DIY jeep 1/4 ton style trailer parts..... - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > Approved Vendor's Showcase > Vendor's Marketplace
Old 10-13-2010, 05:20 PM   #1
Sierra 4x4
Sierra 4x4's Avatar
Member # 11747
http://www.sierra4x4trailers.com
I will be selling our Trailer Tub's, so you guys that want to can build your own trailers.
Cargo Box Dimensions:
41” x 72” inside floor dimensions.
49” x 72” inside top dimensions.
19” depth.
14 Ga. tub all welded together with floor and top support railing, bare steel will need prep work before primer & paint.
$895.00
Tub with all tie-down hooks welded in place and seam sealed, and sprayed with epoxy primer, and set of 12" jeep fenders custom built for me.
$1,195.00
Wider 4′ x 6′ Trailer: add $100.00
If you want a Tailgate it will be a Extra $300.00 wider frame $325.00
If you want a lid $995.00 or a frame, I can sell one of those too.
I take Credit Cards, Paypal, and Checks, plus good old cash.
I have some tubs in stock, if not its a 3-5 day build time.
PM me or find me here: http://www.sierra4x4trailers.com
or here: http://www.facebook.com/pages/Sierra...9998049?ref=mf
__________________
We are:
We also sell ARB 4x4 accessories, OR Fab, Trail Master Suspension, Rough Country suspension, Rock Krawler, Iron Rock Off Road, Rubicon Express, Rugged Ridge, Poly Performance, Trail Tools, Trailer DIY Parts including Tubs, and roof top tents
Sierra 4x4 is offline   Reply With Quote Quick reply to this message
Old 11-06-2010, 09:47 PM   #2
Sierra 4x4
Sierra 4x4's Avatar
Member # 11747
Tub Tubtime to build for spring time
__________________
We are:
Old 11-07-2010, 03:49 AM   #3
levellinebrad
levellinebrad's Avatar
Member # 2703
those are awesome
__________________
I have a jeep and it goes over shit.
levellinebrad is offline   Reply With Quote Quick reply to this message
Old 01-10-2011, 08:42 AM   #4
Sierra 4x4
Sierra 4x4's Avatar
Member # 11747
ttt
__________________
We are:
Old 01-21-2011, 12:33 PM   #5
usmcdoc14
Fistfull of Boomstick
usmcdoc14's Avatar
Member # 206
so what does shipping usualy run on these tubs? Or even the full trailers if you can ship them?
__________________
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 02-07-2011, 08:53 PM   #6
bmweight
bmweight's Avatar
Member # 4571
Are the tubs available in a DIY kit unwelded. Just the metal that has been cut out and bent into the correct shape?/
__________________
"Freedom through Strength"
bmweight is offline   Reply With Quote Quick reply to this message
Old 02-07-2011, 08:58 PM   #7
bmweight
bmweight's Avatar
Member # 4571
pm sent
__________________
Old 02-08-2011, 06:15 AM   #8
Jeep2.0
El Jefe
Jeep2.0's Avatar
Member # 11126
I definitelty like these & want to get one. Can you answer a few questions though?
I assume the narrow width most closely matches the JK?
What's the tub alone weigh? (Make one out of Aluminum??)
Is the lid steel or aluminum? Any gasketing? Photos of latch/lock?
The bare steel photos at the top looks like the tub & frame are integrated. Are they?
Is a Torflex axle available, w/ drop-style spindles? (To raise the axle CL)
Lastly: Subscribed!
__________________
2011 5.3L GM LC9 Aluminum LS V8 Conversion w/ Custom Dyno Tune
Aluminum Genright Bumpers Front & Rear - Aluminum Nemesis Rockers
PR44/RCV/Reid Front - Superior Rear - ORF Front / Poly Rear Cage - ORF Tire Carrier
RK 3.5" Springs - Fox 2.0 Adjustable Shocks - JKS Arms & Trackbars - Poly Steering
Jeep2.0 is offline   Reply With Quote Quick reply to this message
Old 02-08-2011, 10:36 AM   #9
Sierra 4x4
Sierra 4x4's Avatar
Member # 11747
Originally Posted by bmweight View Post
pm sent
Just replied..
Lastly: Subscribed!
The wider width tub size 48" x 72" matches the JK width with our 12" wide fenders that are long enough to fit a 38" tire.
The lid is 16 Ga cold roll steel with a 1" internal frame work to provide the structure needed to mount roof top tents or other gear. is has a 1/2" wide gasket material the we are updating the latches to a keyed one, but the old style photos are on the web site.
The tub and frame bolt together and have a gasket material between then so there is no chaffing issues.
We can build one with a Torflex system if you wanted.
You can see some more detailed photos on here.
__________________
We are:
Old 02-08-2011, 11:59 AM   #10
Jeep2.0
El Jefe
Jeep2.0's Avatar
Member # 11126
Thanks. Tub weight? Lid Weight?
Oh - and will your lid fit the M416?
__________________
Old 11-06-2011, 08:19 PM   #11
Calilove1
Calilove1's Avatar
Member # 11673
M416 Locking Lid
What would it cost to get a full locking lid (primer coat only) for the Military M416 Trailer shipped to 92694 (home) or 92656 (UPS Freight location)?
Calilove1 is offline   Reply With Quote Quick reply to this message
Old 11-26-2011, 11:09 AM   #12
Sierra 4x4
Sierra 4x4's Avatar
Member # 11747
Yes, the lid is 118 lbs
The lids for the M-416 are $900.00
__________________
We are:
Old 12-06-2011, 02:33 PM   #13
Sierra 4x4
Sierra 4x4's Avatar
Member # 11747
You can buy DIY parts online now, including 3/4" LED lights, Taillights, lids, fenders, Full leaf spring kits, Max-Couplers, etc.
Everything will be on there by midnight tonight.
http://www.sierra4x4trailers.com/cat...trailer-parts/
__________________
We are:
Old 06-04-2012, 12:57 PM   #14
bmweight
bmweight's Avatar
Member # 4571
Are these still available??? for the DIY guys....
__________________
Old 09-21-2012, 10:00 AM   #15
Sierra 4x4
Sierra 4x4's Avatar
Member # 11747
TTT
__________________
We are:
Old 09-21-2012, 11:54 AM   #16
bmweight
bmweight's Avatar
Member # 4571
Are these going to be available???
__________________
Old 09-21-2012, 11:55 AM   #17
Sierra 4x4
Sierra 4x4's Avatar
Member # 11747
We have some premade up shells in stock right now.
__________________
We are:
Old 09-21-2012, 12:19 PM   #18
bmweight
bmweight's Avatar
Member # 4571
pm sent.
__________________
Old 09-21-2012, 12:21 PM   #19
bmweight
bmweight's Avatar
Member # 4571
calling.
__________________
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
You may not post new threads
Forum Jump
