towing boat with rugged ridge hitch - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK General Discussion
Old 08-12-2010, 08:57 PM   #1
jeepRcreepR
jeepRcreepR's Avatar
Member # 7996
Anyone pull a 4000 lb boat with the rugged ridge hitch...would I be ok?
__________________
07 JKU Rescue Green with 3.5" RK Mid-Arm Flex w/ Bilstein 5100s, 5.13's, Eaton E-Locker, 35" MT Baja ATZ, 17" DC Torque wheels, Monstalined tub, Home-made front bumper with Smittybilt XRC-8 winch, Wild Boar rack w/ IPF 968 lights, K&N Intake, Gibson Exhaust.
Future Mods: 2wd-4wd conversion = completed!
jeepRcreepR is offline   Reply With Quote Quick reply to this message
Old 08-12-2010, 11:06 PM   #2
kittisman
kittisman's Avatar
Member # 8801
It sounds like your over your tow rating to me.
__________________
'08 D. Yellow 2 dr 6 spd Rubi Hdtp. "The Mistress"
RR winch bumper w/ hoop
12,500 lb winch
Deadweight rear seat removed
kittisman is offline   Reply With Quote Quick reply to this message
Old 08-12-2010, 11:16 PM   #3
StubEXrube
StubEXrube's Avatar
Member # 1473
I would look into the Curt tubular hitch. It's rated at 4,000 lb GTW. They aren't that expensive either. Not sure but the Rugged Ridge is probably rated around 3,000-3,500 lbs. Not sure.
__________________
StubEXrube is offline   Reply With Quote Quick reply to this message
Old 08-13-2010, 07:07 AM   #4
Rugged_Ridge
Rugged_Ridge's Avatar
Member # 6727
It's rated to match what your Jeep is rated to pull....3500lbs for the 4door.
__________________
We Make Jeeps Rock |
Rugged_Ridge is offline   Reply With Quote Quick reply to this message
Old 08-13-2010, 06:37 PM   #5
jeepRcreepR
Member # 7996
I know it is rated at the 3500 lbs, but can it handle 4000 lbs for a short distance? Trying to help a friend out with getting his boat hauled somewhere
__________________
Old 08-13-2010, 06:58 PM   #6
TG426
TG426's Avatar
Member # 9272
are you towing it up a boat ramp? tow ratings are usually for straight line towing (like a camper or utility trailer) and usually do not take into consideration a slippery ramp. if not pulling it up a ramp, you should be able to get away with it if you go real slow and easy. I know a guy who tows a boat similar to mine (28' 8000lb Chris Craft - see my photo album) on a triple axel trailer with a Ford Crown Vic. which couldnt be rated for more than 4 or 5k lbs. Short distance, goes very slow and doesnt pull it up a ramp.
If one of those Home Depot rental trucks has a hitch/receiver, go rent it for the 19 bucks and save yourself from breaking something on the Jeep.
__________________
Tom
2010 Wrangler Unlimited Sport
ORH soft top, Procomp 7069's,Poly Performance leveling spacers
Goodyear Wrangler Duratracs, PSC Evap Skid, CB, Hi-Lift
TG426 is offline   Reply With Quote Quick reply to this message
Old 08-13-2010, 07:19 PM   #7
jeepRcreepR
Member # 7996
I don't know what kind of tow it will be but I just found out its only 150 yards and I'm only going to do it once. Probably up a ramp and back down to a different part of the bay. Thanks for the help. I'll let you know how it goes.
__________________
Old 08-13-2010, 08:23 PM   #8
leman
leman's Avatar
Member # 7573
go for it. ive pulled my buddies malibu that weighs 3900# without trailer or gear. pulled it through town to a different boat launch. took it out of the water and put it in. just took it nice and easy and put it in 4lo on the ramp
__________________
2008 steel blue sahara
with some doo-dads
leman is offline   Reply With Quote Quick reply to this message
Old 08-13-2010, 08:44 PM   #9
*FLPirate*
Member # 7595
You should be fine for that short of a distance. Just take it easy and don't hit your breaks to hard or your back end will start dancing around. Also, use 4lo when pulling out of the ramp. I have no problem towing my action craft that is about 2800# loaded with fishing gear and fuel and I a 2dr rubi.
*FLPirate* is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 05:04 PM   #10
jeepRcreepR
Member # 7996
Had to put the boat in the water and take it out. The Jeep handled very well. The boat is 4500lbs. Over all an awesome day to have the top off the Jeep and get out on the water.
__________________
Old 08-16-2010, 06:49 AM   #11
Rugged_Ridge
Member # 6727
Sorry... I did not know how far or how often you were planning to tow a 4500lbs boat. More worried about the JK than the hitch. For short pulls the hitch will have no issues. You should understand that in the world we live in we cannot legally give approvals that are more than the tow rate of the vehicle.
This goes for most manufactures these days... Don't flame us, it's all about not taking responsibility for your own actions these days.. It's someone else’s fault.... I was not warned enough to know better...
OK I'm off my soap box now....
__________________
Old 08-16-2010, 04:55 PM   #12
jeepRcreepR
Member # 7996
The reason I decided to do it was because you told me not too.
I love the hitch and wiring harness. It is a great product.
__________________
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
