Single person hardtop removal (2dr) - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Stock JK Tech Dept.
Old 02-06-2011, 11:09 AM   #1
binarypie
binarypie's Avatar
Member # 11090
I remember there being a thread somewhere on the internet of a guy who build this kind of shelf he could position behind his Jeep to slide his hardtop onto.
This would allow him to remove the hardtop without having to find someone else to help.
I can't seem to find the thread.
Does anyone have it bookmarked or how to find it?
Thanks!
__________________
Info:
binarypie is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 12:13 PM   #2
yelorubi-EVA
yelorubi-EVA's Avatar
Member # 4055
Accident?
Is it possible the OP'er scummed to injuries sustained when the top fell on him??? Seriously.... if you had the room for such a platform; it would probably work well.
__________________
6" FTLA w/HD TB & SS,
JKS spg rets., rr spg mnts.
37" BFG KM2, 17x9 MT clssc II, Blstn 5100,
Finishline West RB, LoD FB, SB XRC10
PP mod'fd boat sldrs, ARB rr DC's, TERA 44 frt xl hsg,
Sup'r CrMo xls, 5.13 R&P, Reel 1310 DS,
Kilby Evap, Bnchmrk KISS, B&M Trans culr,
sPOD; Aeroforce, FlashPac, Airaid CAI, Magnaflow relo,
Cobra 75, 4' Firestik, Woods Hood & TG holds
yelorubi-EVA is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 12:19 PM   #3
binarypie
binarypie's Avatar
Member # 11090
I do have the room for one. My house was built in 1940 and thus my Jeep is actually too tall to even drive into the garage. So no hoist for me.
Looks like I'll be flexing my fabrication skills.
__________________
Info:
Old 02-06-2011, 01:25 PM   #4
gold knight
gold knight's Avatar
Member # 1460
I remember that shelf. Have you checked the write-up index? I'm on a phone or i would search for it.
__________________
gold knight is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 02:57 PM   #5
RRauzer
Research, bro!
RRauzer's Avatar
Member # 12652
Charles, you're a big guy, just put your back into it! Nah, I know what you mean with it being a PITA doing it by yourself. My garage is too low to drive in and use a hoist also. Let me (us) know if you find that thread - come summertime mine comes off too! Gotta build a dolly/cart for it to rest on and move to the backyard then too...
Or... host a jeep night! Just saying...
__________________
"Are you gonna bark all day, little doggy, or are you gonna bite?" - Mr. Blonde
A proud part of the Cutts!
RRauzer is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 05:28 PM   #6
binarypie
binarypie's Avatar
Member # 11090
Indeed! But today was one of those days I would have loved to just take the top off!!
Anyway. I found the link on the evil forum
http://jk-forum.com/showthread.php?1...-removal-ALONE!
Originally Posted by Sgt P View Post
Here's an easy way to get the Hard Top off by yourself. This is for those of us without garages or carports for hoists and pulleys...
A couple of assumptions:
1. You don't have a bad back.
2. You can lift 100 lbs over your head.
3. Doing this wrong can lead to bad things (dropped top, scratched paint, bad back or knees, etc.)
With that out of the way...
First I built a table the same height as the top of the tailgate using 4x4 legs, 2x12 tabletops, and 2x4 cross braces.
I went 6" longer/wider than the top in any direction. Also the U-shape allows plenty of room to manipulate the top:
I added a caster to the rear of the back leg, about an inch off the ground.
This makes it easy to tilt the table back and roll around.
I painted the top and edges with a Plastic Coating paint. Weather protection and a little protection against rubbing...
Backed up the Jeep to the table:
I got in the back of the Jeep and facing the rear. I get on my knees and find the balance point of the top with my hands spread as far as possible without losing lifting strength.
Practice the lift, this is where the scratches or dropping could happen.
I lift and move the top toward the table a few inches at a time:
Watch the "posts" as you move to the rear. That part of the top is wider than the rear, so scratching and/or losing the balance of the top is possible.
When more of the Hardtop is on the table than on the Jeep, I "climb" into the middle of the U-shaped table and lift to the final resting spot. Climbing in is easy due to the wide areas between cross braces.
When done the top should have 6" on all sides.
This will also make it easy to clean the interior of the top, etc...
Wood logic: 2x4's are not 2"x4", now for some measurements...
The U-Shaped "table top" is 2x12's (1.5"x 11.25") :
(2) sides - 48" long
(1) back - 48.5" long (probably could have done another 48", but that's how it worked out)
back measurement = 71" across the "bottom of the U" (11.25" + 48.5" + 11.25")
(4) legs - 44.5" tall (this dependes on your tailgate height!) 44.5+1.5"top=46"tall
The legs are "centered" on the top. Approx 4" (3.87"exact) from the edges.
The 2x4 braces lengths are dependant on your leg placement. And the angled pieces can be just about any length as long as they are cut to a 45 degree...
__________________
Info:
Old 02-07-2011, 06:16 AM   #7
BeerMonkeY
BeerMonkeY's Avatar
Member # 148
thats a 4 door top in the pics. i could lift my 2 door top off by myself, on i didnt try.
__________________
'91 YJ-woods beater-lift and stuff
'98 ZJ-5.9 lowered street jeep
'13 WK2-5.7 daily tow pig
BeerMonkeY is offline   Reply With Quote Quick reply to this message
Old 02-07-2011, 07:43 AM   #8
binarypie
binarypie's Avatar
Member # 11090
The concept is the same. I can lift my 2dr just fine on my own. The problem is if I trip or anything else I'd probably end up dropping it.
If I was to build a shelf like this I could slide/move the top a little bit at a time. with far less risk of dropping it.
__________________
Info:
Old 02-07-2011, 11:24 AM   #9
WTFool
Member # 11741
I too do not have room in my current garage for a hoist.
I had thought of something similar to a floor jack that would roll beneath the jeep with a tall leg coming off of it that has a pivot point on top that would be able to lock once you've lifted the top high enough to clear.
i'll whip something up in MS paint. This should be epic bad!
err must find image hosting site not blocked here @ work lol
lol see post below, it is bad but it's the general idea. The pivot point will obviously have to be longer and there would have to be a wide base at the end of the lifting arm to balance the hard top but once it's stable and up it should be fine!
WTFool is offline   Reply With Quote Quick reply to this message
Old 02-07-2011, 11:35 AM   #10
WTFool
Member # 11741
let me try this again
Old 02-07-2011, 12:04 PM   #11
gold knight
Member # 1460
You just gave me an idea. I could make an adapter for my engine lift to raise it up.
__________________
Old 02-07-2011, 12:55 PM   #12
binarypie
binarypie's Avatar
Member # 11090
I was thinking about this as well.
__________________
Info:
Old 02-11-2011, 10:36 PM   #13
Sahara Desert
Member # 12703
maybe one could use old hockey pucks, drill holes, and let those pins sit in the pucks, allowing you to really slide the entire top back and forth.
Sahara Desert is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
