My horn isn't working... - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Electrical & Lighting Tech Dept.
Old 11-13-2010, 07:31 PM   #1
HoodJK
Member # 4783
I'm trying to fix my horn, but I can't seem to find the issue. So far I have...
- Checked the horn itself - Horn is good
- Checked to make sure the ground wire for the horn has continuity - Good
- Checked to make sure the power wire has continuity to the fuse - Good
- Checked each of the horn switches in the steering wheel work - All four good
- Checked for 12vDC when pressing the horn - Bad
Now I know there something broken between the fuse and the battery and the service manual says there is a horn relay somewhere in there that should be checked. However, it doesn't say where that relay is, nor does is show where it is in the wiring diagram. So my question is, where is this mythical relay located?
P.S. Having to wait 90 seconds between searches sucks.
HoodJK is offline   Reply With Quote Quick reply to this message
Old 11-13-2010, 07:45 PM   #2
Goodysgotacuda
Goodysgotacuda's Avatar
Member # 4538
Relay is built into the fuse box and not serviceable afaik. you did check the fuse right, doubled checked it was the right one? I know it's elementary, but youd be surprised how often that actually happens in a shop when one over complicates it.
Continuity doesn't mean much to me as far as a broken wire diagnosis. Which is Pretty unlikely unless you have varmits. Voltage drop test is much more accurate for wire diag
Complaining on the searching will go away if you donate to the site.
Now assuming you are out of warranty, I'd take that "good" factory horn trigger, and just wire in a new relay rather than replace the TIPM
__________________
Goodysgotacuda is offline   Reply With Quote Quick reply to this message
Old 11-13-2010, 08:13 PM   #3
HoodJK
Member # 4783
The fuse (M23) is good, there's just no power getting to the fuse when I press the horn. I forgot to mention that. I'll do a section by section check of the wires Monday since I would have to take it apart somewhere anyways to install a new relay. I'll have to take the airbag and display cluster out again though. Sweet... It had been a long time since I visited this site, so having to donate was new to me.
Old 11-13-2010, 08:44 PM   #4
Goodysgotacuda
Member # 4538
The fuse is before the relay. Therefore it should have power in and out of the fuse 100% of the time.
Power should only be changing to the actual horn when it is applied, the fuse will have 12v with the horn pressed or not..
__________________
Old 11-13-2010, 08:53 PM   #5
BBirish
Member # 5381
have you gone through any deep water recently? I had the horn go out on me but it just came back eventually a couple days later, guess it dried out.
PS buy a red star
BBirish is offline   Reply With Quote Quick reply to this message
Old 11-13-2010, 09:37 PM   #6
HoodJK
Member # 4783
I attached the wiring diagram I am using to check for continuity and voltage. It shows +Bat Terminal -> Electronics (relay?) -> Fuse -> Horn -> Ground. I know I have continuity between the horn and the fuse, so there's no closed relay between the two, and don't have voltage between the positive terminal and the fuse though. I believe I can eliminate the entire loop with the horn switch and connections leading to and from it if I check pins 26 and 27 on C7 for continuity while pressing the horn tomorrow. That will be a lot simpler than taking the instrument cluster and steering wheel apart.
@BBirish I haven't gone through water or mud recently (I hate water!), but I did check the horn by directly connecting it to the battery, that's how I know it works. Besides, I know it has to be a power problem since I'm not getting voltage at the horn when I press the switch.
I promise I'll get a red star next payday!
Old 11-15-2010, 10:18 AM   #7
Jun01
Member # 10949
I'm having the same problem with my horn. The horn itself works (checked my pressing the panic button on the key). I can only assume it's the clockspring. It's easy to get at but expensive and from what I've read it's a common failure.
Jun01 is offline   Reply With Quote Quick reply to this message
Old 11-15-2010, 10:22 AM   #8
talljeep
talljeep's Avatar
Member # 4291
Had the same exact problem with my JK, took it to the dealer for a recall and told them to fix that (still under warranty). It took them 30 minutes to do the recall and 3 FUCKING days to fix the horn!!! Still don't know what was wrong with it but its working now.
I think he said something about a electronic board of some sort, I was so pissed at the moment that I didn't really care what it was just wanted to get the hell out of there.
