Dash Battery Light - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Electrical & Lighting Tech Dept.
Old 09-21-2010, 05:59 PM   #1
daspes
daspes's Avatar
Member # 5755
Dash Battery Light
Past several weeks i've had the charging system warning light on the dash. Last Wednesday Jeep wouldn't start. Checked the factory battery and it was bone dry. Topped it off with some water and jumped and rolled into work. During lunch picked up the only 34 series battery the Exchange had in stock. Installed and no warning light.
All was good on the world again.
Drove home and the damn light came on again a few miles from the house. Pulled into the drive and popped the hood to put an eyeball on the ground strap and the alternator was on fire!!! Cursed a few times and started calling around to find a new alternator. No one, not pepboys, napa, advanced auto, carquest, autozone, had them available yet from the supplier. A 2007 was just to new. The dealer would have to order it. Would take about a week and run $275. The Exchange could have it rebuilt by a local shop in one day for $140 so I went that route. Dropped it off the alternator on Thursday morning, picked up that afternoon, and installed it that evening.
Fired right up, no warning light. All was good with the world once again.
Drove to work Friday. Around town al weekend, to work again on Monday and this morning. The on the way home this afternoon the damn light comes back on!!! WTF!
So I've checked all the wires and the negative cable to ground. All wires appear to be good with solid connections. The battery and alternator shouldn't be the issue now that they have been replaced. What else should I be looking for?
__________________
daspes is offline   Reply With Quote Quick reply to this message
Old 09-21-2010, 06:20 PM   #2
JohnnyWalker
JohnnyWalker's Avatar
Member # 2387
Appears that maybe connections aren't always so solid, no?
__________________
JohnnyWalker is offline   Reply With Quote Quick reply to this message
Old 09-21-2010, 07:30 PM   #3
ronjenx
ronjenx's Avatar
Member # 10975
You have some serious chit going on there.
Did you check for fault codes? The charging system is monitored and will set codes.
Having the alternator rebuilt will not include the voltage regulator, as that is in the Powertrain Control Module. If it is bad, the PCM needs to be replaced.
Check for codes.
Check the charging voltage with a volt meter (engine running about 1,000 rpm, don't stand in line with the belt).
You may have to have the dealer hook up their scan tool to see what the charging system is doing.
ronjenx is offline   Reply With Quote Quick reply to this message
Old 09-21-2010, 07:32 PM   #4
daspes
daspes's Avatar
Member # 5755
No codes thrown at all. Ivechecked each time the lamp has come on.
__________________
Old 09-21-2010, 07:40 PM   #5
ronjenx
ronjenx's Avatar
Member # 10975
I added some stuff to my post before I saw your response.
Also, did you check for codes with a code reader? Checking the codes with the ignition key dance won't bring up all recorded codes.
Old 09-21-2010, 07:43 PM   #6
daspes
daspes's Avatar
Member # 5755
Codes were checked with a Aeroforce II gauge. The gauge also is showing my battery voltage at a steady 13.2 to 13.4.
__________________
Old 09-21-2010, 07:50 PM   #7
ronjenx
ronjenx's Avatar
Member # 10975
Sounds like a trip to the dealer may be your best bet.
Before you go, there are some things you can look at.
From the factory service manual:
To perform a complete test of the charging system, refer to a diagnostic scan tool. Perform the following inspections before attaching the scan tool.
1. Inspect the battery condition. Refer to 8, Battery for procedures.
2. Inspect condition of battery cable terminals, battery posts, connections at engine block, starter solenoid and relay. They should be clean and tight. Repair as required.
3. Inspect all fuses in both the fuseblock and Power Distribution Center (PDC) for tightness in receptacles. They should be properly installed and tight. Repair or replace as required.
4. Inspect generator mounting bolts for tightness. Replace or tighten bolts if required. Refer to the Generator Removal/Installation section of this group for torque specifications.
5. Inspect generator drive belt condition and tension. Tighten or replace belt as required. Refer to Belt Tension Specifications in 7, Cooling System.
6. Inspect automatic belt tensioner (if equipped). Refer to 7, Cooling System for information.
7. Inspect generator electrical connections at generator field, battery output, and ground terminal (if equipped). Also check generator ground wire connection at engine (if equipped). They should all be clean and tight. Repair as required.
Old 09-22-2010, 05:35 PM   #8
daspes
daspes's Avatar
Member # 5755
Dropped the JK off at the dealer this morning and picked her up at lunch. Ser ice writer said the negative battery cable was loose and that was the issue. That threw me for a loop cause I knew I tightened it good last night.
So pullout of the parking lot and Ding, on comes the light. Back to the dealership it went. After work picked up again, and the service writer says they couldn't reproduce the light and everything looks fine.
Start the jeep in the parking lot and there's the F'n light! Showed the service writer and his response was "dunno, tech said all everything checked out.".
Guess I'll try another dealership if the jeep doesn't burn to the ground before I can get it in.
__________________
Old 09-22-2010, 07:23 PM   #9
Badd Andy
Member # 4349
this happened to me on my old Ranger (I know its not a Jeep, but may be related), and turned out the voltage regulator was shot, I also noticed that the light came on under heavy acceleration
the dealership replaced the whole alternator and problem solved
__________________
Blacked out 07 JKUR, safari straps, Treadwright 35's on stock rims and Spydertrax spacers, stubbied front bumper, trimmed flares, 2" body lift, 2" spacers in front with 1" spacers in rear, Gen Right Tire carrier, more to come!
Badd Andy is offline   Reply With Quote Quick reply to this message
Old 09-22-2010, 07:25 PM   #10
daspes
daspes's Avatar
Member # 5755
I specifically asked them to triple check the voltage regulator on the second visit. The alternator was been replaced two days after the battery (which was replaced again this morning). So don't know, still no codes either.
__________________
Old 09-23-2010, 06:00 PM   #11
daspes
daspes's Avatar
Member # 5755
Update...
This morning no light.
At lunch, no light.
Trip home from work... Light. And a code!
P0622 generator field terminal circuit.
Any ideas?
__________________
Old 09-23-2010, 06:36 PM   #12
ronjenx
ronjenx's Avatar
Member # 10975
P0622-GENERATOR FIELD CONTROL CIRCUIT
Set Condition:
When the PCM tries to regulate the generator field with no result during monitoring. One Trip Fault. Three good trips to turn off the MIL.
Possible Causes
(K125) GEN FIELD CONTROL CIRCUIT SHORTED TO VOLTAGE
(K125) GEN FIELD CONTROL CIRCUIT OPEN
(K125) GEN FIELD CONTROL CIRCUIT SHORTED TO GROUND
GENERATOR
POWERTRAIN CONTROL MODULE (PCM)
Old 10-04-2010, 05:11 PM   #13
daspes
daspes's Avatar
Member # 5755
Update...
PCM was the cause, covered under the emissions warranty. Unfortunately the part is a week or two out...
__________________
Old 10-04-2010, 05:48 PM   #14
slacktide
slacktide's Avatar
Member # 7583
I hate electricity except it keeps my beer cold
__________________
37s on Raceline Beadlocks 5.38 Yukon Gears
slacktide is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
