Cruise Control Problem - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Electrical & Lighting Tech Dept.
Old 12-10-2010, 07:15 AM   #1
erikprime
Member # 9013
2007 X
i hit the button, and nothing happens...wont turn on... aside from checking a fuse, anybody have any advice? has this happensed to anyone else?
erikprime is offline   Reply With Quote Quick reply to this message
Old 12-10-2010, 09:31 AM   #2
thisbejonas
thisbejonas's Avatar
Member # 9182
Mine does the same thing. I can turn the cruise on and the "cruise" light comes on in the cluster then hit the set button and it does nothing. Its a real PITA since I do alot of interstate driving.
thisbejonas is offline   Reply With Quote Quick reply to this message
Old 12-10-2010, 10:17 AM   #3
JK-Ford
Member # 3772
I have seen others on diffrent forums with the same problem. I think that the contacts on the switch are cheep. Pull the switch and use a meter to check?
__________________
"The Green Monster"
2007 2 Door X Jeep Green with Freedom Top
16" Painted Aluminum Mopar Wheels
Grab Bar Mod on front bumper
130w KC Daylighter Driving Beams on grab bar
130w KC Daylighter Long Range Beams
on
Smittybuilt Windshield Brackets
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline   Reply With Quote Quick reply to this message
Old 12-10-2010, 11:09 AM   #4
jeepRcreepR
jeepRcreepR's Avatar
Member # 7996
Are you having sensor problems (ESP, traction control type stuff). When I lifted my jeep my sensors would go crazy with every turn. Had a bad speed sensor which knocked out my whole cruise control.
__________________
07 JKU Rescue Green with 3.5" RK Mid-Arm Flex w/ Bilstein 5100s, 5.13's, Eaton E-Locker, 35" MT Baja ATZ, 17" DC Torque wheels, Monstalined tub, Home-made front bumper with Smittybilt XRC-8 winch, Wild Boar rack w/ IPF 968 lights, K&N Intake, Gibson Exhaust.
Future Mods: 2wd-4wd conversion = completed!
jeepRcreepR is offline   Reply With Quote Quick reply to this message
Old 12-10-2010, 11:39 AM   #5
thisbejonas
Member # 9182
No sensor issues on mine as it is basically stock right now.
Old 12-10-2010, 12:13 PM   #6
Fishyguy
Member # 2113
I just replaced my clock spring due to this exact same problem.
__________________
08 Detonator Yellow Rubicon-RE Arms-37" Mt/R's with Kevlar-Riddler Diff Cover-LoD stubby with Stinger-LoD stubby tire carrier-Warn M8000 Winch-Rigid D2's-20" Rigid Light Bar-SPOD-PS Rocker Knockers-PS Body Armor-5.13s-hydro assist-RCV shafts-IPF-Corbeau LG1 seats-12" King coilovers-AEV Hood-AEV Snorkel-5.7L VVT Hemi-AEV hemi Install Kit-4.5" AEV Springs-ProRock 44-AlloyUSA Rear shafts-Spyntech Hubs-Raceline Monters-
Fishyguy is offline   Reply With Quote Quick reply to this message
Old 12-10-2010, 12:25 PM   #7
thisbejonas
Member # 9182
Clock spring?
Old 12-18-2010, 09:57 AM   #8
mr_natural78
Member # 5441
I'm in that same boat at the moment. I think I have a bad ABS sensor. I'll go get it checked out eventually.
__________________
Doug
Valparaiso, IN
2007 Steel Blue X Unlimited
Rubi D44 up front with chromo shafts, riddler cover, and CTM u-joints
4" Frankenlift
black steel wheels
35" AT's
Rock Hard bumper and tire carrier
Nate's 4x4 frnt winch bumper
(custom chopped into a stubby)
Rubi rails
Rock Hard skids
KC 8" driving lights
KC 6" driving lights on KC windshield mounts
Tuffy console insert
mr_natural78 is offline   Reply With Quote Quick reply to this message
Old 12-18-2010, 12:32 PM   #9
zjr
zjr's Avatar
Member # 5296
My abs sensor wire got cut, and that killed my cc.
__________________
zjr is offline   Reply With Quote Quick reply to this message
Old 11-22-2012, 08:02 PM   #10
spryan81
Member # 15150
bringing it waaaaaaaaaaaaaay back from the dead but... Have any of you guys with the above listed problems had any dash lights come on to indicate bad wheel sensor etc? My cruise control stopped working but I've not no codes... Checked with both an OBDII and the ignition method and all of my fuses are fine... I replaced the switch and still nothing... I haven't checked the continuity of the clockspring yet but was hoping someone had another idea for me before I try that...
spryan81 is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
