JK WRANGLER 4BT DIESEL CONVERSION - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK New Product News
Old 07-04-2011, 08:58 AM   #1
Jeffs_Jeep_Yard
Jeffs_Jeep_Yard's Avatar
Member # 7628
Fellow JKOwners we are pleased to inform you that after a many months of designing, engineering and testing we are ready to release our Cummins 4BT Diesel conversion kit for JK Wranglers. This exciting conversion kit is something that many of us have been dreaming about for quite some time. We are teaming up with Kenny from River Raider Off Road to release this kit and perform these conversions at our two facilities. Feel free to contact either Kenny or myself at either our FL or PA locations by e-mail or phone. There will no doubt be many question that everyone will want answered. We will attempt to to answer all your questions in this thread. - Jeff Garland
We are extremely excited to be working with Jeff on this project. His design and attention to detail on this conversion is exactly what the JK world has been waiting for. We have collaborated through out its development and are thrilled with the results. We think many JKOwners will be blown away by the performance, drive ability and economy of this conversion. - Kenny Hauk
The DIY kit is now available for pre-order and will begin shipping in 6 to 8 weeks. This kit is very comprehensive and comes complete with detailed instructions. Much time has been spent in the designing and engineering of this system in order to achieve a from the factory feel both in appearance and function. Our team of electrical engineers have worked non stop for months designing the complex electrical system required in order to have the factory Wrangler wiring system interface perfectly with the 4BT Diesel unit. This has resulted in a simple painless DIY conversion kit that will unleash your Wranglers full driving and fuel economy potential. In order to protect ourselves from copycats until our Patent pending status is achieved some of the parts that will be included in the kit are not shown.
Here is what is included in the kit: (please note that not everything is pictured)
1) ENGINE MOUNTS ,BRACKETS MOUNTS AND HARDWARE
2)ENGINE TO TRANSMISSION ADAPTER INCLUDING FLYWHEEL AND ALL HARDWARE
3)TRANSMISSION TO TRANSFER CASE ADAPTER INCLUDES SEAL AND GASKET W/ TAILSHAFT FOR CONVERSION AND ALL HARDWARE
4)TRANSMISSION TO CROSSMEMBER ADAPTER INCLUDES HARDWARE
5)TRANSMISSION SHIFTER BRACKETS W/ HARDWARE
6)TRANSFER CASE SHIFTER BRACKET W/ HARDWARE
7)BATTERY TRAY WITH BRACKET FOR FUSE/RELAY BOX W/ HARDWARE
8)LOWER WATER NECK W/ HARDWARE
9)AC AND ALTERNATER BRACKET W/ IDLER PULLEY AND ALL HARDWARE
10)UPPER COOLING HOSE WITH CLAMPS LOWER HOSE IS REUSED
11)AC CONVERSION LINES
12) ALL FITTINGS FOR TRANS COOLING LINES AND FUEL LINES
13)THROTTLE BRACKET ASSEMBLIE WITH ALL HARDWARE
14)LOKAR THROTLE CABLE AND DETENT CABLES
15)VACUUM PUMP AND CANISTER FOR BRAKING SYSTEM
16)THROTTLE PEDAL AND BRACKET W/ HARDWARE
17)POWER STEERING CONVERSION HOSES HIGH PRESSURE AND RETURN
18)TURBO DOWN TUBE FOR EXHAUST SYSTEM
19)FUEL TANK CONVERSION COMPONENT KIT
20)TRIGGER WHEEL AND SENSOR BRACKET
21) COMPUTER AND WIRING HARNESS PLUG AND PLAY
ITEMS NOT IN PICTURES INCLUDE
AC LINES
FITTINGS FOR TRANS AND FUEL
THROTLE BRACKET ASSY.
LOKAR CABLES
VAC PUMP AND CANISTER
POWER STEERING HOSES
CORRECT AC AND ALT BRACKET ASSY W/ IDLER PULLEY
FUEL TANK CONVERSION COMPONENTS
TRIGGER WHEEL AND BRACKET
DIY conversion kit
To pre-order your DIY kit or schedule a complete install at one of our facilities feel free to call or email us.
Jeff's Jeep Yard
(727) 449-0800
info@jeffsjeepyard.com
(717) 491 5300
info@riverraider.com
Here are some frequently asked questions we have received over the last few months. As more questions come up we will add to this list here in this post.
Q) WHAT ENGINE APPLICATION WILL WORK BEST?
A) BREAD TRUCK 4BT WORKS BEST BUT YOU CAN BUY A LONG BLOCK AND WE CAN HELP SUPPLY PARTS NECESSARY
Q) HOW MUCH SHOULD I PAY FOR AN ENGINE ?
