Easy Switched Power Source
36K views 18 replies 10 participants last post by  Uncle Sams Misguided Child
#1 · (Edited)
If your TIPM (fuse box) is set up like my 2008 is....
Here is a way to get switched power from the fuse box. It's easier than installing wires in the connector under the TIPM, although not quite as clean an install.
The fuse tap came from Advance Auto, Buss catalog # BP/HHH. It is rated for 10 amps, so that will be the max fuse you should put in it.
For use as outlined, only the top fuse position can be used, as the bottom fuse would send power to an empty wire socket in TIPM connector C6.
#2 ·
Thank you! I've got way too many things spliced into my 12V behind the center console.
I'm not really that electrically literate, so pardon me if this is a stupid question, but how much can 10w hold safely? Will it provide sufficient and safe power to my GPS and CB?
#3 ·
More than likely it will be fine for the CB. I don't recall exactly how much a CB draws, but it's a couple of amps I believe. Look at the fuse for the CB or the current draw rating for what you are trying to power off of it.
