JK axle U-joints - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK General Discussion
Old 05-08-2010, 06:25 PM   #1
SGT. K
Member # 9159
JK axle U-joints
My 08 jk U-joints take a crap every time I use the 4 wheel drive. I have the unlimited 4 door. I have broken both u-joints in the front axle. Is anyone else having this problem?
SGT. K is offline   Reply With Quote Quick reply to this message
Old 05-08-2010, 06:31 PM   #2
4x4x4
4x4x4's Avatar
Member # 6912
I know there were some having problems with the retainers on the joints allowing them to come apart. One of the things I did to keep the caps in place was to give each one a small spot weld. I don't know if this has helped but I haven't had any issues and I have wheeled it pretty hard. This is a pic of what I did:
I also put in EVO C gussets in this picture.
__________________
Army 13B enlisted & 15B officer MΟΛΩΝ ΛΑΒΕ NRA Life Member /
Detroit/Aussie,Sport Cage,4.5 lift, some welds...
4x4x4 is offline   Reply With Quote Quick reply to this message
Old 05-08-2010, 06:40 PM   #3
StubEXrube
StubEXrube's Avatar
Member # 1473
When you say "broken"....you mean they have actually broken or that the caps have come out?
As stated- you can tack-weld the caps to insure that they don't "wander off". If you have lost u-joint caps and not yet broken the ears on the outer stub shaft, then consider yourself lucky.
__________________
StubEXrube is offline   Reply With Quote Quick reply to this message
Old 05-09-2010, 08:28 AM   #4
jvalason
jvalason's Avatar
Member # 3263
How are hard are you wheeling? I have 35s on a D30 and havent broken one yet (knock on wood)
jvalason is offline   Reply With Quote Quick reply to this message
Old 05-09-2010, 08:42 AM   #5
SGT. K
Member # 9159
Jk U- Joints
My Jk Is running on 32's. I don't wheel it real hard. I broke the right front at BVORR it apperead the retaining clip failed. I was at the beach yesterday when I broke the left front in powdery sand. I was not wheeling hard at all. The U-joint actually snapped. Can anyone recommend a replacement u-joint that is not $200 or more? Also when this u-joint snapped it caused the left front axle seal to start leaking, is this common. I've never had a axle seal leak from a u-joint snapping.
Old 05-10-2010, 10:46 AM   #6
rabidranger
Member # 1152
You don't say whether or not you have a rubi, but if you DO NOT you can use the spicer 5-760x joint. Should only be about $25. Don't know how they compare to the stock ones though.
If you have a rubicon you are hosed. The ONLY things out there are the stockers from the stealership, CTM's (~$275) or the CV thingies (can't think of who makes em, but they are $$$$).
__________________
Good leaders are scarce, so I am following myself.
rabidranger is offline   Reply With Quote Quick reply to this message
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
