C2116ľABS PUMP MOTOR SUPPLY LOW VOLTAGE. - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Stock JK Tech Dept.
Old 03-12-2011, 06:51 AM   #1
DataByte
DataByte's Avatar
Member # 3848
Question C2116ľABS PUMP MOTOR SUPPLY LOW VOLTAGE.
Jeep just started throwing this code.
Any thoughts on how to fix this or how I go about tracking down the problem?
Anyone have any experience with this?
On a related note, anyone know how to get the wiring harness off the ABS pump without breaking it? Thought I would start with checking that connection as it may have some mud or dirt in there.
__________________
Matthew D
2008 Silver Sahara
*Mention JKOWNERS.com for a 10% discount at checkout*
DataByte is offline   Reply With Quote Quick reply to this message
Old 03-12-2011, 10:38 PM   #2
TEXASKEV
Member # 112
Well, I haven't seen this one before. But a Google search found this:
"Essentially these codes mean there is insufficient voltage getting to the abs module. The most likely cause of this would be a blown fuse in the underhood fuse box. Fuse # XXXXX is a 50 amp fuse and supplies the voltage for the abs module.
At the module the power wire is tan/red in color and you can test it for voltage directly at the module if needed."
Hope that helps a little. It would be great if it was just a fuse!
__________________
TEXASKEV is offline   Reply With Quote Quick reply to this message
Old 03-12-2011, 10:42 PM   #3
TEXASKEV
Member # 112
More info... from the service manual:
This is a link that has a 'how to' diagnose this problem.
http://koehlercafe.com/subdomains/je...l/7c033333.xml
__________________
Old 03-13-2011, 03:00 AM   #4
guinness
guinness's Avatar
Member # 2753
I had that same problem and had to have the whole abs control module replaced.
Mine was caused by my house being hit by lightning and having the jeep parked against the metal garage door.
I'm guessing something else is causing your issues.
__________________
Rest In Peace Guinness. You will never be forgotten. My brother and my best friend
guinness is offline   Reply With Quote Quick reply to this message
Old 03-13-2011, 07:44 AM   #5
DataByte
DataByte's Avatar
Member # 3848
Smile
I swear to you I tried a Google search.. I always do.. I don't know how yours turned up this!! Apparently your searching skills are way better than mine.
Thank you for finding this for me.
Service manual??? There is a service manual online???
Why have I never heard of this before????
Wow.... At least your problem has a great story to go with it!
__________________
Matthew D
2008 Silver Sahara
Old 03-13-2011, 07:50 AM   #6
guinness
guinness's Avatar
Member # 2753
Yep A real good story, and a lot of other blown up electronics to go with it.
Thankfully insurance covered it or you would have seen the funniest JK for sale add ever.
__________________
Old 07-14-2012, 09:01 AM   #7
tomwilsonfl
Member # 22829
I am having the same problem with my 2009 Compass. The problem is intermittent, but the lights are on about 90% of the time. Same error that is mentioned here - ABS PUMP MOTOR SUPPLY LOW VOLTAGE.
The dealership wants to change the ABS module, and the pump since they'll be in there anyway, for almost $1,000.
Could this be something more simple?
My Compass is three years old this month, with only 42,000 miles on it.
I already had the battery, starter and alternator checked out... all good.
Edit: The worst part about this problem is that the car doesn't up-shift properly, so it drives horrible and dumps gas like crazy. :-\
Thanks,
Tom
tomwilsonfl is offline   Reply With Quote Quick reply to this message
Old 07-15-2012, 09:42 AM   #8
DataByte
DataByte's Avatar
Member # 3848
If there is a way around it, I don't know what it is. They changed my module and pump for about the same price.
Now my Sebring is doing the same thing... grrrrr
Thanks,
Tom
__________________
Matthew D
2008 Silver Sahara
Old 07-15-2012, 07:13 PM   #9
Demon
Demon's Avatar
Member # 18319
Thanks,
Tom
No, this is common, the reason is, not even chrysler has a decent pinpoint test for us Techs to follow... its dumb, but i swear, once all the wiring has been checked, the pinpoint test says replace ABS module and if the code returns, replace HCU.
Really?? yup... its called an guess.... so to combat that, Techs will sell both units. I have replaced two ABS modules, only to have the car come back days or weeks later with the pump failed...
I know it sounds bad, but to cover their ass, a Tech sells both. In that case, we (customers and Techs) have to blame the dumb ass engineers who cant give us a better pinpoint test
Demon is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
