MyGig/Lockpick/Uconnect Mic Question - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Electrical & Lighting Tech Dept.
Old 10-16-2011, 10:51 AM   #1
althekiller
Member # 9808
Finally got around to hooking up a mygig and lockpick in my JK.
Everything works fantastic, except the uconnect stuff. When I click the Uconnect buttons, it asks for my input (as if it is working), but never hears my answer, as if the mic isn't hooked up, which it is.
At first, I had thought it was a bad mic, but upon replacing it, same problem.
Upon further digging, I found that you have to pull up the "engineering" menu on the mygig, and select "Enable JK VR/HFM". I tried doing that, and when I go into the Engineering menu, the option for "Enable JK VR/HFM" is ACTUALLY THERE, but unfortunately, you can't do anything with it. The button actually looks grayed out, and clicking it doesn't do anything.
Anyone have any ideas why I don't have the button clickable?
althekiller is offline   Reply With Quote Quick reply to this message
Old 10-17-2011, 11:24 AM   #2
althekiller
Member # 9808
Bump...
Old 10-20-2011, 01:34 PM   #3
pnut
Member # 247
This last weekend I installed the mic and lockpick in my 07 Rubicon Unlimited.
I plugged it into the back, and it worked when I turned everything on. Sound quality when I left myself a voice mail was poor. But listening to a call on the speakers was great.
I have yet to try it out further beyond that I know it works. I have the mic peeking out from the top panel (drilled a small hole) on the drivers side next to the vertical grey plastic piece.
What I can suggest is going back and re-reading the manual one more time, that helped me with a problem. Plus make sure the dipswitches on the side did not change position during josling of installation.
How did you fit in all your wires? I had a bear of a time shoving all the extra wiring in there and still being able to push the radio back in. I used the hole to the left of the stack - to the right of the gauges.
__________________
07 Rubicon Unlimited - Teraflex 3" prerunner lift, 35's, 5.7 Hemi using AEV kit, Teraflex CRD60 rear with 5:13 gears all around.
pnut is offline   Reply With Quote Quick reply to this message
Old 10-20-2011, 02:09 PM   #4
Silverjk12
Silverjk12's Avatar
Member # 8456
make sure its ACTIVE! I believe you have a dvd in and hold the menu button down for 7 seconds. Look on the site and check that part out. I actually am going to look as well because mine is inactive or dealer mode at the moment
__________________
09 Sahara Unlimited
4.88 gears, 6 speed. 4 inch Teraflex with control arms
SB rock rails, stinger, tire carrier, and 10k winch, line x
35 Baja Claws, 17 XD Hoss wheels, backup cam, lights!
list goes on and on......
Silverjk12 is offline   Reply With Quote Quick reply to this message
Old 10-22-2011, 05:17 PM   #5
AOR
AOR's Avatar
Member # 4970
go to this web page and download the latest mygig updates burn them to disc and install them
http://mofv.com/MyGIG/
__________________
We sell and install products from over 100 manufactures at low prices and install them all
check us out on Facebook
AOR is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
