wiring diagram - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Write Up Dept. (The Library)
Old 08-21-2011, 03:09 PM   #1
Uncle Sams Misguided Child
Gunnery Sergeant USMC (ret)
Member # 12861
wiring diagram
Ok so I had a hard time trying to figure out which wire went to which part on the relay and where did it go from there. So I drew out this easy schematic for myself and figured if I could figure it out anyone could.
So Positive from battery to fuse block
From the fuse block off to the #30 on the relays. I just used a 30 amp relay available anywhere. Then from #87 on the relay it goes out to power your item (lights, compressor, whatever).
From the M9 fuse on the stock fuse box it goes to your switch. M9 fuse is switch on only. And spade #85 on your relay to your switch. This just powers the relay to let it close the circuit so that power can go from the battery to your item.
Spade #86 on the relay goes to a ground.
Pretty easy when you break it down barney style. I have the relays mounted to an aluminum panel on top of the stock fuse box and the bluesea fuse block mounted on the drivers side of the battery tray. It has been this way for 3 years and has never been a problem.
__________________
What the fuck is that?? Looks like a faggot wagon!!!
Uncle Sams Misguided Child is offline   Reply With Quote Quick reply to this message
Old 09-05-2013, 09:21 AM   #2
HAFICON
Member # 20245
This is nice.. Wish I would have found it 4 weeks ago when I was doing my wiring. Nice explanation.
HAFICON is offline   Reply With Quote Quick reply to this message
Old 09-05-2013, 12:28 PM   #3
Member # 12861
Thanks, If a Jarhead can do it then anyone can.
__________________
Old 09-05-2013, 01:19 PM   #4
bigworm36
bigworm36's Avatar
Member # 17300
If I can do it anyone can that really helped !
bigworm36 is offline   Reply With Quote Quick reply to this message
Old 05-06-2015, 07:52 AM   #5
bigworm36
bigworm36's Avatar
Member # 17300
This is the best diagram out there I have used it for all my wiring!!! Just wired up some lights in the back the same way !
Old 07-21-2015, 08:13 PM   #6
bpkeen
Member # 134394
Few Questions
So, I just got this Jeep
and the last owner just ran wires wherever...
I have been thinking about doing the Power Distribution Block setup since I had an FJ Cruiser. I really need order in my life. I totally understand everything you have written up concerning this, but I have a few questions (because I need to know).
1. What Gauge wire do you use from the fuse tap and accessories to the fuse block/power distribution block?
2. How do I determine what size fuses to run at the fuse block?
3. Are the relays a standard relay, or is there a specific "size" that I need to order?
Thanks!
Billy
bpkeen is offline   Reply With Quote Quick reply to this message
Old 07-21-2015, 08:22 PM   #7
JKCTAZ
Certified Bullshit Spotter
JKCTAZ's Avatar
Member # 15063
8 ga. would suffice for lighting and small electrical loads as a main to the Blue Sea block main lug, 14 Ga. for Halogen or HID lighting loads, and 18-16ga would be adequate for the M9 fuse to switches portion and beyond if you're staying near the dash and cowl with the relays. That wire size would also be okay for LED lighting.
Also, Gunny has the M9 going to a distribution block and then separate leads for each line side on the switches, that isn't necessary if you just daisy chain off a single lead from M9 right on the back of the switches. That would simplify wiring a little.
__________________
JKCTAZ is offline   Reply With Quote Quick reply to this message
Old 07-22-2015, 07:15 AM   #8
Member # 12861
Yeah I don't remember why I didn't daisy chain the switches together, because I did daisy chain the grounds on the relays together.
The relays are just standard 30 amp from autozone.
__________________
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
