WonTon - JKowners.com : Jeep Wrangler JK Forum
Old 11-14-2010, 01:40 PM   #1
Co4Lo
Coming Soon
Co4Lo's Avatar
Member # 4935
Thumbs up WonTon
Here we go...
Co4Lo is offline   Reply With Quote
Old 11-14-2010, 01:49 PM   #2
Goodysgotacuda
Goodysgotacuda's Avatar
Member # 4538
betty noice
__________________
'09 2dr Rubicon - 6spd | 37s | 4.88s | DIY PSC Ram | OR-Fab cage | Poly Cage | BFH Front | XRC Rear | XRC12 Winch | Walker Evans Beadlocks |
WannaBe Off Road Shop
Goodysgotacuda is offline   Reply With Quote
Old 11-14-2010, 02:30 PM   #3
outkast
Member # 11866
Very pretty!!!!
outkast is offline   Reply With Quote
Old 11-14-2010, 02:31 PM   #4
BBirish
Member # 5381
w00t w00t
BBirish is offline   Reply With Quote
Old 11-14-2010, 02:31 PM   #5
JohnnyWalker
Mindbender 1
JohnnyWalker's Avatar
Member # 2387
I was thinking soup...
YouTube - Angry Asian Restaurant Prank Call- OwnagePranks
__________________
JohnnyWalker is online now   Reply With Quote
Old 11-14-2010, 03:00 PM   #6
nlgrav182
If You Can Dodge a Wrench...
nlgrav182's Avatar
Member # 7834
Gelice. Betty gelice.
__________________
OKAY FUCKMOUTH.
nlgrav182 is offline   Reply With Quote
Old 11-14-2010, 03:18 PM   #7
redx08
redx08's Avatar
Member # 5731
Nice man. Dana 70 for the rear?
__________________
08 jk unlimited X
1 ton axles
39.5 Iroks
www.rivercityoffroad.com
www.offroadalliance.com
redx08 is offline   Reply With Quote
Old 11-14-2010, 03:28 PM   #8
levellinebrad
levellinebrad's Avatar
Member # 2703
thats nice.
__________________
I have a jeep and it goes over shit.
levellinebrad is offline   Reply With Quote
Old 11-14-2010, 03:46 PM   #9
SlvrJK
SlvrJK's Avatar
Member # 8383
Schweeet.
__________________
2008 JK X 2-door, 37" MTRK's, Xenon narrows, 2" Frankenlift, Prorock 44 front with 5.13's/rcv's/rubi locker, Rock Jock 60 rear w/ 5.13's and a Detroit, and lots of armor...
SlvrJK is offline   Reply With Quote
Old 11-14-2010, 04:57 PM   #10
Co4Lo
Coming Soon
Co4Lo's Avatar
Member # 4935
I was actually going to use a 99+ E350 Van HD60 rear. They are a gem.
They come with 35-spline axles, big bore spindles, 8 on 6.5 bolt pattern (not like the SuperDuty) big disc brakes, and have an ABS tone ring!! You can get them complete for around $500, so all you would need is gears, locker, and some brackets. This would be the most excellent choice for a JK 8-lug swap.
BUT......
I ended up with this, because I was lonely and needed a new BFF!
Old 11-14-2010, 05:00 PM   #11
paramaniac
Licensed Queef Taster
paramaniac's Avatar
Member # 5392
Lucky prick... Looks nice and a great idea!
In another note... What size wheels are on those jack stands? They look bad ass!
paramaniac is offline   Reply With Quote
Old 11-14-2010, 09:50 PM   #12
redx08
redx08's Avatar
Member # 5731
[QUOTE=Co4Lo;588466]I was actually going to use a 99+ E350 Van HD60 rear. They are a gem.
BUT......
[QUOTE]
Nice, im ready to see this under your jeep. What year is the front out of? It looks very clean. Maybe a mid to late 80's ford.
__________________
08 jk unlimited X
1 ton axles
39.5 Iroks
Old 11-14-2010, 10:12 PM   #13
RiverCityOffroad
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Member # 10936
Feedback: 52 reviews
Jon...could you...maybe for just a minute, take a break from the modding? You're making me exceedingly jealous.
What'd you do with the 44s?
__________________
The Wheelin Man's Friend -
River City Offroad.com
Email Me!
RCO on Facebook!
