JKU Springs - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Stock JK Tech Dept.
Old 10-19-2011, 08:42 AM   #1
numb_crna
Lost in MI
numb_crna's Avatar
Member # 13140
JKU Springs
Are the springs in the JKU all the same? Rubi vs Sahara vs X, etc
I was thinking about a low budget change in the springs in my 2 door Rubi with 4 door.
Any advice?
__________________
____________________
Marcus of RCO: "I'm not selling anything, I'm just helping you buy stuff!
numb_crna is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 09:03 AM   #2
Chuck Bullitt
Chuck Bullitt's Avatar
Member # 3546
There are probably 10 different spring rates. You just have to look at the part numbers on the springs....high the number, higher the spring rate.
And you can't always just assume the springs off a Rubi are going to be taller. I bought some springs off a Rubi only to find they were shorter than the springs on my X. Gotta look at the part number.
__________________
Chuck
2009 JK Unlimited X, mostly stock with a K&N filter.
Chuck Bullitt is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 09:26 AM   #3
TheBlackSheep
TheBlackSheep's Avatar
Member # 16727
http://www.jkowners.com/forum/showthread.php?t=57605
check here
__________________
O||||O
TheBlackSheep is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 10:14 AM   #4
Obstruction of Justice
Obstruction of Justice's Avatar
Member # 6064
X2! Did the same thing. Bought some of CL and went to install them while I was putting in my bb and found that the front ones were smaller then the ones I had and the rear ones were taller. The only thing I could think of was that they came off a 2d.
__________________
Obstruction of Justice is offline   Reply With Quote Quick reply to this message
Old 11-05-2011, 11:36 AM   #5
numb_crna
Lost in MI
numb_crna's Avatar
Member # 13140
JKU Springs Update: My data
I did the swap of springs from my JK Rubi to JKU Rubicon Springs
Here is the DATA as measured by me. Same spot in garage, same tires, same payload weight in the jeep, same tape measure. Same idiot measuring.
Fender measurements are at the spot on the fender corresponding with the center of the wheel 90 degrees to the ground (I used a plumb line). The rock rail (RR) measurements are at the center of the door. Bumper height is measured at the front LEFT corner of my Rugged Ridge XHD stubby.
I swapped my front OE xxxx-14 springs for xxxx-18 springs; rear OE xxxx-56 for xxxx-59. You can see the difference in the front and rears in the photos below.
Location-------------Stock-------------1.75 RK BB-------------New springs + 1.75 RKBB
Bumper----------------25"----------27.25"-------------28
L Frt Fender-----------38.75"-------------41"-------------42.25
R Frt Fender-----------39-------------40.25-------------41.5
L Rr Fender-----------39.25-------------40-------------41
R Rr Fender-----------39.5-------------40-------------41
R Rk Rail----------------------------------18.25-------------19.25
L Rk Rail----------------------------------18.75-------------19.75
Interestingly enough, the right side of the vehicle sits 0.5" lower than the left. Could this be the weight of the fuel tank?
Hope this helps somebody.
Ron
__________________
Old 11-07-2011, 02:05 PM   #6
JOHN412
JOHN412's Avatar
Member # 12481
The stock Jeep one that end in 19 and 60 will give a 2dr 1-2" of lift depending on your set up and they go right in easily. There also pretty cheap if you shop correctly.
__________________
JOHN412 is offline   Reply With Quote Quick reply to this message
Old 11-09-2011, 12:57 PM   #7
THIN ICE
THIN ICE's Avatar
Member # 12620
I did it and added a Tera flex leveling kit gained 3". No drive shaft problems and I'm on 35's just added a set of Flat fenders. It's a cheap lift that works for a DD and trails. I also put a set of JKU Rubi shocks on but will get Bilstein soon.
__________________
Best Two Guy's in the Buisness!
Jason at KOR
Marcus at RCO
Jesus loves you, but everyone else thinks you're an asshole.
THIN ICE is offline   Reply With Quote Quick reply to this message
Old 11-15-2011, 11:33 AM   #8
jgrogan
Member # 1478
2dX to JKU Rubi Springs/Shocks
I swapped my stock 2 Dr X springs and shocks out with a 4dr Rubi "towing package"... Don't recall exact part numbers. Ended up with about a 1.75 in. lift, better ride and now my lights don't shine the tree tops when I load down for a camping trip. Really happy with this "cheap" lift.
Second the note that the right side is lower. Right rear is about 3/4 in lower than other corners... Don't notice it if you aren't looking but it drives me nuts!
jgrogan is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 02:24 PM   #9
xmikedentx
Member # 10354
Lots of free springs in the classifieds too!
xmikedentx is offline   Reply With Quote Quick reply to this message
Old 12-19-2011, 11:14 AM   #10
Rhino64
Member # 3602
I don't know this for a fact,but Ive been told that Rubicon shocks are made by Bilstein.If thats the case might not be any improvement.
Rhino64 is offline   Reply With Quote Quick reply to this message
Old 12-26-2011, 11:06 PM   #11
daggo66
daggo66's Avatar
Member # 4822
They are not. They are made by Tenneco, the manufacturer of Monroe and Rancho, among others.
daggo66 is offline   Reply With Quote Quick reply to this message
Old 01-23-2012, 10:27 AM   #12
fourplyn
fourplyn's Avatar
Member # 5388
Over time..the weight of the fuel tank will sag the right side slightly...Just swap the springs side to side when you see this happen.
And yes...higher the number on the springs the stiffer the springs..because of option's...like..Hardtop, full doors, 32" tires.
__________________
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