A) PRICES VARY BUT A GOOD RUNNING COMPLETE ENGINE CAN BE PURCHASED FOR AROUND $3,000. A REBUILT ENGINE CAN BE PURCHASED COMPLETE FOR AROUND $6,800.
Q) WHAT TYPE OF TRANSMISSIONS CAN I USE WITH KIT?
A) WE RECOMEND THAT YOU USE RAPTOR 700R STAGE 3 FOR AUTOMATIC. FOR MANUAL WE RECOMEND NV4500.
Q) WHAT IS THE COST OF THE TRANSMISSION?
A) RAPTOR 700R STAGE 3 IS APPROX. $2,600 WITH SHIPPING IT COMES WITH TORQUE CONVERTOR. THE NV4500 COST $1,900 BUT ALL COMPONETS NECCESARY TO RUN NV4500 EQUALS AND EXCEEDS PRICE OF THE ADAPTER FOR THE AUTOMATIC APPLICATION. EVEN THOUGH THE COST OF THE NV4500 IS LESS YOU HAVE A CORE CHARGE AND EXTRA PARTS NECCESARY THAT EQUATE TO THE $700 DOLLAR DIFFERENCE MINUS THE ENGINE TO TRANSMISSION ADAPTOR IN KIT FOR AUTOMATIC.
Q) WHAT LEVEL OF EXPERIENCE IS NEEDED TO DO THIS CONVERSION?
A) WE HAVE TAKEN THE TIME TO MAKE THIS CONVERSION AS SIMPLE AS IT CAN POSSIBLY BE. ON A SCALE OF 1 TO 10 FROM EASY TO
DIFFICULT I WOULD GIVE IT A 5. THE MOST DIFFICULT STEPS OF THE INSTALL ARE REMOVING OLD ENGINE MOUNTS, AND
REPLACING THEM WITH NEW AND THE ALINEMENT OF BELT FOR THE ALTERNATOR AND AC BRACKET ASSEMBLY.
Q) HOW MUCH DO WE CHARGE TO DO THE INSTALL IN OUR SHOP?
A) THE LABOR PORTION OF THE INSTALL IS APPROX $4,000 IN EITHER OUR FLORIDA SHOP OR OUR PENNSYLVANIA INSTALL FACILITY.
Q) HOW LONG DOES IT TAKE TO RECIEVE KIT ONCE ORDERED?
A) 4 TO 6 WEEKS.
Q) WHAT IS THE AVERAGE TIME FOR AN INSTALL ONCE COMPONETS AND VEHICLE ARE AT OUR FACILITY?
A) DEPENDING ON THE CUSTOMER'S BUILD SHEET FROM 5 WORKING DAYS TO 10 WORKING DAYS. THIS INCLUDES TESTING AND
TUNING THE VECHILE AFTER INSTALL.
Q) WHAT TYPE OF FUEL ECONOMY SHOULD I EXPECT?
A) DEPENDING ON VEHICLE BUILD SHEET AFTER COMMICATION WITH CUSTOMER WE WILL BE ABLE TO GIVE THAT INFORMATION.
THE AVERAGE IS 27 MPG. ( DEPENDS ON TIRE SIZE, GEAR RATIO, ENGINE MODS, AND DRIVING STYLE)
Q) HOW MANY MILES CAN I EXPECT TO GET OUT OF A 4BT?
A) THE AVERAGE IS 250,000 MILES DEPENDANT ON ENGINE MODS.
Q) CAN A 4BT RUN ALTERNATIVE FUELS?
A) YES 4BT'S LOVE WVO ( WASTE VEGETABLE OIL), SOY OIL, BIO DIESEL.
Q) DO ALL THE FACTORY GAUGES AND EQUIPMENT WORK AFTER CONVERSION?
A) EVERYTHING WORKS AS IT DID BEFORE, EXCEPT CRUISE CONTROL AND WE GENERALLY REMOVE ESP SYSTEM ( CLIENTS CHOICE).
Q) WHERE CAN I ORDER THE CONVERSION KIT?
A) JEFF'S JEEP YARD AND RIVER RAIDER OFFROAD.
Q) WHAT TYPE OF HORSEPOWER AND TORQUE NUMBERS SHOULD I EXPECT WITH A BASE 4BT.
A) THE AVERAGE 4BT MAKES 120 HORSE AND 385 FT/LBS OF TORQUE @ 1900 RPM'S. THE MOTORS THAT WE BUILD ARE 250 HORSE AND
492 FT/LBS OF TORQUE@ 2700 RPM'S ( REMEMBER THE MORE POWER THE LESS ECONOMY).
Q) WILL THE STOCK 4BT BE CAPABLE IN AN OFFROAD ENVIROMENT?
