6.1 Hemi conversion question - JKowners.com : Jeep Wrangler JK Forum
Go Back   JKowners.com : Jeep Wrangler JK Forum > JK Community > JK General Discussion
Old 04-12-2010, 02:32 PM   #1
jrc
Member # 8919
does anyone know if a 2006 Dodge Charger 6.1 Hemi motor will fit in a JK?
jrc is offline   Reply With Quote Quick reply to this message
Old 04-12-2010, 02:38 PM   #2
ALASHA
F5 Champ
ALASHA's Avatar
Member # 6694
All Hemi engines will technically "Fit" in the JK. The issue is with how the front accessory system is set up. Check with the company whose kit you want to use to see if the kit works with that engine. The AEV for example recommends Hemis out of Cherokees and Commanders and JSS uses hemis from Rams.
ALASHA is offline   Reply With Quote Quick reply to this message
Old 04-12-2010, 03:38 PM   #3
txjeeplover
txjeeplover's Avatar
Member # 2576
I've been doing research on this topic and yes the 6.1 from the Charger will work but you'll have to change the oil pan and pick up. There are 2 variations of the accessory drives for the 5.7 (LX and DR) but one setup for the 6.1.
__________________
2008 2 Door Rubicon
4" Zone Lift
15x10 Ion 138
35x13.50R15 Toyo Open Country MT
A bunch of other stuff done and yet to do
txjeeplover is offline   Reply With Quote Quick reply to this message
Old 04-12-2010, 05:42 PM   #4
scrogg
scrogg's Avatar
Member # 1196
not knowing if your planning on keeping on the street or not, but doesn't the engine have to come out of the same year or newer for emission reasons?
__________________
scrogg is online now   Reply With Quote Quick reply to this message
Old 04-12-2010, 06:08 PM   #5
txjeeplover
Member # 2576
That's a safe rule of thumb to meet 50 state engine swap requirements but rules actually vary state to state. For example, in Texas the only requirement is that the vehicle have all the emissions components that were present when the vehicle was manufactured.
__________________
2008 2 Door Rubicon
4" Zone Lift
15x10 Ion 138
Security Question
Insurance
Date of Birth
Month Day Year
Privacy
Forum Jump
