Full Independent Suspension...? - JKowners.com : Jeep Wrangler JK Forum
Old 07-06-2011, 03:17 PM   #1
Wiggles
Wiggles's Avatar
Member # 15820
So, currently my rig is sitting on a Rough Country 3" lift. While this lift makes it look pretty in the mall parking lot, when it comes to actual usability, it ranks right up there with poop. So...
I have two 2003 Cobra IRS systems sitting in storage, and I started wondering about designing a full independent suspension system. After some thought, though, I'm wondering if this would be a wise way to go. While all the flexiness would be nice, would it even be worth it with a rigidly mounted diff? I'm not sure I could get the diff high enough to make it so ground clearance would not suffer, tremendously.
Has anyone ever seen full independent suspension, other than gee-wow, on a JK, and if so, have you seen it work/how well does it work?
-M
Wiggles is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 03:29 PM   #2
Co4Lo
Slow and Low
Co4Lo's Avatar
Member # 4935
Here you go...
Co4Lo is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 03:30 PM   #3
Dr.Dirty
Member # 1569
Feedback: 21 reviews
YouTube - ‪JK Wrangler test drive‬‏
Dr.Dirty is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 03:40 PM   #4
Stigo
Member # 15539
rear steer FTW!!!!
Stigo is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 06:31 PM   #5
Wiggles
Wiggles's Avatar
Member # 15820
Yeah, I've seen the gocms.com trucks. They are definitely nice setups, but, as best as I can tell, absolutely useless anywhere other than the street/parking lot. I'm more interested in LCG setups, like on an H1. I just don't know if it would be truly applicable to a rock crawler setup, or even possible for a JK.
Old 07-06-2011, 07:08 PM   #6
GKR
Member # 9118
Check out the "long travel H3" thread on pirate for one persons design. Pretty impressive fab regardless of if you like IFS or not.
GKR is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 07:44 PM   #7
spedly
spedly's Avatar
Member # 13091
H1's have portals to keep everything tucked up and keep the cv's at decent angles. A 4 wheel independent setup would be much better suited to desert racing then it would be to rock crawling. Even then though a cobra irs has very short arms and offers very little travel causing it to very likely perform worse then stock even in the desert.
spedly is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 07:54 PM   #8
RoCk-NeSs MoNsTeR
RoCk-NeSs MoNsTeR's Avatar
Member # 2773
More complicated... more moving parts.... more failure points.
RoCk-NeSs MoNsTeR is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 09:23 PM   #9
2k2wranglerx
2k2wranglerx's Avatar
Member # 9620
IFS brings the suck
__________________
2007 2 door, RK coilovers, 5.38 gears, built rubi axles, 35" Kumho KL71's, etc
2003 TJ, solid 60, Full traction long armed, caged, etc
2011 Jeep WK2 70th anniversary (baby hauler)
2013 focus ST, SCT with unleashed tune, green filter, Daily driver
2k2wranglerx is online now   Reply With Quote Quick reply to this message
Old 07-06-2011, 09:50 PM   #10
lamar95x4
Member # 5129
4Wheel & Offroad's Ultimate Adventure truck is a new F150 with the turbo V6 they are beafing up the independant suspension with some shop that is escaping me right now...
Mike
lamar95x4 is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 09:58 PM   #11
THECHAD
JEEP...its my way of life!!!
THECHAD's Avatar
Member # 3913
go on the pirate and look up BEBE's H3 pretty bad ass and functional
__________________
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
now just kicking it as a civilian
I served so your lazy ass didnt have to
THECHAD is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 10:04 PM   #12
2k2wranglerx
Member # 9620
if youre blasting through the dunes it's awesome...
for slow crawling over obstacles... not so much
__________________
Old 07-06-2011, 11:40 PM   #13
usmcdoc14
Fistfull of Boomstick
usmcdoc14's Avatar
Member # 206
you will have to throw 3x the money at a IFS/IRS to get it to perform at the same level as a solid axle.
Yes, it can be done, just look at some of the new KOH/Ultra4 rigs.
Just be prepaired to bleed from the wallet badly
Get or ride in a mid/long arm JK with well setup springs and shocks the decide. what state are you in? I am sure people will let you test drive thier sh!t.
__________________
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 12:07 AM   #14
Co4Lo
Slow and Low
Co4Lo's Avatar
Member # 4935
Back to your original post. You have 2 Mustang IRS rear ends laying around. And the simple answer is; hell no fawking way will those effectively work in your JK.
So, with that in mind, are you still interested in engineering an IS JK, or were you just looking for something to do with the Stang assemblies you have laying around?