A) EXTREMLY CAPABLE BASED ON THE TORQUE CURVE BEING SO CLOSE TO IDLE. A STOCK 4BT WILL MAKE 225 FT/LBS OF TORQUE AT
1600 RPM'S.
Q) WHAT TYPE OF HIGHWAY SPEEDS CAN I GO WITH MY 4BT?
A) DEPENDING ON GEAR RATIO AND TIRE SIZE, 80 MPH CAN BE ACHIEVED WITH GOOD FUEL ECONOMY.
Jeffs_Jeep_Yard is offline   Reply With Quote Quick reply to this message
Old 07-04-2011, 09:28 AM   #2
hotrodtinker
hotrodtinker's Avatar
Member # 1559
I can't wait!!! I'm going to start looking for a good cheap engine and tranny now!!!
__________________
Hotrodtinker JERSEY
CREW
'08 Unlimited Rubicon (Rescue Green)
Lifted and running (for the moment)...
Planned Mods:
- Engine swap and 1-ton axles!!!
hotrodtinker is offline   Reply With Quote Quick reply to this message
Old 07-04-2011, 10:46 AM   #3
BBirish
Member # 5381
Awesome ! Excited to know that kenny is doing them pretty close by!
BBirish is offline   Reply With Quote Quick reply to this message
Old 07-04-2011, 01:04 PM   #4
makemeknowit
makemeknowit's Avatar
Member # 2373
__________________
Jeepless until:.....:....
makemeknowit is offline   Reply With Quote Quick reply to this message
Old 07-04-2011, 01:14 PM   #5
e-jeep
e-jeep's Avatar
Member # 7797
Feedback: 12 reviews
Dammit!!! I'm gonna have to win the lottery or auction off a kidney. Any chance y'all are looking for a pilot test Jeep???
__________________
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline   Reply With Quote Quick reply to this message
Old 07-04-2011, 01:20 PM   #6
Jeffs_Jeep_Yard
Member # 7628
Happy 4th fellow JK owners
Old 07-04-2011, 01:21 PM   #7
HITMONEY
Administrator
HITMONEY's Avatar
Member # 1369
Simply Awesome!
Nicely done!
I'm really gonna have to come up to see it.
__________________
°lllll°
All my rigs info and pictures can be found
Get Your JKOwners Swag
My Youtube Channel
HITMONEY is offline   Reply With Quote Quick reply to this message
Old 07-04-2011, 03:14 PM   #8
Jeffs_Jeep_Yard
Member # 7628
Fellow JKOwners we are pleased to inform you that after a many months of designing, engineering and testing we are ready to release our Cummings 4BT Diesel conversion kit for JK Wranglers. This exciting conversion kit is something that many of us have been dreaming about for quite some time. We are teaming up with Kenny from River Raider Off Road to release this kit and perform these conversions at our two facilities. Feel free to contact either Kenny or myself at either our FL or PA locations by e-mail or phone. There will no doubt be many question that everyone will want answered. We will attempt to to answer all your questions in this thread. - Jeff Garland
Are you using a Cummins 4BT, or a Cummings 4BT?
You got us bro LOL !!
Old 07-04-2011, 03:27 PM   #9
Jeffs_Jeep_Yard
Member # 7628
Simply Awesome!
Nicely done!
Anytime Bro
Old 07-04-2011, 07:13 PM   #10
GadgetPhreak
Member # 7057
I want one!!!! hmmm how to fund.
GadgetPhreak is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 10:22 AM   #11
MSUJeep
MSUJeep's Avatar
Member # 13229
Why no cruise control?? Can aftermarket cruise be added?
Honestly, I was expecting the total price (with good engine and tranmission) to be around $10k, if I did it myself. But it looks like closer to $20k after all is said and done. I'm not saying that it's not worth it with the longer engine life, cheap fuel (WVO), and fuel economy...not to mention torque. I'm thinking the hemi upgrade might be back on the table now that I know the cost of 4bt conversion.
__________________
"Sweet ain't as sweet without the sour"
MSUJeep is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 02:50 PM   #12
crash
crash's Avatar
Member # 1743
Yes aftermarket cruise can be added.
Your right Diesel equipped vehicles are more expensive for a reason. The life span, fuel economy and driving performance of the 4BT is vastly different from a Hemi. The complete kit for the 4BT conversion is massive (not all pictured) and has thousands of hours of engineering time invested in just the electrical system alone. With that being said a DIY install can be performed in the $15k range and a professionally "Hey I dropped the keys off and pick it back up" install can be done for around $19k.
