Dual Battery Set-Ups - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK General Discussion
Old 11-12-2011, 04:16 PM   #1
Tank29
Tank29's Avatar
Member # 1452
Looking for some pics and opinions on dual battery set-ups...I have seen pics of the Benchmark Design set-up but wondering what else is out there that you guys have seen or are running...Thanks.
__________________
2007 JK Unlimited "X"
TF 3" Kit w/4 Arm Flex Kit, TF HD F & R Adj. Track Bars, TF HD Steering Stabilizer, Yukon 5.13 gears, CenterForce II Clutch, Black Rock Soft 8's 16x8, Cooper Discoverer STT 315/75/16, RR XHD Front w/Stinger, SB XRC Rear w/Carrier, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fenders, SB XRC8 Winch
Tank29 is offline   Reply With Quote Quick reply to this message
Old 11-12-2011, 05:21 PM   #2
Criticalhabit
Member # 17623
I just ordered the rugged ridge off ebay for 84.00 buy it now plus 16.00 shipping. then i think i will order 12volt guy dual battery wire kit and winch controls.
Criticalhabit is offline   Reply With Quote Quick reply to this message
Old 11-12-2011, 07:33 PM   #3
FrostByte
FrostByte's Avatar
Member # 7212
JSS has one that fits with hemis
http://www.jkowners.com/forum/showthread.php?t=47061
FrostByte is offline   Reply With Quote Quick reply to this message
Old 11-12-2011, 08:19 PM   #4
ibjammin
ibjammin's Avatar
Member # 8660
The mounting brackets all seem to be about the same design and location I'm looking into it also now that I have added the winch I'm looking at the ARB fridge and need duals to run my portable welder!
ibjammin is offline   Reply With Quote Quick reply to this message
Old 11-12-2011, 08:26 PM   #5
Nwapache
Nwapache's Avatar
Member # 18149
Don't mess with benchmark .... Buy anything else, but make sure you spend the money for a Cole hersee smart isolator. It's the part that makes it all work best.
Nwapache is offline   Reply With Quote Quick reply to this message
Old 11-12-2011, 11:49 PM   #6
Criticalhabit
Member # 17623
So is the kit from 12volt guy not good. He offers a 200amp solenoid heavy gauge wire node kit from what I have read here in JKO
Old 11-13-2011, 08:30 AM   #7
JKUnlimitedSport_2010
Member # 11119
id like to see some of these set ups!!!! especially since a winch is in my christmasy future!!!
__________________
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42 MTR's
17" Spyderlock Beadlocks
JKUnlimitedSport_2010 is offline   Reply With Quote Quick reply to this message
Old 11-13-2011, 11:23 AM   #8
numb_crna
Lost in MI
numb_crna's Avatar
Member # 13140
Do not cast the Benchmark DB kit aside. It is a very well built mod that will last quite a while.
With that said, understand if you deal with Benchmark, you will get your product EVENTUALLY and enjoy.
http://www.jkowners.com/forum/attach...5&d=1311952291
Here is my install of the BM dual battery with Smart Isolator and his 500 amp winch fuse. I have all my accessories on a 9 switch custom 12Volt Guy panel with remote winch controls.
I am very happy with both.
__________________
____________________
Marcus of RCO: "I'm not selling anything, I'm just helping you buy stuff!
numb_crna is offline   Reply With Quote Quick reply to this message
Old 11-13-2011, 11:26 AM   #9
GKR
Member # 9118
A nice thing about the JSS is that it doesn't hang the second battery over the exhaust manifold. Keeps the plug/wire/etc access same as stock.
GKR is offline   Reply With Quote Quick reply to this message
Old 11-13-2011, 12:25 PM   #10
evdog
evdog's Avatar
Member # 11564
Went and got a ruggid ridge dual battery tray, and bought the ch smart battery isolater. Haven't had a problem since I got the smart isolater tried other methods u defintely need the ch smart isolater
__________________
VE7 ESH
evdog is offline   Reply With Quote Quick reply to this message
Old 11-13-2011, 12:28 PM   #11
Dr.Dirty
Member # 1569
Feedback: 21 reviews
Having installed bit the 12volt guy and BMD kits id say your safe with either... Both very nice kits
http://www.jkowners.com/forum/showthread.php?t=21381
http://www.jkowners.com/forum/showthread.php?t=43375
Dr.Dirty is offline   Reply With Quote Quick reply to this message
Old 11-13-2011, 01:00 PM   #12
idrivejeep
idrivejeep's Avatar
Member # 1434
I went with the M.O.R.E. dual battery tray and T-Max dual battery controller, after reading about the T-Max on some expedition/camping and Toyota forums.
Originally planned to go with the Rugged Ridge tray, but found the M.O.R.E. tray on ebay for $95. Couldn't beat that. The MORE dual battery tray is a well made American product, except for one design flaw. The battery hold down is nothing more than a flat piece of 1/8" steel spanning from side to side. This causes it to bow in the middle when you tighten down the nuts on the J-hooks. Too tight and you bend the hold-down, too loose and the batteries slide. Although their not going anywhere, as the group 34 Sears AGM Platinums slide in like a glove.