If you are still interested in engineering an IS JK... I would look for Military H1's at auctions to yoink the suspension and portal boxes from...
Old 07-07-2011, 04:46 AM   #15
Hovo
Hovo's Avatar
Member # 8253
Originally Posted by Co4Lo View Post
Here you go...
I think that guy tried to re-invent the wheel.. and failed..
__________________
POWER TO THE PEOPLE!
Hovo is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 09:04 AM   #16
Wiggles
Wiggles's Avatar
Member # 15820
Coming from a road racing background, of course I love IS. Drawing from that love, I was more interested in whether or not it would function well. From all that I've read, both here and elsewhere, it's pretty much a non-starter for anything other than racing or gee-wow. (Gee-wow would be the gocms.com trucks.) While I am all about re-inventing the wheel if it will produce a much better result, I'm certainly not about doing 10-times the work at 5-times the cost for half the results!
That being said, if I come across an HMMWV for the right price, maybe I'll revisit the IS thing... Or, maybe I'll just get teh HMMWV and and pimp it out! For now, though, looks like I'm just going to go with a 5.5" RK coilover kit... That should placate me for a while!
Thanks for the input, guys.
-M
Old 07-07-2011, 10:41 AM   #17
jeeperjkj
jeeperjkj's Avatar
Member # 4516
Or... you could do this...
http://youtu.be/w_F7QrR4Ur8
__________________
jeeperjkj is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 04:56 PM   #18
charles
charles's Avatar
Member # 8233
See FJ articulation fail.
The "true" 4X4 FJ guys go to solid front axle. You sir are "going backwards".
charles is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 04:59 PM   #19
Ogie
Ogie's Avatar
Member # 2504
FJ owners don't know how to drive.
This year's KOH winner was running with IFS.
That being said, for simplicity, durability and cost reasons, I'd rather run solid, but don't say you can't wheel with IFS.
Ogie is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 05:08 PM   #20
SoK66
SoK66's Avatar
Member # 4483
It's an interesting idea but probably not very practical. Certainly would be pressed to even match the wheel travel & durability of a good coil lift & the stock live axles. We'll have to face the inevitability that one day the SWB Jeep will be fully, or partially independent. We dodged the Daimler Benz bullet re: the JK, they wanted a front independent. Fortunately they bailed on the business. These were the same dimwits that bought you the "Trail Rated" red herring to cover the Compass/Patriot shit boxes. Whatever, either some marketing asshole or NHTSA will get their way someday and our beloved Jeep will be just another poser. I know race trucks have used fully independent for years, but we've yet to see a single setup that really works on the rocks.
SoK66 is online now   Reply With Quote Quick reply to this message
Old 07-07-2011, 05:10 PM   #21
SoK66
SoK66's Avatar
Member # 4483
Love to see this on the rocks.
Old 07-07-2011, 05:39 PM   #22
Ogie
Ogie's Avatar
Member # 2504
Originally Posted by SoK66 View Post
..l but we've yet to see a single setup that really works on the rocks.
Grant it, there's more money spent in the front-end of this buggy than most of us have spent on our entire rigs...but since you asked...
__________________
Vidi, vici, veni
2008 Jeep JK Wrangler Rubicon Unlimited
Old 07-07-2011, 08:20 PM   #23
Ipe
Ipe's Avatar
Member # 326
Probably closer to twice as much, if not more....
__________________
Ipe is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 08:41 PM   #24
VADERJKU
VADERJKU's Avatar
Member # 15229
Seems to me there are three ways of going about a fully independent suspended JK that won't cost as much as a house (like a full on KOH setup would):
Hummer H1
Gamma Goat
sand car
The first two I have seen on the web/in magazines, the second just seems logical to me though, I have yet to see one. All three would need some SERIOUS fab work, mods, and $$$ to work but, they are do-able! Mustang IRS though= fail!!! Might as well start from scratch!!!
VADERJKU is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 09:29 PM   #25
SubCultureNM
SubCultureNM's Avatar
Member # 10727
I'd say that if your JK currently rides or performs like crap, then it isn't set-up well. Keep in mind that solid axles are dirt-simple, especially compared to independent suspensions. Independent suspensions were developed for their ride and handling characteristics. Yes, they can be made to function well off road, but generally for a lot more money, and you will sacrifice strength. A well built, well tuned solid axle vehicle will ride almost as well (I say almost 'cause a Jeep ain't supposed to ride like a car) and will amaze you on the trail or in the rocks.
__________________
1997 TJ with LOTS of stuff.
2011 2DR Rubicon with stuff.
2012 JK8 with some stuff.
SubCultureNM is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
