Differential Fluid Change Front and Rear - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Tech > Write Up Dept. (The Library)
Old 05-17-2010, 06:20 AM   #1
bodybrdng
bodybrdng's Avatar
Member # 2147
Here is a quick write up to change your differential fluid. If you can change your oil then this will be a breeze.
What You Will Need
• 3/8" Drive Ratchet
• Torque Wrench
• 3" Ratchet Extension
• Oil Catch Pan
• Paper Towels
• 4 Quarts 75W90 Synthetic Gear Oil
Front Differential Capacity:
2.7 pints (1.35 quarts)
Rear Differential Capacity:
4.75 pints (2.375 quarts)
1. Use the square head of a 3/8" Drive ratchet, remove the top bolt on the differential cover
2. Place an oil catch pan underneath your differential. Then, using a 3/8" drive ratchet with a 3" extension attached to it, remove the drain bolt from the bottom of the differential. Allow your Jeep differential to drain completely.
3. Your differential drain bolt is magnetic and the inside end of it should have fine metal shavings. Clean with a paper towel and some brake cleaner to wipe the bolt clean.
4. Using a 3/8" drive ratchet with a 3" extension attached to it, reinstall your drain bolt back on to the base of your differential. Tighten this bolt to 25 ft. lbs. of torque.
5. Fill up your differential with your gear oil. The front differential only needs 2.7 pints (1.35 quarts) and the rear only needs 4.75 pints (2.375 quarts). If you have factory covers, all you need to do is fill up your differentials until gear oil oozes out of the fill hole. If you have an after market differential cover that has a higher fill hole, DO NOT fill up your differential with any more gear oil than it needs as it will just end up getting pumped out of the breather tube and make a mess.
6. Using the square head of a 3/8" Drive ratchet, re-install the fill bolt on to the differential cover. Tighten this bolt to 25 ft. lbs. of torque.
Side Note:
These towels are awesome for working on your Jeep
__________________
07 JK 2/DR Sahara, 35" Wrangler kevlar, 10k Winch, Garvin Roof Rack, 3" Black Diamond, CatBack Exhaust, RR Gen-1 Snorkel, too much more to list
Welcome to JKOWNERS- Home of boobs, guns, meat, and Jeeps.
bodybrdng is offline   Reply With Quote Quick reply to this message
Old 05-17-2010, 09:01 AM   #2
chromedome
chromedome's Avatar
Member # 762
I prefer to remove the covers, drain, then clean (with brakleen) and inspect.
Replace the covers and refill (with Royal Purple). To each his own..
chromedome is offline   Reply With Quote Quick reply to this message
Old 05-18-2010, 05:39 AM   #3
bodybrdng
bodybrdng's Avatar
Member # 2147
Me too, but there was a post on another thread on how to change the diff fluid so I did a quick write up for them. Dealer wanted to charge him/her $260... so I just wanted to save him/her some cash and time.
__________________
Old 05-18-2010, 08:27 AM   #4
riverzendz
riverzendz's Avatar
Member # 1678
You did a quick write-up or you did a quick copy and paste?
Either way, it's posted here now...I guess.
riverzendz is offline   Reply With Quote Quick reply to this message
Old 05-18-2010, 09:11 AM   #5
bodybrdng
bodybrdng's Avatar
Member # 2147
it's a mix of both
__________________
Old 06-17-2010, 06:09 AM   #6
NorthGAX
NorthGAX's Avatar
Member # 3482
So i have started my rear fluid change (dealer wanted $140 per axle). So I have one work of warning do not tighten the diff cover bolts to 30 ft/lbs. You will snap the head of the bolt off (ask how I know).
I am now working on extracting the bolt but needed to stop before I damaged myself or the Jeep. It is pretty straight forward and I appreciate the write-up.
__________________
Love you brother and you will always be my hero!
NorthGAX is offline   Reply With Quote Quick reply to this message
Old 10-11-2011, 07:48 AM   #7
RamboSFJC
RamboSFJC's Avatar
Member # 4634
Thanks for the write up, im gonna do mine today i think. The 90* heat might stop me!
__________________
In 2009 a crack commando wheelin' unit was sent to prison by a military court for a crime they didn't commit. These men promptly escaped from a maximum security stockade to the South Florida underground. Today, still wanted by the government, they survive as wheelers of fortune. If you have a problem. If no one else can help. And if you can find them. Maybe you can wheel with The 50/50 Off-Road Team.
RamboSFJC is offline   Reply With Quote Quick reply to this message
Old 10-12-2011, 08:46 AM   #8
TheBlackSheep
TheBlackSheep's Avatar
Member # 16727
just did mine after some wheeling caused a small leak in the front dana 30 - took about an hour. the rancho glide plate made it a pain in the ass. without that thing it would have been 30min.
the specs at autozone said the front diff required 2.1qt of oil. im thinking now that may have been for the 44. in any event - i put 2qt in and pulled the funnel out and about 1/2 a qt poured out of the fill hole (on level ground).
__________________
O||||O
TheBlackSheep is offline   Reply With Quote Quick reply to this message
Old 10-21-2011, 12:17 PM   #9
LTDanPup
LTDanPup's Avatar
Member # 15650
Doing this one over the weekend along with manual transmission and transfer case changes. The factory spec from my Android app says API Service Grade GL-5 80W-90 gear oil or 75-W140 for towing...
__________________
2008 Black Sahara 2-Door
Rough Country 3.25" Lift, LCAs, Quick Discos - LT295/70R18 Nitto Terra Grapplers - Warrior Products Rock Crawler Stubby Bumper - Olympic Double Rock Rails - Skid Row Offroad Evap Skid -Rugged Ridge Mirror Relo Brackets - "Angry Eves" Headlight Mod - Hella 500FF Fogs - Delta Tech Lug Nut Lites - Cobra 75 WX ST- 4' Firestik II - SuperChips FlashPaq
LTDanPup is offline   Reply With Quote Quick reply to this message
Old 08-20-2013, 07:43 AM   #10
ramnj
ramnj's Avatar
Member # 31242
Originally Posted by LTDanPup View Post
...The factory spec from my Android app says API Service Grade GL-5 80W-90 gear oil or 75-W140 for towing...
Which app are you using?
ramnj is offline   Reply With Quote Quick reply to this message
Old 09-04-2013, 09:54 PM   #11
Landoom
Landoom's Avatar
Member # 27601
My service manual says that you need to add an additive if you have the trac lock. Anyone know why and what it is?
__________________
If it ain't broke, don't fix it. If you don't like it, go break it!
'07 JKRU
3.5" RK X-Factor Lift on 37x12.5x17 MTR-K's wrapped around AEV Pintler Wheels
Landoom is offline   Reply With Quote Quick reply to this message
Old 09-04-2013, 10:00 PM   #12
Landoom
Landoom's Avatar
Member # 27601
Never mind. Answered my own question.
Don't need additive with most name brand oils.
__________________
'07 JKRU
Old 11-13-2013, 07:20 PM   #13
jkfamilypride
jkfamilypride's Avatar
Member # 49954
I highly suggest adding a friction modifier when doing this. helps keep the gears slippery! $7 for a bottle at napa
__________________
2010 Jeep Sahara black 4DR
-AFE CAI
-Throttle body spacer
-KC windshield slim lites
IRAQ AND AFGHANISTAN COMBAT VETERAN 2006-2012
jkfamilypride is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
