What grease for door hinges? - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK General Discussion
Old 07-30-2010, 09:17 PM   #1
rockclimbermd
Member # 7611
I'm planning to take my doors off for the first time this summer... my jeep is an 07 that I bought this winter used. I am assuming that when I put the doors back on I should grease the hinges/pins to prevent corrosion. Can anybody tell me what's the best stuff to buy? Extra points if you can provide a link to a cheap supplier!!!! Who's bored?
Thanks!
Greg
rockclimbermd is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 09:18 PM   #2
TEXASKEV
Member # 112
Thanks!
Greg
Since the bushing in the body side hinge is nylon of some sort it probably doesn't need anything. But I just give it a little shot of LPS or WD40. I have a buddy who likes to put some anti seize but I think that's overkill.
__________________
TEXASKEV is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 09:27 PM   #3
jdubb75
jdubb75's Avatar
Member # 9749
My doors were hard to remove and the hinge pins were very dry so I just cleaned them and put a light coating of multi purpose grease on them. Seemed to do the trick. If it trashes the bushes I'll just buy some aluminum ones.
jdubb75 is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 10:13 PM   #4
Black09JK
Black09JK's Avatar
Member # 4800
I live in Western New York so I drive on salt covered roads for the better part of the year. My doors would be impossible to take off in the summer if I didn't lube the hinges on a regular basis. I just use a white lithium grease in a spray can. Small squirt in each hinge and wipe off the excess. It's worked good so far.
Black09JK is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 10:37 PM   #5
mckbrew
mckbrew's Avatar
Member # 10199
White lithium here too. The tube kind though. I don't take the doors off much, but they were a PITA before I greased them.
mckbrew is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 10:52 PM   #6
StubEXrube
StubEXrube's Avatar
Member # 1473
I prefer graphite on the plastic hinge bushings- doesn't attract dirt and debris. Works very well.
StubEXrube is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 11:52 PM   #7
Sunburst Sahara
Member # 7798
I use white lithium grease in the tube too, but only cuz I had it handy and my doors were a bitch to pull off at first.
__________________
No more Jeep
Sunburst Sahara is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 11:57 PM   #8
Rubydak
Rubydak's Avatar
Member # 2657
I use white lithium grease as well.
__________________
2008 Rubicon, 4 door Detonator yellow, 3.5" lift, Motech LS 6L engine conversion, RR Skids.
Rubydak is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 12:40 AM   #9
07unlimitedx
07unlimitedx's Avatar
Member # 2682
I take the doors off every couple of months in the winter and put some synthetic grease on them... come off easy every time.
__________________
07unlimitedx is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 01:13 AM   #10
PO'BOY
PO'BOY's Avatar
Member # 8886
x2
PO'BOY is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 05:00 AM   #11
insanitize
insanitize's Avatar
Member # 1978
I use marine grade bearing grease (because it's always in my toolbox) never had any problems installing or removing my doors.
__________________
07 Rubi rescue Green
"The previous explanation is based on my historically bad memory of a conglomeration of past experiences and conversations. The opinions above probably have some kernel of truth to them but the details are most likely flawed on some level. Please acquire further help from experts before listening to anything I say."
insanitize is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 07:00 AM   #12
nourlmt
nourlmt's Avatar
Member # 2116
ptfe synthetic teflon doesn't collect dust
__________________
got Jeep got stuff, never enough of the right stuff tho
Am I in deep enough yet?
nourlmt is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 10:38 AM   #13
Badd Andy
Member # 4349
you guys will probably laugh at this one, but I use Vaseline (petroleum jelly) and apply it with a Q-tip and so far it has yet to fail me on two Jeeps, super cheap, and the tub (small one) has lasted 6 years so far
__________________
Blacked out 07 JKUR, safari straps, Treadwright 35's on stock rims and Spydertrax spacers, stubbied front bumper, trimmed flares, 2" body lift, 2" spacers in front with 1" spacers in rear, Gen Right Tire carrier, more to come!
Badd Andy is offline   Reply With Quote Quick reply to this message
Old 07-31-2010, 10:41 AM   #14
fl-mitchells
fl-mitchells's Avatar
Member # 4246
Bearing grease here too, cuz it's already in my toolbox. I just put a dab on the post before I slide them on and swing the door back and forth a few times to spread the love. Wipe off any extra that oozes out so it doesn't pick up dirt. Before I started doing these the doors were growing increasingly difficult to lift off, and the pins had begun to rust and squeek. No more of that now!
On a side note, our mechanic for our big trucks was showing me how to replace a broken wheel stud recently (long story) and he uses a dab of bearing grease on the studs before he runs his lug nuts on. I'd never heard of greasing wheel studs before but I'm doing it now and it definitely cuts back on the rust and the chance of cross threading.
