how to reset esp bas? - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK General Discussion
Old 06-06-2010, 07:21 AM   #1
austinjeepr
austinjeepr's Avatar
Member # 8185
I installed my adjustable tracbar and got called out to work before i centered my steering wheel and the esp, bas, and traction control lights all came on.
ABS came on about 8 times while driving till finally the ecm faulted out.
now a week later i got the wheel centered and figured i could hook my obd scanner up and clear it but no luck.
How in the hell do i reset it??
driving it wont reset it i drove it 25 miles, no reset....
HELP..........
Mat
austinjeepr is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 07:27 AM   #2
block
block's Avatar
Member # 6132
not sure if you did this .. but i would unhook the battery for 15 mins or so with your lights turned on .. that might reset it... seems like it should go off after you center your wheel.
block is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 08:05 AM   #3
paramaniac
paramaniac's Avatar
Member # 5392
You can try disconnecting the battery, but I have found that it will just reset itself after a while.
Worst case is you damaged the clock spring, but I highly doubt that
__________________
paramaniac is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 08:20 AM   #4
Mr.RonGilbert
Mr.RonGilbert's Avatar
Member # 3399
How "centered" is the wheel? If it is off just a little then it will throw the light. Mine stayed on even after I made some adjustments I centered some more and the lights went off after driving for a while.
I am not sure how long it takes to clear the damn thing once the wheel is centered.... hopefully someone who knows can enlighten us.
Good luck dude.
Mr.RonGilbert is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 09:05 AM   #5
tkob1060
tkob1060's Avatar
Member # 5021
it takes a certain amount of good key cycles to shut off, I forget if its 2 or 3 good runs of the wheel being centered. The battery disconnect should work though IF the wheel is actually straight.
__________________
tkob1060 is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 09:34 AM   #6
Zack Massey
Zack Massey's Avatar
Member # 3780
Mine is off center after the last weekend run. So Following this with interest. I have not had time to try and recenter the wheel yet but I will as soon as I find the post on how. Ok so I lied I had one day to try it but ended up yanking rear fenders and getting drunk with the neighbor. Sue me.
Zack Massey is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 09:45 AM   #7
austinjeepr
Member # 8185
Went for a ride to the auto parts store and the damn thing finally went off!!!!!
So all you have to do is be patient and it goes away.
Old 06-06-2010, 10:02 AM   #8
Zack Massey
Member # 3780
Don't think so on mine. My cruise control lever is almost straight up.
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