The T-Max 47-3800 kit brought everything I needed to make all the connections including the in-dash display that allows you to:
1. View the voltage coming in from the alternator.
2. View the voltage of each battery.
3. Link the batteries manually.
IIRC the batteries are automatically linked when charging and unlink about 30 seconds after you turn off the ignition. You can Google for actual specs.
__________________
My dog is worried about the economy because Alpo is up to 99 a can. That's almost $7.00 in dog money.
idrivejeep is offline   Reply With Quote Quick reply to this message
Old 11-13-2011, 01:44 PM   #13
TheBeatenPath
TheBeatenPath's Avatar
Member # 5580
i like that t maxx setup!!
__________________
TheBeatenPath is offline   Reply With Quote Quick reply to this message
Old 11-13-2011, 02:38 PM   #14
Vin
Vin's Avatar
Member # 12541
Originally Posted by FrostByte View Post
That's interesting. I wonder if it'll work with the River Raider's snorkle system.
Vin is offline   Reply With Quote Quick reply to this message
Old 11-14-2011, 05:46 AM   #15
brent_f70
brent_f70's Avatar
Member # 1918
Nemesis posted a few pics ......below before SEMA but I have not heard anything else about this set up. It is dual yellow tops, sideways!!
__________________
Courtesy of Hit - "You should only fuck the fuckable.. to fuck the unfuckable or to un-fuck the fuckable is like crossing streams in Ghost Busters"
brent_f70 is offline   Reply With Quote Quick reply to this message
Old 11-14-2011, 03:30 PM   #16
ibjammin
ibjammin's Avatar
Member # 8660
I have a question for those with the benchmark or RR side by side set up where it moves the battery closer to the motor any problems getting to the spark plugs or manifolds?
Old 11-14-2011, 03:32 PM   #17
REBEL OFFROAD
REBEL OFFROAD's Avatar
Member # 8448
The BMD kit is great - just wish there was more MFG support.
__________________
Rebel Off Road // Bond Gilmer, President
Toll Free: 866-900-8841
Email:
HQ:
CONSULT. BUILD. DELIVER.
REBEL OFFROAD is offline   Reply With Quote Quick reply to this message
Old 11-14-2011, 03:43 PM   #18
TXROCK
ADDICTION II build begins....
TXROCK's Avatar
Member # 5262
very clean on all of the setups although I like the MAXX addition of the battery monitor so you can see the voltage for both batteries.
What would be even cooler is if it had an amp rating so you can see the battery draw ...would be good to see indicators of the battery cells dying before it's time to replace it (usually once the battery is dead!)
__________________
U.S. Army
TXROCK is offline   Reply With Quote Quick reply to this message
Old 11-14-2011, 04:30 PM   #19
Djstorm100
Djstorm100's Avatar
Member # 16161
This would be a great idea for the 12+ but I don't think they make dry sells for 91/48 group ?
__________________
Maker of Black box, In-cab winch control and other electronics
Want to make wiring easy and painless?
Order your "Black Box" today!!
Djstorm100 is offline   Reply With Quote Quick reply to this message
Old 11-14-2011, 04:58 PM   #20
Dr.Dirty
Member # 1569
If your running stock manifolds there is no issues.... But with headers its a major bitch
Old 11-14-2011, 04:59 PM   #21
Vin
Vin's Avatar
Member # 12541
That actually had me thinking after I finished the install
I may look into the JSS tray and swapping come the warm weather.
Old 11-14-2011, 05:08 PM   #22
Dr.Dirty
Member # 1569
The easiest way is through the wheel well.........
Old 11-14-2011, 09:10 PM   #23
ibjammin
ibjammin's Avatar
Member # 8660
I do plan on running the ripp headers in the future so it sounds like it would be worth the extra money for the JSS set up?
Old 11-15-2011, 07:34 AM   #24
Dr.Dirty
Member # 1569
You might be ok with the rip.... I have the macaroni noodle Gibsons ant its and all around pain period lol
Old 05-25-2012, 10:43 AM   #25
fxk142
Member # 10095
Best Setup
I am jump starting this thread with a few questions, and opinion requests. I currently have the 3.8 engine and manual trans, and just ordered my sPOD 6 switch with air gauge. Plan on adding bumper lights, front/rear roof lights, Fridge/freezer, 9.5ti winch, and air compressor.
After studying dual battery setups, and keeping in mind future modifications (Hemi) would this be the best setup? (all purchased seperately):
-JSS Dual Battery Tray (modify top strap for mounting CH Isolator)
-Cole Hersee Smart Battery Isolator 200 Amps
-BenchMark 500 Amp Winch Fuse Module
-Odyssey Batteries (if so which size?)
Can a controller be used with this?
If this is not the best setup, is there a better approach?
fxk142 is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