Call Me - 832-526-2415
RiverCityOffroad is offline   Reply With Quote
Old 11-15-2010, 05:57 AM   #14
Co4Lo
Coming Soon
Co4Lo's Avatar
Member # 4935
It's a 1989 F350. It has some light surface rust, but they painted it to protect it from the elements. I still have to sandblast it and prep it for welding.
The only issue with this era (as opposed to the '78-79) is that the short tube is VERY short. But not a factor if you run coilovers.
For coil applications, most people just cut away the leaf spring casting up to the leaf spring pin keyhole and make more room for coil buckets. Works like a charm.
Old 11-15-2010, 07:46 AM   #15
redx08
redx08's Avatar
Member # 5731
Originally Posted by Co4Lo View Post
It's a 1989 F350. It has some light surface rust, but they painted it to protect it from the elements. I still have to sandblast it and prep it for welding. The only issue with this era (as opposed to the '78-79) is that the short tube is VERY short. But not a factor if you run coilovers. For coil applications, most people just cut away the leaf spring casting up to the leaf spring pin keyhole and make more room for coil buckets. Works like a charm.
Yeah I plan on running coilovers with my super duty 60 because of the short tube. Well that's my excuse anyway. What's your plans for locker and gears?
__________________
08 jk unlimited X
1 ton axles
39.5 Iroks
Old 11-15-2010, 08:42 AM   #16
Co4Lo
Coming Soon
Co4Lo's Avatar
Member # 4935
FRONT:
5.38, ARB, 35-spline stubs, and maybe the stub hub conversion depending on the backspacing I use. Probably some Warn premium hubs, and keep some slugs in the toolbox.
REAR:
5.38, Detroit Locker, 35-Spline full floaters, Disc conversion, shaved diff.
Old 11-15-2010, 09:08 AM   #17
BenFoo
The Nose plays...
BenFoo's Avatar
Member # 8805
eh?
BenFoo is offline   Reply With Quote
Old 11-15-2010, 09:12 AM   #18
Co4Lo
Coming Soon
Co4Lo's Avatar
Member # 4935
eh?
Slug= Drive Flange, aka splined metal puck that replaces a lockout hub when it explodes.
Old 11-15-2010, 11:54 AM   #19
STUPIDFACE
Heat'n and a beat'n...
STUPIDFACE's Avatar
Member # 2880
Will you still have abs?
__________________
corey d
2008 JEEP...
STUPIDFACE is offline   Reply With Quote
Old 11-15-2010, 12:20 PM   #20
Co4Lo
Coming Soon
Co4Lo's Avatar
Member # 4935
No.
But I'm plotting a tone ring on the rear T-Case output with an adjustable sensor plate so that I can keep my speedo/odo functional. Not sure if/how it will work yet, but I'll figure something out.
I'm more concerned about the Odometer, since I can use GPS for speed.
Old 11-15-2010, 12:25 PM   #21
dconnole
dconnole's Avatar
Member # 7902
on your gussets- are the lines machined in or did you somehow bead-roll them in?
dconnole is offline   Reply With Quote
Old 11-15-2010, 12:26 PM   #22
sliv3r
Member # 4561
Nice i just did a one ton swap on my jk 4 door swaped to pasenger side drop and 7.17 gears in my d60 front and d70 rear and ags check out my thread
Yours is looking good what size tire syou plan on running
http://www.jkowners.com/forum/showthread.php?t=40031
sliv3r is offline   Reply With Quote
Old 11-20-2010, 07:49 AM   #23
Co4Lo
Coming Soon
Co4Lo's Avatar
Member # 4935
Got the truss completely burned on last night. It's 3/16 DOM with brake-formed 1/4" plate gussets.
Since the casting on the 14B is offset, the truss is made to be symmetrical with the casting, but the center of the axle is still on the center of the truss.
The truss it rotated forward to accommodate the proper pinion angle for my application.
The D60 knuckles sandblasted...Good as new!
D60 ready for stripping...
Old 11-20-2010, 07:55 AM   #24
weaver1371
Carpe Poon
weaver1371's Avatar
Member # 6411
Can't wait to see it finished!
__________________
WWW.DSIMETALS.COM
JKOutcast
weaver1371 is offline   Reply With Quote
Old 11-20-2010, 08:05 AM   #25
Mr.RonGilbert
Mr.RonGilbert's Avatar
Member # 3399
That is just plain sexy!
Mr.RonGilbert is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