__________________
RIVER RAIDER OFF-ROAD
717.262.3079
crash is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 02:58 PM   #13
ALASHA
F5 Champ
ALASHA's Avatar
Member # 6694
9,800 for the kit
6,800 for a rebuilt engine
2,800 for the trans
19,400 grand total.
As mentioned, a used engine could be found for ~3K but the numbers still arent adding up in my heads (it has been a rough day though )
ALASHA is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 03:16 PM   #14
BigMike
BigMike's Avatar
Member # 6692
Will it pass emissions?
sorry if this was in the introduction, but I'm a skimmer
__________________
, Granite,
, ProComp 7069 17x9, Goodyear MTR Kevlar 35's, Warn M8000, ACE ProSeries Bumpers, RROR Skids, Stock 4.10 gears
2011 Grand Cherokee Overland, HEMI
- SOLD
BigMike is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 05:06 PM   #15
Alaska-HWY JK
Member # 260
What transfer case is being used?
Alaska-HWY JK is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 05:34 PM   #16
Jeffs_Jeep_Yard
Member # 7628
all factory t cases and all aftermarket re: altlas etc . we supply adapter accordingly .
Old 07-05-2011, 07:45 PM   #17
Jeep2.0
El Jefe
Jeep2.0's Avatar
Member # 11126
Jeff, this is great information & it shows lots of detail in the kit. Nicely done. Once your patent pending status is resolved, I look forward to additional detail & instructions.
__________________
2011 5.3L GM LC9 Aluminum LS V8 Conversion w/ Custom Dyno Tune
Aluminum Genright Bumpers Front & Rear - Aluminum Nemesis Rockers
PR44/RCV/Reid Front - Superior Rear - ORF Front / Poly Rear Cage - ORF Tire Carrier
RK 3.5" Springs - Fox 2.0 Adjustable Shocks - JKS Arms & Trackbars - Poly Steering
Jeep2.0 is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 08:08 PM   #18
.:eMETAL:.
.:eMETAL:.'s Avatar
Member # 5575
DAMN GOOD WORK Jeff and crew!! This thread is to a T how every release thread should be written.
soon to be part of the black cloud gang cuz like they say... "I'd rather be cummin than strokin"
__________________
.:eMETAL:. is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 08:20 PM   #19
O2BDrty
O2BDrty's Avatar
Member # 620
Just got a SC. Oh well.
On board air?????? And what do you do about the gastank?
__________________
I'm sure I'll think of something
O2BDrty is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 09:58 PM   #20
mckbrew
mckbrew's Avatar
Member # 10199
This is awesome. Granted I am a few years away from a swap now, but my wife promised that as long as I didn't trade in for a new Jeep (and I didn't have to go in debt) that I could do the swap.
__________________
mckbrew is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 10:08 PM   #21
fastrat350
Member # 460
I rather do this swap than a HEMI anyday, now to win some money
fastrat350 is offline   Reply With Quote Quick reply to this message
Old 07-05-2011, 10:54 PM   #22
BenFoo
BenFoo's Avatar
Member # 8805
Interesting that one of the install facilities is in a state (my home state) that it would not pass inspection in.
If someone from PA has RR do the install does it come with free inspections for life and guaranteed to pass inspection every time?
BenFoo is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 12:23 AM   #23
Matt Wright
Matt Wright's Avatar
Member # 11064
9,800 for the kit
2,800 for the trans
19,400 grand total.
this. ?
__________________
AKA: "American"
Pile of parts waiting for a JK: 5.3, tons, coilovers, 43's, etc
'05 Ram CTD: 6spd, 4-link, 37" Bajas, TWF H1's, etc
Matt Wright is offline   Reply With Quote Quick reply to this message
Old 07-06-2011, 07:08 AM   #24
crash
crash's Avatar
Member # 1743
$9,800 for the conversion kit
$2k - $3k for a 4BT engine - Actually some guys are picking up entire 4BT bread trucks for $2k
$2,600 for the trans - this was the price stated in the first post
14,400 - 15,400 grand total
__________________
717.262.3079
Old 07-06-2011, 07:26 AM   #25
randyb
Member # 9343
I wish I had the money to do this. It seems like alot of money, but considering I have over 10k in my Jeep now and haven't even touched the engine the 20 k for the project seems cheap.
__________________
2010 SURF BLUE JK UNLIMITED. 4" TERAFLEX FULL FLEX LIFT, SMITTYBUILT FRONT AND REAR BUMPERS, SMITTYBUILT 10K WINCH, SMITTYBUILT ROCK SLIDERS, BUSHWACKER FLAT FENDERS, 35" PROCOMPS ON 17" ADDICTS, 513 GEARS, HELLA LIGHTS AND TANTRUM LIGHTS UNDERNEATH.
randyb is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