Gus
__________________
2008 JK Sahara 4" of lift, 2" BL, 37" M16's , rancho rear bumper, EVO C gussets and skids, PSC Evap Skid, SB Bumper w/stinger, 10000LB SB Winch, Aussie locker on front and a lot of spare axle shafts lol
CONFIDENCE is the feeling you have before you fully understand the situation.
talljeep is offline   Reply With Quote Quick reply to this message
Old 11-15-2010, 12:33 PM   #9
joeglock
joeglock's Avatar
Member # 3439
My horn quite on me a while back. dealer had to replace the clock spring in the column.
joeglock is offline   Reply With Quote Quick reply to this message
Old 11-26-2010, 02:13 PM   #10
Joneszj
Joneszj's Avatar
Member # 2793
So I am not at all familiar with all the horn talk above (clock spring???) and I have an issue with my horn. It isnt working at all. I removed the horn and went to replace it with another, and once it was hooked up, it worked for a brief second then shut off. The wires are all ok, the fuse is ok, and when I press the horn I can hear the power relay giving power. But, no sound. What gives? Do I have to go to a dealer or is there a way to fix this myself?
I'm way out of warranty.
__________________
2007 Graystone 2dr X
Joneszj is offline   Reply With Quote Quick reply to this message
Old 12-12-2010, 06:44 PM   #11
chileanjk
chileanjk's Avatar
Member # 11653
Did you fix this?
As I found the cable that connects 12v to the horn fuses in my JK shorted and cut, as soon as I repaired it, connected the battery and the horn goes off, then I found the clock spring it's the culprit of the cable fried, strange as the fuses were ok.
Now I have to buy a new clock spring
chileanjk is offline   Reply With Quote Quick reply to this message
Old 12-12-2010, 08:04 PM   #12
Joneszj
Joneszj's Avatar
Member # 2793
Mine still isnt fixed. I need to check the cable because as flimsy and junky as it is I wouldnt doubt if its ripped. My fuses look fine. Still need to get around to fixing this...
__________________
Old 12-12-2010, 08:43 PM   #13
ronjenx
ronjenx's Avatar
Member # 10975
Everything before the TIPM in the diagram above, is CAN bus communication.
A lot of mysterious things can go wrong there.
ronjenx is offline   Reply With Quote Quick reply to this message
Old 12-12-2010, 08:51 PM   #14
paramaniac
paramaniac's Avatar
Member # 5392
I've had two occasions where my horn failed.
First time the TIPM was replaced... Problem fixed.
Second time the clock spring was replaced, problem fixed. Turns out when I left the top down during a rain shower it caused a short of said clock spring.
Both times were easy fixes and covered under warranty
__________________
paramaniac is offline   Reply With Quote Quick reply to this message
Old 12-12-2010, 09:00 PM   #15
RubiZealot
RubiZealot's Avatar
Member # 6292
Wow, this is looking endemic. Mine is dead too. I need to test out whether power is making it to the horn, but I guess I'd be just as successful dropping it off at the dealership.
__________________
Mike 2010 Rubicon 2DR | RK 3.5 X FACTOR MID ARM | ΜΟΛΩΝ ΛΑΒΕ
RubiZealot is offline   Reply With Quote Quick reply to this message
Old 12-12-2010, 10:06 PM   #16
Joneszj
Joneszj's Avatar
Member # 2793
Must be nice to have a warranty.
__________________
Old 12-12-2010, 10:30 PM   #17
dickyB
dickyB's Avatar
Member # 2766
sounds like you guys need a new sticker:
__________________
I like driving my jeep around while wearing a suit....it says I'm formal, but I'm here to party.
dickyB is offline   Reply With Quote Quick reply to this message
Old 12-26-2010, 06:45 PM   #18
Heavy D
Heavy D's Avatar
Member # 12080
I do need that sticker. The first occasion that I had to use the horn was the other day when some a-hole cut me off. I went to lay on the horn and the dang thing didn't work. That just made me even more angry. So I guess I will check it out this week and see if I can find the problem. Sounds like the clock spring should be the first thing I check after the fuse. Anyone have some insight into how to get to it?
Heavy D is offline   Reply With Quote Quick reply to this message
Old 12-26-2010, 07:07 PM   #19
paramaniac
paramaniac's Avatar
Member # 5392
you shouldnt have put those big tires on, not only do they bend axles they void warranties
__________________
Old 12-28-2010, 08:23 AM   #20
chileanjk
chileanjk's Avatar
Member # 11653
You can get it using this guide: http://www.quadratec.com/Assets/Installation/75675.pdf
But you have to take out the steering shell out first, not pictured in the guide.
__________________
2007 Wrangler Diesel CRD, 35" Cooper discoverer, AEV 3.5" premium
Old 12-28-2010, 12:03 PM   #21
Jun01
Member # 10949
The clockspring wasn't the issue for me. After I installed it still no horn! I ended up buying a horn switch and that's what did it. Much cheaper than a clockspring too...
Needless to say I now have a good "used" clockspring for sale if anyone is interested.
Old 07-24-2013, 03:54 PM   #22
viperbluelx
Member # 19483
Originally Posted by chileanjk View Post
Did you fix this?
Which cable are you talking about? Just the wiring harness to the horn?
__________________
Rescue green 07 2-door on 35's
viperbluelx is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
