Adding longrange fuel tank - JKowners.com : Jeep Wrangler JK Forum
Old 08-12-2011, 04:00 PM   #1
jurci2
Member # 16707
Thumbs down Adding longrange fuel tank
Recently became the proud owner of a 2door Jeep Wrangler petrol 2011 model. From australia we ordered an additional fueltank see: http://www.thelongranger.com.au/jklo....html#TA64PAHD
While looking undernearth the car there is a square shaped black box (approx 6 x 10 x 16 inch) at the location where the second tank is supposed to be mounted. See attached pictures to get an impression
Anyone known what this box possibly can be?
jurci2 is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 04:02 PM   #2
glwood
Member # 114
Evaporative canister.
__________________
07 Jeep Green 2 door Rubicon; OME Std suspension; 33" BFG KM2; Shrockworks stubby front, Expedition One rear bumpers, JKS adj trackbars f/r, Poly HD tie rod, Moog TRE on drag link.
glwood is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 04:03 PM   #3
sinduda2
sinduda2's Avatar
Member # 13606
Believe that is the evap canister. I purchased a skid plate for it because it's supposively expensive to fix
__________________
Jersey
Crew
Jim- 2010 Natural Green Pearl, 6spd, hardtop/soft top, RK 2.5" max travel lift kit,
"No Hesitation"
sinduda2 is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 04:03 PM   #4
ALASHA
F5 Champ
ALASHA's Avatar
Member # 6694
I think you are referring to your evap canister. There are kits out there to relocate it over you rear axle.
ALASHA is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 04:06 PM   #5
jurci2
Member # 16707
Glwood: Thanks for you quick answer. Can you indicate me what this is meant for? Could it easily be placed at a different location?
Help much appreciated. while buying the longranger tank they assurred me it would fit the 2011 model. But with this canister there I don't know how the tank can be placed there.
Old 08-12-2011, 04:06 PM   #6
glwood
Member # 114
For emissions control.
From the website you linked above:
Other Modifications: The Carbon Canister Is Relocated With All Parts Required Supplied In Kit.
__________________
Old 08-12-2011, 04:07 PM   #7
sinduda2
sinduda2's Avatar
Member # 13606
Also how much does that extra gas tank cost? I was putting on a lift last week and was saying how much Room there is under there for a bigger gas tank and if the cost wasn't to bad I would consider it
__________________
Jersey
Crew
"No Hesitation"
Old 08-12-2011, 04:10 PM   #8
jurci2
Member # 16707
Alasha: sounds very interesting as it seems that I will have to relocate it. especially as sinduda2 mentions it is expensive to replace.
Still no idea what is meant for though.
Old 08-12-2011, 04:17 PM   #9
jurci2
Member # 16707
Ok, Carbon canister and evaporation canister are the same thing as I understand now. The installation movie on the longranger website shows a canister being removed, but that was much smaller and drum shaped? See at 38 seconds: http://www.youtube.com/thelongranger.../5/rGK9v4VyHGQ
Tank for the two doors is only 42 liters unfortunately. And costs are approx 1470 AUD, but shipment can be fairly expensive, depending on destintion. Although expensive I thought to do this right when getting the new car, to have most advantage of it.
Old 08-12-2011, 04:34 PM   #10
sinduda2
sinduda2's Avatar
Member # 13606
But Is it adding 42 liters to the original 70 liters ?
__________________
Jersey
Crew
"No Hesitation"
Old 08-12-2011, 04:39 PM   #11
jurci2
Member # 16707
yes it is a seperate tank, with a switch to pumps fuel from the 42 to the main tank in case you need it. Your total fuel size will be 112 liter, giving you slightly more range withour having to carry Jerry cans in the limited space when camping. Furthermore it doesnt reduce your ground clearance.
Old 08-12-2011, 07:42 PM   #12
b1pig
b1pig's Avatar
Member # 748
i wonder... with the exhaust running right next to that tank... how does that affect the fuel? evaporation, condensation, expansion and such.....
__________________
'15 Ram 1500
2008 Kawasaki KLR650
needed: boat and plane
b1pig is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 07:47 PM   #13
sinduda2
sinduda2's Avatar
Member # 13606
Also would this effect a full under armor skid plate like from river raider?
__________________
Jersey
Crew
"No Hesitation"
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
