Airbag light will not go off! Problem? - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Electrical & Lighting Tech Dept.
Old 04-19-2011, 11:23 PM   #1
nootherride
nootherride's Avatar
Member # 11644
So about two days ago this light came on (see pic)
It comes and goes with bumps or turning it seems..
My concern aside from driving me crazy is.. My airbag system malfunctioning or god forbid deploying.. Any input would be great! Or at the very least how to just turn the light/chime off!
Attachment 33317
__________________
Black 2008 x ,Dana30 Aussie locker,Teraflex C gusset's 2.5 Pro comp coils,Adj Rancho Rs9000's JKS quick disconnects,Jks Adj trackbar, 35.13.50.15 Toyo MT's on 15x8 MB Razors, K&N intake,Superchips, Magnaflow muffler,Optima Red top, Poison spyder ricochet rock rails,Solid diff covers, front Mopar rock bumper chopped, HD D-rings,Xrc 8000 winch, HOGG cut fenders!Bedlined interior, 130 watt kc slimlites
nootherride is offline   Reply With Quote Quick reply to this message
Old 04-19-2011, 11:25 PM   #2
StubEXrube
StubEXrube's Avatar
Member # 1473
I think it's your clock spring going bad/ shorting out. Dealership may be the solution.
What's up with the CEL?
__________________
StubEXrube is offline   Reply With Quote Quick reply to this message
Old 04-20-2011, 12:48 AM   #3
nootherride
Member # 11644
ya thats what i been reading....i absolutely hate going to the dealer for anything but safety is a big thing....i guess another issue is there is no dealer up here(closed) i think there might be one 30 miles north but what a pia!
ya sorry for the bad cell pic..
__________________
Old 04-20-2011, 01:11 AM   #4
StubEXrube
StubEXrube's Avatar
Member # 1473
Oh....I meant that your check engine light was on.
__________________
Old 04-20-2011, 01:19 AM   #5
nootherride
Member # 11644
keys on engine wasnt running...it goes off after
__________________
Old 04-20-2011, 04:56 AM   #6
tjkoen01
tjkoen01's Avatar
Member # 10065
Attachment 33317
the light is on because it has detected a problem and your air bag(s) may not go off in the event of an accident. clockspring could be bad, but it is an expensive part to replace on just a guess. Have to take it to a dealer to diagnose.
__________________
2008 Rubicon
Rugged Ridge XHD Bumper w/Warn XD9000i
315/70/17 Cooper ST Maxx, No Lift
Superchips Flashpaq
Flow Daddy Headers
Gibson Dual Exhaust
tjkoen01 is offline   Reply With Quote Quick reply to this message
Old 04-20-2011, 12:28 PM   #7
nootherride
Member # 11644
See they would tell u it's bad just to make a couple bucks too..
__________________
Old 04-27-2011, 09:52 AM   #8
jk007
Member # 7341
Mine come on and it was a bad connection under the passenger seat, probably after some stuff was push to hard and broke a wire, have to replace the complete seat harness. Check engine isn't suppose to stay on if that's an airbag problem, the airbag light take care or those info
jk007 is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 10:06 AM   #9
rdhrd4
rdhrd4's Avatar
Member # 6573
this, check your connections under-seat. also, idk if jeep does this, but with fords, they will blink a certain number of times,
say blink 3 times, pause, blink 7 times... this is a code 37 which can be looked up, does it blink at all when you turn the key on? more than likely it will be a clock spring since you said when you turn the wheel, definately a dealership fix IMHO, although some have DIY'd it...
edit, you can also check the connection that is in the steering wheel, there should be a harness connection on the driver door side of the wheel, you may have to take off a small panel to see it, but check that as well, as this could cause a problem while turning...
__________________
I LIVE, I RIDE, I DESTROY, ANYTHING I GET BEHIND THE WHEEL OF
But you either support your troops or you are shit.
rdhrd4 is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 04:50 PM   #10
dtcc687
dtcc687's Avatar
Member # 5534
Mine turned off after I cleaned my connectors under the seat. With all the water that's always it my jeep I'm suprised it doesn't happen more often.
__________________
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 05:01 PM   #11
Muvovr
Muvovr's Avatar
Member # 7570
Could Be
Clock Spring
Seat Position Sensor malfunction
Airbag
I have replaced the Airbag $275 and the clockspring about $275.
Still have the light but no chime.......... Mine is a seat position sensor issue I have yet to resolve. BUT I AM WORKING ON IT !!!
__________________
My Parts need Parts.......
Muvovr is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 06:09 PM   #12
redneckjk
redneckjk's Avatar
Member # 5994
mine did this 2 years ago. dealer replaced the driver's seat (go figure) under warranty. started again in Moab last week intermittently.
they started by changing the passenger seat belt assembly, problem returned after a couple of days. then they changed the switch that controls that light, problem returned after a couple more days. then i got the new 2010 drivers seat ( in an 08 ) and fixed. until now.
redneckjk is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 06:51 PM   #13
johnmcd
johnmcd's Avatar
Member # 4881
Mine's been on since I flooded int interior and then ripped out the rugs. Although I kinda think it might be a clock spring issue, there is play in the wheel at the wheel to shaft connection. I have about 3/8" of front to back play at the top of the steering wheel, it knocks when i do it.
__________________
Ok We need to organize a "Strippers and Blow Trail Run" It can raise money for college scholarships
Raleigh Meet and Greet,
Check the thread ------------->
johnmcd is offline   Reply With Quote Quick reply to this message
Old 05-03-2011, 12:49 PM   #14
UGET IT
UGET IT's Avatar
Member # 10522
Check all of the connections under the seats...............Just installed PRP Recliners and no issues...........
__________________
Method Motorsports
Email:
UGET IT is offline   Reply With Quote Quick reply to this message
Old 05-03-2011, 12:55 PM   #15
nootherride
Member # 11644
Good call I'll have all the seats out ect in few weeks to bedline I'll check them all pretty good
__________________
Old 12-31-2015, 09:09 AM   #16
pacu44
Member # 11578
Smile
Originally Posted by Muvovr View Post
Clock Spring
Airbag
What was the resolution to this?
SEARCH feature used.
pacu44 is offline   Reply With Quote Quick reply to this message
Old 12-31-2015, 12:26 PM   #17
Tweak
Tweak's Avatar
Member # 33122
Clock Spring
Airbag
you bought your clockspring at the dealership I am guessing?
It's $100 less on amazon.
__________________
Billet 2013 2 door
Dana 60 front, 14 Bolt rear, ARB's, 5.38's, 37" Nitto Mud Grapplers, 3 link front and rear, 14" Sway-a-Way coilovers, Tom Woods 1310 front, Adams 1350 rear, PSC Hydro assist
Tweak is offline   Reply With Quote Quick reply to this message
Old 12-31-2015, 06:13 PM   #18
dahreno
Member # 26881
My airbag light is on also. If it is something I need to bring it to the dealer for, lifetime warranty will fix it. Of course I'll have to bring to the dealer twice to fix it. It's funny though, airbags and how we feel we need it. My old Jeep came with no seat belts, they weren't required back then.
dahreno is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