__________________
"Experience is something you don't get until just after you need it." --Stephen Wright
fl-mitchells is offline   Reply With Quote Quick reply to this message
Old 08-16-2010, 06:41 AM   #15
jake_blue
Member # 9242
That's exactly what I was going to say!
Also, there is some sort of nylon braided sleeve in the body side hinge (inside the tube) and I tapped/ripped that bad boy out as quickly as possible. I'm sure that was a great idea on the drawing board but what a PITA in the real world.
jake_blue is offline   Reply With Quote Quick reply to this message
Old 08-16-2010, 07:37 AM   #16
jgkjeep
Member # 9066
I use white lithium out of a tube or wd40. Whichever my hand reaches first.
__________________
2007 Rescue Green 2-door
A few mods here and there
jgkjeep is offline   Reply With Quote Quick reply to this message
Old 08-16-2010, 08:20 AM   #17
TG426
TG426's Avatar
Member # 9272
I applied Super-Lube synthetic since I already have and use it on the boat.
__________________
Tom
2010 Wrangler Unlimited Sport
ORH soft top, Procomp 7069's,Poly Performance leveling spacers
Goodyear Wrangler Duratracs, PSC Evap Skid, CB, Hi-Lift
TG426 is offline   Reply With Quote Quick reply to this message
Old 01-13-2011, 10:33 PM   #18
mecheng10
Magnitude Engineering, LLC
mecheng10's Avatar
Member # 10599
Jeep Door Hinge Bushing/Sleeve/Insert Lubrication
I would recommend against using a petroleum-based lubricant on any door hinge with composite bushings/sleeves/inserts such as those used on Jeep Wranglers. These lubricants can cause the composite material to swell and degrade making problems worse. The best bet is to use a non-metallic bushing and run them dry. I recommend a high grade engineering plastic such as delrin. Some people will recommend brass bushings, but in reality a self lubricating plastic is the best long term choice from a wear stand point, and you won't have increased issues with galvanic corrosion causing rust on your hinges or bolts due to proximity of dissimilar metals. I can discuss further with anyone that would like more help with this and can help you get the exact bushings you need. E-mail me through my website if you want to learn more.
Brian Pechan
www.magnitude-engineering.com
mecheng10 is offline   Reply With Quote Quick reply to this message
Old 01-13-2011, 10:56 PM   #19
maverick
maverick's Avatar
Member # 669
Brian Pechan
Buy a YELLOW star and I'll buy two sets.
Seems shipping would be FREE considering the size and weight.
__________________
maverick is offline   Reply With Quote Quick reply to this message
Old 01-13-2011, 11:50 PM   #20
STUPIDFACE
Heat'n and a beat'n...
STUPIDFACE's Avatar
Member # 2880
I say 3n1 earl...
__________________
corey d
2008 JEEP...
STUPIDFACE is offline   Reply With Quote Quick reply to this message
Old 01-14-2011, 01:25 AM   #21
TEXASKEV
Member # 112
Read the info on your site. You sold me. Get that yellow star and I'll order a set! <we like vendors who support JKO. Lots of doors off wheelers on this site = customers
__________________
Old 01-14-2011, 05:43 AM   #22
dsy
dsy's Avatar
Member # 365
Napa Sil-glyde works great for the door bushings, also the top and door seals.
http://www.napaonline.com/Search/Det...351_0282385811
dsy is offline   Reply With Quote Quick reply to this message
Old 01-14-2011, 06:18 AM   #23
2k2wranglerx
2k2wranglerx's Avatar
Member # 9620
Thanks!
Greg
Mine were suoer seized. It took an hour to get both off. I sanded the pins and hit them with antisieze and they've been good since.
__________________
2007 2 door, RK coilovers, 5.38 gears, built rubi axles, 35" Kumho KL71's, etc
2003 TJ, solid 60, Full traction long armed, caged, etc
2011 Jeep WK2 70th anniversary (baby hauler)
2013 focus ST, SCT with unleashed tune, green filter, Daily driver
2k2wranglerx is offline   Reply With Quote Quick reply to this message
Old 01-14-2011, 08:01 AM   #24
Dronac
Member # 11656
Do you all keep the torx bolts on the bottom or did you toss them?
__________________
2008 2 Door X
33x12.5R15 Duratracs on Soft 8's
2'' (3'' actual) Rusty's coil lift
Cobra 75 w/ Wilson 4' Flex
Dronac is offline   Reply With Quote Quick reply to this message
Old 01-14-2011, 09:05 AM   #25
Obstruction of Justice
Obstruction of Justice's Avatar
Member # 6064
Mine are sittin on a shelf in my garage for over a year now. I don't want to lose them cause I hear they're like 20 bucks a piece to replace.
Obstruction of Justice is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
