ABS,ESP,BAS fuse? - JKowners.com : Jeep Wrangler JK Forum
Old 01-15-2011, 04:01 PM   #1
Reflux
Reflux's Avatar
Member # 11316
ABS,ESP,BAS fuse?
i know i can cut the purple wire with a light blue stripe under the dash to turn all of the extra BS off. i remember reading there should be a fuse i can pull to do the same thing. i tried searching no luck.
anyone know if there is a fuse i can pull to turn off the abs/esp/bas?
btw please don't post because you think this is dangerous i don't care!!!
thanks
__________________
Rusty's 3.25 lift
35x12.5-15 bfg km2
15x8 soft eights
cut front stubby bumper
rough country winch plate
harbor freight 8K winch
Lincoln rear locker
aussie front locker
spal fan
Reflux is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 04:11 PM   #2
tkob1060
tkob1060's Avatar
Member # 5021
http://www.jkowners.com/forum/showthread.php?t=22584
J6
__________________
tkob1060 is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 04:18 PM   #3
Reflux
Reflux's Avatar
Member # 11316
yeah i saw that but which one? probably not m37 because of the fuel pump rly. so what about the other two? anyone know?
M37
10 Amp Red
Anti-Lock Brake System (ABS) , Electronic Stability Program (ESP), Stop Lamp Switch (STP LP SW), Fuel Pump Rly Hi Control
J6
40 Amp Green
Anti-Lock Brake System (ABS) Pump/ESP
J7
30 Amp Pink
Anti-Lock Brake System (ABS) Valve/ESP
__________________
Rusty's 3.25 lift
35x12.5-15 bfg km2
15x8 soft eights
Lincoln rear locker
aussie front locker
spal fan
Old 01-15-2011, 05:37 PM   #4
flipity
flipity's Avatar
Member # 4900
J6. Lights (esp/abs/etc..) will stay on for a few min after you put it back in. Did it a few days ago in the snow in a nice unplowed open parking lot. so much fun.....
flipity is offline   Reply With Quote Quick reply to this message
Old 01-16-2011, 04:02 PM   #5
styx
styx's Avatar
Member # 3282
keep in mind, once your ABS and ESP is gone you will lose cruise control
__________________
Two is one and one is none... Fire in the Hole
styx is offline   Reply With Quote Quick reply to this message
Old 01-17-2011, 05:57 AM   #6
Reflux
Reflux's Avatar
Member # 11316
i don't have cruise control...
__________________
Rusty's 3.25 lift
35x12.5-15 bfg km2
15x8 soft eights
Lincoln rear locker
aussie front locker
spal fan
Old 01-17-2011, 06:14 AM   #7
militaryman4455
militaryman4455's Avatar
Member # 8813
why not just do the little video game/dance combination thingie and cut off the esp? Why do you want the ABS off? Im asking because I turned off the ESP like that and have had no problems since of the sort...
__________________
Mod..Wheel..Break..Repeat
Criminals prefer unarmed victims:Μολὼν λαβέ
I think I understand your question - but I am a two door guy.
militaryman4455 is offline   Reply With Quote Quick reply to this message
Old 01-17-2011, 09:46 AM   #8
Reflux
Reflux's Avatar
Member # 11316
i want the "BAS" off, i went through my rear brakes at 10K and i welded my rear, i want to see if turning off everything increases my mpg. also, i don't like abs when playing in the mud. i did do the dance to turn off the esp when i first got the jk.
__________________
Rusty's 3.25 lift
35x12.5-15 bfg km2
15x8 soft eights
Lincoln rear locker
aussie front locker
spal fan
Old 01-17-2011, 09:51 AM   #9
militaryman4455
Member # 8813
What exactly is the BAS? You welded your rear gears? wouldnt that cause some problems on the street?
__________________
Old 01-17-2011, 10:14 AM   #10
tkob1060
tkob1060's Avatar
Member # 5021
M37
10 Amp Red
J6
40 Amp Green
J7
30 Amp Pink
I posted J6 because IT IS J6, I've done it for a couple years
__________________
Old 01-17-2011, 10:26 AM   #11
Reflux
Reflux's Avatar
Member # 11316
isn't bas like a brake assisted cheap mans locker? since i welded mine i don't need it AND i went through my rear brakes with in 10K, thats a lot of brake dragging! i just want to see if there is any improvement on mpg and brake wear... i haven'd had any big problems on the street.
