Who has the PSC or ORFAB cross member? - JKowners.com : Jeep Wrangler JK Forum
Old 09-16-2011, 07:59 PM   #1
SoK66
SoK66's Avatar
Member # 4483
Been looking at these recently. Running a Poly skid system but concerned about weight and access. Anyone melded one of these beefed up cross members into someone else's skid system?
SoK66 is offline   Reply With Quote Quick reply to this message
Old 09-17-2011, 10:34 PM   #2
Moose512
Moose512's Avatar
Member # 2045
I have the PSC crossmember and it worked fine with my Rockhard skids.
Moose512 is offline   Reply With Quote Quick reply to this message
Old 09-18-2011, 01:49 AM   #3
dcmp001
Member # 513
I have the OR-FAB crossmember and it is an exact copy of the factory one just built super beefy. I have a skid row skid attached and have beat the hell out of both and the OR-FAB crossmember has held up perfect. I highly recommend it.
don't blame me, I voted for the American.
dcmp001 is offline   Reply With Quote Quick reply to this message
Old 09-19-2011, 11:06 AM   #4
biglar
biglar's Avatar
Member # 2564
If the Poly skid system uses the factory mounting holes in the cross member, then ours will work. The weight difference between the factory cross member and ours is 14Lbs, but if you're like me and have (repeatedly) bent your factory cross member, the extra strength is worth every pound. Give us a call if you have any other questions.
Thanks,
__________________
Larry McRae
951-849-5911
Connect with us on:
biglar is offline   Reply With Quote Quick reply to this message
Old 09-19-2011, 11:12 AM   #5
Thean
Member # 14789
Whih skid are you running? Our full system replaces the cross member with 3/16 all boxed construction.
Our budget skid for use with RE longarms & similar is based off the stock crossmember & ties into stock mounting holes.
__________________
Click the sig for everything you need to build a JEEP... 805-706-0232
NEW PRODUCTS ADDED DAILY !!!
----> Click and download the new catalog!!!
Thean is offline   Reply With Quote Quick reply to this message
Old 09-20-2011, 09:55 PM   #6
SlvrJK
SlvrJK's Avatar
Member # 8383
I'm running the orfab xmember with a combination of purejeep and rockhard skids...they all get along very nicely.
__________________
SlvrJK is offline   Reply With Quote Quick reply to this message
Old 09-27-2011, 12:03 PM   #7
bcls99
bcls99's Avatar
Member # 15145
I have the PSC cross member.
__________________
I'm Dave and my rig is Brett.
'11 Black Unlimited Rubicon | 37 - 5.13 - 3
Teraflex - Poison Spyder - Fox - Poly Perf - GenRight - Dynatrac
Superwinch - Warn - Rigid - Skid Row - Smittybilt - Midland
ARB - Rancho - Black Rock Viper with Toyo M/T
978-618-5000
bcls99 is offline   Reply With Quote Quick reply to this message
Old 09-27-2011, 04:13 PM   #8
SoK66
SoK66's Avatar
Member # 4483
What I ended up doing is adapting a Rockhard tank skid to the Poly skid system. Pulled the Poly (PITA!) skids first, then re-installed the stock x-member. Mounted the RH4X4 tank skid. Removed everything and reinstalled the Poly (PITA!) skids. Removed RH4X4's tank skid mounting spacer at the t-case skid mount, reinstalled the tank skid with the side bolts. Drilled & tapped the Poly skid for the forward RH4X4 12mmx1.5 tank skid bolts and bolted them down. Made up a mounting spacer for the t-case skid bolt and will use a button head bolt. Looks like it was made for this app!
Old 09-27-2011, 05:16 PM   #9
Suffolk JK
Member # 7038
Made my own with 2"x4"x1/4" wall box. Used to the old one for the degree bends and all the measurements for the holes. 2 hours later, all welded up, solid piece, $60. The thing is all scratched to hell, zero dents.
__________________
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Confucius say "If you no want break axle, Drive with BIG head not LITTLE head"
Suffolk JK is offline   Reply With Quote Quick reply to this message
Old 10-09-2011, 11:48 AM   #10
dern
dern's Avatar
Member # 4866
I just installed the PSC cross member this weekend, work well with the River Raider Skid Plates.
dern is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
