis Industries is offline   Reply With Quote
Old 04-10-2012, 07:05 AM   #52
Uncle Sams Misguided Child
Gunnery Sergeant USMC (ret)
Member # 12861
Got mine all painted up and ready for install. Thanks Nemesis, great product.
__________________
Originally Posted by unsub View Post
when it's your turn to fuck the cat you can name the kittens.
Uncle Sams Misguided Child is offline   Reply With Quote
Old 04-10-2012, 02:57 PM   #53
Thisguyhasadd42
Thisguyhasadd42's Avatar
Member # 16578
Rob
Excellent thanks for the info!
__________________
2010 Mango Tango 2dr 6spd Rubicon
Thisguyhasadd42 is offline   Reply With Quote
Old 08-17-2012, 10:10 AM   #54
el_campede
Going old school: CJ-7
el_campede's Avatar
Member # 4468
Just finished ordering a set. Thanks!
__________________
1985 CJ-7 Green (for now)
Jersey Crew (PA Stepchild)
el_campede is offline   Reply With Quote
Old 08-17-2012, 11:19 AM   #55
Nemesis Industries
Member # 8920
They are all boxed up and waiting for the UPS guy to come pick them up! I hope you enjoy them!
__________________
NEMESIS INDUSTRIES
(303) 974-2440
WWW.NEM-IND.COM
Old 08-30-2012, 12:34 PM   #56
jk_zero
Rock Donkey
Member # 20071
Great product! keeps the fox shock bodies from binding/rubbing on the frame. thanks guys.
__________________
So-Cal Krew O.G.
RKDONKY (work in progress)
'11 JKU Rubicon, bright silver
jk_zero is offline   Reply With Quote
Old 08-30-2012, 01:35 PM   #57
jchmelo
I'm awesome!
Member # 4225
So is there any cutting required or anything like that with these? Or do they just bolt on? Also I have a 2.5 inch lift with bilsteins will those shocks be ok with these?Or will I need different ones if I run this product?
__________________
JK ready for the build but the pockets aint
jchmelo is offline   Reply With Quote
Old 08-30-2012, 02:48 PM   #58
Rottenbelly
I Stink
Rottenbelly's Avatar
Member # 13438
They bolt right on. I have gussets on my axle and I did have to grind down a little off the edge. But otherwise its a simple install.
They are compatable with most any lift . Just moves the shocks out a few inches and up about a half inch. You will gain a little droop in your suspension cycle.
__________________
You smell that?
Rottenbelly is offline   Reply With Quote
Old 09-01-2012, 01:39 PM   #59
jchmelo
I'm awesome!
Member # 4225
I looked up the install steps it says you need to drill a hole. Is that correct?
__________________
Old 09-01-2012, 01:45 PM   #60
Fklein6768
JC Militia
Fklein6768's Avatar
Member # 5317
Yes on the passenger side.
Is this thing on?
__________________
www.4x4s-pod.com
Fklein6768 is offline   Reply With Quote
Old 09-04-2012, 08:07 AM   #61
ttechris
ttechris's Avatar
Member # 21160
Noticed this weekend my Bilsteins were hitting the frame under extreme articulation. Ordered a set this morning.
I may go coilovers in the future. These brackets look similar to what I installed on my buddies EVO setup, but turned 90 degrees. Do you see a problem using these with a coilover setup if welded on?
ttechris is offline   Reply With Quote
Old 09-04-2012, 08:29 AM   #62
Blackr6
Blackr6's Avatar
Member # 8378
Love mine!!!
Sent from my iBrick
Blackr6 is offline   Reply With Quote
Old 09-04-2012, 10:19 AM   #63
Nemesis Industries
Member # 8920
Your order has already been boxed up and is awaiting the UPS guy to come pick it up! As for the coilovers, you should be just fine welding it on but we haven't tested the clearance of the coilover springs on this bracket yet.
__________________
NEMESIS INDUSTRIES
(303) 974-2440
WWW.NEM-IND.COM
You may not post new threads
You may not post replies
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
