Rear Spring issue - JKowners.com : Jeep Wrangler JK Forum
Old 12-24-2010, 01:06 PM   #1
peanut
peanut's Avatar
Member # 4440
Rear Spring issue
I just installed the RK 3.5 x factor and I am having an issue with the spring on the rear driver side. The top portion has a rubber seat where it sits on the body and when i went to flex to check clearances is shifted...
Any ideas on how to deal with this? Has anyone seen this before?
peanut is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 01:28 PM   #2
redx08
redx08's Avatar
Member # 5731
Did you have the coil seated correctly before you flexd it out. If so how long are your shocks. You can get the currie shock retainers to keep it in place.
__________________
08 jk unlimited X
1 ton axles
39.5 Iroks
redx08 is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 03:55 PM   #3
GreenJK
Member # 6997
Teraflex spacer/guides
Limiting Straps
Coil spring retainers
GreenJK is offline   Reply With Quote Quick reply to this message
Old 12-25-2010, 10:44 PM   #4
wsoffroad
wsoffroad's Avatar
Member # 10770
Feedback: 12 reviews
What has happened is that the shocks have more droop than the spring will allow for. This causes the spring to come unseated. The best thing to do is jack the rear of the jeep up to see when the axle is a full droop how far the top of the spring is from the coil pad. I would limit the shock travel with limiting straps. Doing this will increase the longevity of your shock to keep them from bottoming out when at full articulation.
__________________
Rock Krawler, Poison Spyder, Rigid Industries, Currie and more.
OR CALL 813.361.0869
wsoffroad is offline   Reply With Quote Quick reply to this message
Old 12-25-2010, 11:51 PM   #5
RODICON
30 Years of Rockin!
RODICON's Avatar
Member # 2233
Go with Teraflex retainer/ spacer.
__________________
2014 Rubicon on the build!
RODICON is offline   Reply With Quote Quick reply to this message
Old 12-25-2010, 11:53 PM   #6
peanut
peanut's Avatar
Member # 4440
I didn't even have it at full droop. This happened with very little flex as I was just looking to check clearances and both springs shifted. I could completely understand if I had drooped it enough for the springs to come out and them not seat back in the right spot.
Right now I think the Currie set up is the way to go, I never had this issue on my 2 door.
Old 12-25-2010, 11:57 PM   #7
peanut
peanut's Avatar
Member # 4440
They lost me as a customer...
Old 12-26-2010, 12:21 AM   #8
charles
charles's Avatar
Member # 8233
TF lost you as a customer but RK keeps you even though the kit you installed led to a spring falling out the minute you flexed, and not even at full flex?
You'll have to explain that.
Did you get it re-seated?
charles is offline   Reply With Quote Quick reply to this message
Old 12-26-2010, 09:02 AM   #9
Absolute Offroad
Member # 774
Dont limit the shock travel, as that really counter productive to what we are trying to acomplish here. use the currie Spring retainers and enjoy the flex from the RK kit. Problem is with the JK not any of the kits. The unseated spring length thats available for low height lifts is not enough to let it flex properly without the spring coming un seated. Not a big issue, just fix it and forget about it. RK is going to be more noticeable because these kits flex so much compared to the others.
__________________
Thanks!!
Joe Daro
Absolute Offroad
07 JK Rubicon with a "few" Mods....and NO!, My ESP light IS NOT ON!
Absolute Offroad is offline   Reply With Quote Quick reply to this message
Old 12-26-2010, 09:11 AM   #10
charles
charles's Avatar
Member # 8233
What makes you think RK flexes more than TF? It's an honest question...not an attack. The only reason I haven't popped a spring is because TF puts the correct spring retainers in their kit.
Old 12-26-2010, 12:48 PM   #11
peanut
peanut's Avatar
Member # 4440
Bottom line: I am one of those people who value customer service. I have had bad luck with TF product on more than one occasion (with TJ's) and there customer service wasn't any better. I wasn't looking to make this a bash TF thread, I am looking for other options besides TF spacer.
That being said.
The problem with the springs is a JK problem this could happen with any lift and yes, it would have been nice to have something come in the lift kit to fix this issue but I don't see it as the end of the world.
Springs can be re-seated it was a PITA with the way this happened. This is my first 4 door so I didn't realize it was a problem. I was curious to know what others are doing to fix the problem.
Old 12-26-2010, 12:53 PM   #12
peanut
peanut's Avatar
Member # 4440
As for Flex I have the RK shocks which allow more travel than most. I think the shock you run has more to do with it than TF or RK, mid arm lift compared to a mid arm...
Old 12-26-2010, 12:58 PM   #13
peanut
peanut's Avatar
Member # 4440
Have you used the Currie kit? Does clamping it off on both ends limit anything? I figure the weight of the axle would still allow it to flex just as much but I have never seen a spring clamped on both ends off-road.