__________________
Rusty's 3.25 lift
35x12.5-15 bfg km2
15x8 soft eights
Lincoln rear locker
aussie front locker
spal fan
Old 01-17-2011, 10:29 AM   #12
militaryman4455
Member # 8813
So your rear tires dont chirp and shit when you go around corners? Since they are welded doesnt that make them locked all the time? When you turn your inner tire would not spin at the same speed as your outer, but with your locker it should cause it to keep them spinning at the same speed.
__________________
Old 01-17-2011, 10:43 AM   #13
Reflux
Reflux's Avatar
Member # 11316
yeah the rear tires chirp around corners with the diff welded. yes they are locked all the time which means the rears are always spinning the same speed. which also means i don't need BAS, which also means i shouldn't have gone through rear brakes so fast either.
__________________
Rusty's 3.25 lift
35x12.5-15 bfg km2
15x8 soft eights
Lincoln rear locker
aussie front locker
spal fan
Old 01-17-2011, 11:01 AM   #14
militaryman4455
Member # 8813
And you arent worried about breaking shit with that constant stress on the rear axle?
__________________
Old 01-17-2011, 12:12 PM   #15
Reflux
Reflux's Avatar
Member # 11316
well 10K on the rear axle no problems yet also got 35's on the jk...
now watch my diff explodes today...
__________________
Rusty's 3.25 lift
35x12.5-15 bfg km2
15x8 soft eights
Lincoln rear locker
aussie front locker
spal fan
Old 01-17-2011, 02:43 PM   #16
militaryman4455
Member # 8813
Lol, I thought the same thing when I was at 10k... Then I broke a front axle shaft at 17000.... Just food for thought.
__________________
Old 01-17-2011, 05:44 PM   #17
Reflux
Reflux's Avatar
Member # 11316
yeah i already changed my axle u joints already...
__________________
Rusty's 3.25 lift
35x12.5-15 bfg km2
15x8 soft eights
Lincoln rear locker
aussie front locker
spal fan
Old 01-17-2011, 05:46 PM   #18
Reflux
Reflux's Avatar
Member # 11316
oh yeah thanks about that... oops missed that...
__________________
Rusty's 3.25 lift
35x12.5-15 bfg km2
15x8 soft eights
Lincoln rear locker
aussie front locker
spal fan
Old 01-17-2011, 05:59 PM   #19
jk_ed
jk_ed's Avatar
Member # 10909
I pulled j7. Worked good for me.
__________________
07 black unlimited. 5.5" rock krawler x factor long arm. Pro comp soft 8s, 37" nitto mud grapplers. Kilby front winch bumper. Warn xd9000i. OrFab rear bumper. Much more to come in the near future.
jk_ed is offline   Reply With Quote Quick reply to this message
Old 01-17-2011, 09:17 PM   #20
THECHAD
JEEP...its my way of life!!!
THECHAD's Avatar
Member # 3913
what is this dance, where can I find it????
__________________
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
now just kicking it as a civilian
I served so your lazy ass didnt have to
THECHAD is offline   Reply With Quote Quick reply to this message
Old 01-18-2011, 01:01 AM   #21
styx
styx's Avatar
Member # 3282
your trying to improve your MPG by disconnecting electronics and welding your diff?? im sorry but your going to use more gas (more power to make turns) and your going to spend a but load more cause your going to need new tires 3x faster. trust me my rear diff locked and i just about went through a set of tires in a month it took to get a new axle... have fun, but i dont understand your logic
__________________
Old 01-18-2011, 04:39 AM   #22
gold knight
gold knight's Avatar
Member # 1460
In the write-up library
http://www.jkowners.com/forum/showthread.php?t=42181
__________________
gold knight is offline   Reply With Quote Quick reply to this message
Old 01-18-2011, 05:16 AM   #23
militaryman4455
Member # 8813
Thats what I was thinking... Why not just put a cheap lunchbox in the front axle and leave it at that? Or even a lunchbox in the rear would be better then welding the rear.
__________________
Old 01-18-2011, 05:54 AM   #24
Reflux
Reflux's Avatar
Member # 11316
well mpg is not a concern i'm just curious to see if disabling BAS would help and would disabling the BAS help with rear brake pad wear. the baseline for mpg is with a welded rear since i welded the diff when the jk had 500 miles on it. as for the welded rear i wheel the jk more then drive it on the street, and don't tell the girlfriend but if i have to buy tires more often THAT WOULD BE GREAT! and i do have a aussie locker in the front diff. when i welded it they didn't make a lunch box for the rear that would fix.
__________________
Rusty's 3.25 lift
35x12.5-15 bfg km2
15x8 soft eights
Lincoln rear locker
aussie front locker
spal fan
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