Does anyone have pics of the Currie Kit in action?
Old 12-26-2010, 01:16 PM   #14
redx08
redx08's Avatar
Member # 5731
I used the currie spring retainers and just used the top portion of the kit. That way I could have full flex and the spring would seat correctly on the bottom every time. The bottom of the spring might come off, but when the axle starts to travel back up the spring will go right where it is suppose. keeps the spring in place and allows full travel.
__________________
08 jk unlimited X
1 ton axles
39.5 Iroks
Old 12-26-2010, 08:32 PM   #15
PIG
PIG's Avatar
Member # 119
I think the solution is simple. You need to run a spring with more travel. Have you take a look at THESE?
__________________
USE CODE: JKOWNERS FOR 10% SAVINGS ON YOUR NEXT ORDER!!!
PIG is offline   Reply With Quote Quick reply to this message
Old 12-27-2010, 09:56 AM   #16
Rock Krawler Suspension
Member # 4318
Peanut
Our shocks have a large amount of travel in them and there is no spring out on the market that will allow you to use all the travel without some tricks. Unfortunately, we do not limit the suspension droop with out shocks. For people that like to use some tricks, they allow the coil to come unseated and then reseat similar to Absolute Offroads comments. We install and recommend limiting stress to prevent over extension of components and the shocks! If you would like, give us a shout. We will be more than happy to help you out.
RK
__________________
Better Products Through Innovation, Not Duplication!
The Originator of the Independent 3 Link System!
Rock Krawler Suspension is offline   Reply With Quote Quick reply to this message
Old 12-27-2010, 04:40 PM   #17
Miraz
Member # 7848
I've had similar issues (mine dropped out completely!) and experimented with the Poly Springs and found that whilst the PP springs didn't dislocate, they changed the balance between the front and rear suspensions....the front stopped flexing, and the softer rear did all the work. RK's spring rates seem to be significantly higher than PP's.
Ended up going back to the RK Springs, but using the Currie Retainers to keep everything in place.
Miraz is offline   Reply With Quote Quick reply to this message
Old 12-28-2010, 05:13 PM   #18
peanut
peanut's Avatar
Member # 4440
Do you use both ends?
I figure I am going to just use the top Currie retainer and add a long bumpstop on the bottom to help guide it home LOL Currie is closed until the 3rd of Jan so it may be a little bit before I get this installed and I will post up after.
Old 12-29-2010, 12:30 PM   #19
TeraFlex
TeraFlex's Avatar
Member # 1767
Sorry to hear that. I can tell you that our Customer Service Dept. has changed quite a bit in the last few years. PM your name and address to me and I will have CS send you a set of rear 1/2" coil guide/spacers for free.
__________________
1-888-837-2359
TeraFlex never left the market or the trail.
TeraFlex is offline   Reply With Quote Quick reply to this message
Old 12-29-2010, 12:38 PM   #20
austinjeepr
austinjeepr's Avatar
Member # 8185
Talk about stepping up to the plate!
austinjeepr is offline   Reply With Quote Quick reply to this message
Old 12-29-2010, 12:56 PM   #21
desert dog
desert dog's Avatar
Member # 7121
I'm using the TF coil retainers that came with the kit and have never lost a spring. My Fox shock set-up has lots of drop too. Id just use retainers like others have suggested.
desert dog is offline   Reply With Quote Quick reply to this message
Old 12-29-2010, 01:13 PM   #22
peanut
peanut's Avatar
Member # 4440
If this is the case than I suppose I should order the bump stops I need from you and cancel my other order...
Old 12-29-2010, 02:15 PM   #23
TeraFlex
TeraFlex's Avatar
Member # 1767
Sounds good to me!
__________________
1-888-837-2359
Old 01-04-2011, 07:43 PM   #24
peanut
peanut's Avatar
Member # 4440
I received the Tera spacers and lower retainers. I installed them tonight and so far this seems like it should work. I need to get it out and flex it around but at max droop the guide is long enough. I will post up once I get a chance to test this out but if it works it is an easy fix. I did not retain the stock rubber spacers so I believe the lift is in the same spot I will measure up and post updates on that as well.
I went with the Tera bumps for the top front and rear bottom as this sounds like what I needed for the lift.
Thanks to TeraFlex for there support and sending me the parts I needed. I even got a new hat!
Old 01-04-2011, 07:50 PM   #25
BenFoo
BenFoo's Avatar
Member # 8805
Another thing to keep in mind, if you adjusted your rear pinion angle properly your springs will have an affinity to bow under load and pop out when they are unloaded. This is because of the axle being rotated up for proper angle.
RK makes spring wedges that help alleviate the issue and keep the springs straighter.....your other option is to cut the spring perches off and re-weld them on in the proper spot.
BenFoo is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
